08-08-2020, 04:11 PM
#141
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver
Originally Posted by HRTKD
When I have to remove the belly material and fiberglass insulation to get to something on the underside of my trailer, I've been using Owens Corning rigid foam to insulate the underside of my trailer. So far, it's worked well.
Not sure what material the Owens Corning is made of, but polyisocyanurate is definitely the way to go (rigid, foil faced, closed-cell foam panel). It has the highest R value of any of the rigid panel insulations, it is very light, and it *will not* hold moisture.
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
08-08-2020, 04:23 PM
#142
1977 31' Excella 500
Spring
Yup I still need to find a solution for insulation on the floor. I love the idea of ease of working on anything under there without the belly pan in the way.
08-08-2020, 04:25 PM
#143
Spring
Originally Posted by PeterH-Airstreamer
No flack, just wondering about lots of drag and no option for insulation?
Not too worried about drag. The beauty of an airstream is I feel it has a way better drag coefficient than most all other RV's out there. With or without a traditional belly pan.
08-08-2020, 04:42 PM
#144
Highlands Ranch
If you're creative in how you install the rigid foam, it comes out as easy as it went in.
I was looking at a 40' toy hauler with no underside insulation. Crawling under there for hours on end wasn't going to be a lot of fun. The plan was to hold the insulation in with angle aluminum along the edges and a single aluminum strap across the middle. This would be installed in sections of course. The chance of installing and entire 4'x8' panel at a time wasn't likely to happen.
I think the construction of your trailer frame lends itself to this. At least on the central part of the frame. Rigid foam outside the frame rails would require a slightly different method.
2006 Fleetwood Gearbox 220FB (toy hauler) <- current
2017 F-350 CCLB 6.7L
2019 Nissan Leaf SV+
08-08-2020, 06:00 PM
#145
Spring
I'll definitely have to look in to this...
08-08-2020, 06:01 PM
#146
Spring
Any options that could go inside the trailer - more specifically under whatever flooring I use?
08-08-2020, 06:46 PM
#147
1960 33' Custom
Athens
, Georgia
My plan was, and probably still is, to leave the frame cavities insulation free. I've installed the perimeter belly pan to the rails and at some point I'll cut sheets down to cover each cavity. But each sheet section will be joggled with a 2" lip so they can overlap from front to back and each section will be cross braked so they don't make that oil can boom. Above the floor I think I'll use 1/2" cork for insulation and very likely leave it as the finished floor.
I plan to use 3 grey tanks and a DOT LPG tank in the frame cavities so no insulation gives me more room and less headaches.
08-08-2020, 09:59 PM
#148
Spring
Cool something else to look into. I wonder how well the cork would stand up to dogs coming in and out all the time.
08-11-2020, 02:10 PM
#150
1960 33' Custom
Athens
, Georgia
similar I think. With your steel tube wall thickness i'd look for a self tapping floorboard screw that matched the gauge correctly, Fastenal or similar maybe 5/16" diameter.
08-11-2020, 02:18 PM
#151
Spring
So more along the lines of this?
https://www.fastenal.com/products/details/32535
08-11-2020, 02:32 PM
#152
1960 33' Custom
Athens
, Georgia
Yup, exactly
08-11-2020, 02:42 PM
#153
Spring
Yup, exactly
Ordered - thanks for pointing me in the right direction
08-11-2020, 02:44 PM
#154
Spring
I went ahead and ordered the curved section of c-channel direct for front and rear so I don't have to mess with it as much. I did not realize it would be the double-c setup like down the sides. Kind of annoying.
08-12-2020, 04:55 AM
#155
2019 27' International
Rogers
, Arkansas
Even Easier
GPurcell,
Another and IMO even easier option is the Elco Brand 1-7/16" wing tek screw. The wings makes the hole in your wood slightly bigger so it doesn't burn the point or break the screw trying to thread and drill at the same time. Then the wings break off on contact with metal and self drills the metal.
These have been great for me.
Good Luck!
08-14-2020, 02:02 PM
#156
Spring
Floor should be cut this weekend. Waiting for my floor screws to be delivered so next weekend maybe... just maybe... I might have a trailer back in one piece.
08-15-2020, 02:28 PM
#157
Spring
Floor cut to the correct width. I forgot the c-channel at home so didn't mess with the curved sections front and rear
The wheel wells have to be cut out still too. It's still big progress though.
Since the original curved sections were shorter than the rest, I'm thinking of actually taking the access out here at the wheels.
Standing on the floor was a great feeling...
08-15-2020, 03:50 PM
#158
Spring
Oh and I forgot to grab some pictures of it but prepped the c-channel down the sides of the shell. Removed the remaining bits of old floor and cleaned everything up with a grinder.
08-15-2020, 05:08 PM
#159
Perpetually Perplexed
Mobile Rail Bunkhouse
Farmington
, MO
My apologies if I missed it but what flooring did you decide on?
08-15-2020, 05:44 PM
#160
Spring
Coosa Bluewater 26 board
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
