05-25-2023, 10:45 PM
Flagstaff
Anatomy of a Trailer Sway Accident
I found this video on YouTube. It all happens pretty fast so I slowed it down and added some commentary as the event unfolded. No indication if the Jeep had a WDH.
Clearly the worst case for sway as they started down hill just as a semi truck overtakes the TV/trailer on the left.
http://youtu.be/hfTddTzozyw
2022 25' GlobeTrotter FB <->2021 Ford F-150 PowerBoost 7.2kW ProPower
Electric Globetrotter
05-26-2023, 05:06 AM
1971 23' Safari
Windsor
, South Carolina
Thank God they didn’t get flipped down that embankment!
05-26-2023, 05:36 AM
1994 30' Excella
alexandria
, Kentucky
Wow that’s crazy!
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
05-26-2023, 06:07 AM
Oak Park
That is really crazy to see happen in slow motion.
That wheelbase seems fairly short for that trailer, but maybe that's just me...regardless, the ending could have been far, far worse.
I saw the aftermath of something similar to this several years ago. Guy was towing a roughly 25er with a Jeep like this. Both RV and Jeep wound up on their side. After making sure everyone was ok, I took a look at the hitch setup. He was towing on the ball only. Didn't even have friction sway control....but the chains did work.
05-26-2023, 06:13 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
WB...no it's it's not just you...short makes a marginal lash-up quite a bit worse.
Step on the gas a bit & hit the trailer brakes.
"You don't know where you've been until you leave, enjoy life" RLC
05-26-2023, 07:08 AM
2018 23' Flying Cloud
Peru
The Equation
Jeep Cherokee towing capacity 2,000 lbs (4,500 with Towing packages) + Forest River Micro Lite 25' UVW #5,748 + HW #824 = disaster.
zoz
Cindy & Randy
2018 AS Flying Cloud 23FB
2018 GMC Sierra Denali 4x4 6.2L
05-26-2023, 07:10 AM
2020 25' Globetrotter
Hillsdale
, New York
Would love to know hitch weight as % of trailer, as loading up a bunch of bikes on a rear mounted rack will unweight the hitch some.
SPP
05-26-2023, 07:35 AM
Flagstaff
So many variables. Jeep Cherokee has a GVW of 5,500 which is more than I thought. Towing weight restrictions most likely hitch structural related. Does the Jeep Cherokee have electronic sway control like the F-150? I really think electronic sway control is the magic sauce that can abort the onset of sway in situations like this.
For my part I have started a practice of putting my finger on the trailer brake paddle any time I crest a hill with a semi on my tail in the left lane.
05-26-2023, 08:00 AM
2017 16' Sport
N/A
, N/A
Be careful when using a generic name Jeep Cherokee, there are different models with very different capabilities in towing etc. some with excess of 7000 lbs.
05-26-2023, 08:57 AM
2008 22' Safari
Spicewood (W of Austin)
Well, certainly Bob stated the proper corrective-action would have been to apply trailer-brakes only…(which alone should have solved the problem)…. But…
The added weight of those rear-mounted bikes don’t help…..And….
I you look at :20 sec’s you can see that overpass the 18-wheeler/jeep-combo simultaneously passing beneath likely contributed greater “bow-wave” effect upon the combo…. and….
Prior to the sway-event it appears the jeep rear wheel-well height/ axle is higher than it’s front ….while the trailer is “hitch high”…. not a good set-up…. This makes for a naturally unsteady combo and increases sensitivity to sway. It becomes Worse as the Jeep applies brakes and the trailer begins to “over-run” the Jeep.
I suspect that trailer/bike pkg is tail-heavy being towed by a short-wheelbase TV which has it’s rear axle un-loaded somewhat.
Less gov’t is what we all desire…but I believe that it might be a good idea to require “Trailering” to the restrictions and testing requirements of driver licensing, especially when TV-to-Trailer size/weights approach equality or greater.
05-26-2023, 09:20 AM
2021 22' Caravel
Houston
Thank you for posting. That is absolutely terrifying. I have been considering the Tuson electronic sway controller that brakes trailer wheels if sway is detected. It seems to get good reviews. I have sway control on the F-150 so I would need to make sure the two systems don’t fight against each other.
Thanks again.
05-26-2023, 09:25 AM
Flagstaff
I agree with your analysis. Also it is common to see the strongest winds at the top of a hill. So all these factors summed together to start this event.
I agree, toggling the trailer brakes at this point and not using the TV brakes may have aborted the whole thing. It would be really nice to have a steering wheel mounted trailer brake toggle switch for just these situations since reaction time is critical.
05-26-2023, 09:36 AM
Roanoke
, Virginia
Thank you. The video, along with the commentary, is a good safety lesson. It's uncomfortable to watch, but it really helps me to go through what-if scenarios.
05-26-2023, 10:57 AM
Occasional RV
2023 27' Flying Cloud
Coatesville
, Pennsylvania
This stuff is terrifying which is why my TV is capable of towing much more than I’m willing to tow with it. I like to stay well under any max. numbers.
05-26-2023, 11:04 AM
Flagstaff
No doubt the bigger the better when it comes to TV's. But there are so many variables that can conspire even with a big TV. Anticipating a sway event (big truck, down hill, overpass, strong winds all together) and learning how to quickly react to the beginning of a sway event may be more important than the TV or WDH used.
This thread and associated video should be a sticky post in the Towing, Tow Vehicle & Hitches forum.
05-26-2023, 12:29 PM
2007 25' Safari FB SE
2017 30' Flying Cloud
Highland
There is one more variable that I have not seen discussed and that is "speed". I cannot tell from the video how fast the traffic is moving. Towing speed is regulated by the state and it can range from 55 MPH to 75+. In any case the driver is driving faster than the road conditions; rig configuration allows including the driver's ability. No doubt this individual was a road hazard pulling out their driveway at home.
Hugh----
05-26-2023, 01:25 PM
2000 25' Safari
Woodbine
, Georgia
Hensley or ProPride
05-26-2023, 04:10 PM
2021 28' International
Knoxville
, Tennessee
I think it's a safe bet that if they're still trailering, they own a bigger TV.
A cautionary tale if there ever was one.
05-26-2023, 07:41 PM
2018 25' Flying Cloud
2019 25' Flying Cloud
2021 30' Flying Cloud
Lady Lake
Rear brakes
If your trailer is not set up with proper weight distribution and correctly loaded all that “Ferd fancy puter swaying cnytl “will do is smoke your rear brakes while you tool along saying wow what a great truck.
Thanks again.
05-27-2023, 04:46 AM
2019 28' Flying Cloud
Broward
It looks to me like the root cause of this accident was a ridge on the freshly paved road surface. When the trailer dropped off the edge and the driver tried to bring it back again it suddenly surged and started swaying. The driver then overcorrected and lost control. He should have taken his foot off the gas pedal, slowed down and held the wheel straight.
