Old 06-30-2020, 08:40 AM   #1
2019 ​Interstate Nineteen
Thousand Oaks , California
Cool Interstate 19 no power in back
The power in my Interstate 19 is gone. Nothing works even when plugged into external power. I found the battery for the engine dead and jumped it to restart it. The car drives fine but nothing except for the door step works in the back. When I plug it into external power only the inverter shows any life and it says fault. Any ideas where to start? I checked the GFI, breakers and fuses and didn't find any issues.
Interstate D is offline   Reply With Quote
Old 06-30-2020, 06:30 PM   #2
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
You may need to put a charger on the coach batteries. If these batteries are dead, the Magnum will not pick up and charge them from the external hookup. The battery manager that Airstream installs is a very poor piece of equipment and may very well be not passing the charge from your generator to the 12v system in the rear if the coach batteries are too low.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 07-01-2020, 08:04 AM   #3
Thank You
Thank you for the help. I thought that might be the case. I'll give it a try. Can you tell me where the charge access is to the house batteries? I'll review the manual too.
Old 07-01-2020, 09:12 AM   #4
Contributing Member
Pahaska's Avatar
Pretty much need to hook to the batteries themselves. Kind of tight there under the coach.
John W. Irwin
WBCCI #9632
Bottle Jack: back up of back up? Atsushi Hitches, Couplers & Balls 33 03-03-2019 09:30 PM
2017 AI back huge back TV obstructs walkway Perpich Audio, Video & TV 0 10-07-2016 11:48 AM
Back and forth, back and forth.....what 2 do??? WILDRTEXAS Upholstery, Blinds, Walls & Interior Finishes 19 11-30-2009 05:24 PM
UPS back-up power supply in an AS? richinny Batteries, Univolts, Converters & Inverters 8 09-30-2008 01:17 PM
Odd back-to-back eBay auctions .... summerkid Trailer Values 5 09-12-2005 12:34 PM
