08-16-2020, 04:35 AM
#161
2019 27' International
Rogers
, Arkansas
Great progress Gary! Are you having mostly fun so far?
08-16-2020, 09:50 AM
#162
1977 31' Excella 500
Spring
So far! still trying to figure out the best way to tackle this floor so everything lines up. Little stressful cutting up board as expensive as the Coosa lol
08-19-2020, 07:22 AM
#163
Spring
Got my order from Fastenal. I don't think my floor will be coming up anytime soon I love having the 6-lobe drive head too instead of phillips.
Truckasaurus - thanks for the tip on what to order.
08-19-2020, 08:31 AM
#164
Highlands Ranch
That is one monster screw! Or you have really small hands. No, it's a monster screw.
2006 Fleetwood Gearbox 220FB (toy hauler) <- current
2017 F-350 CCLB 6.7L
2019 Nissan Leaf SV+
08-19-2020, 09:21 AM
#165
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver
Originally Posted by GPurcell
Cool something else to look into. I wonder how well the cork would stand up to dogs coming in and out all the time.
The answer: it won't. Take it from someone with a lot of experience with cork floors and dogs.
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
08-19-2020, 11:28 AM
#166
Spring
Ok good to know. Most likely will lay the cork down and then some sort of click-lock flooring on top.
08-19-2020, 11:32 AM
#167
Spring
Hahaha definitely a monster screw. Should be seeing how they work soon!
08-19-2020, 11:55 AM
#168
1972 25' Tradewind
1975 24' Argosy 24
Denver
It's a bummer, because I'm a midcentury freak and I LOVE cork floors, but after 15 years with several kinds of floor (click lock at varying degrees of expense, rolled, glued tile, etc.) and three different dogs (Doberman - no issues, Pit/Boxer - destruction, Hound/Dobie mix (spaz) - absolute disintegration), I would never install them in an RV with that much traffic (at this point, I wouldn't even use them in a home unless it was a very low traffic area).
There is probably a better insulating material than cork to lay under LPV or whatever flooring you choose. A lot of the "sound mats" have decent thermal insulative properties, but I still think you'd be happiest with some polyisocynurate panels on the underside of the subfloor.
BeahmStream.com
08-19-2020, 02:30 PM
#169
Spring
Thanks for the info! Very much appreciate the honesty. I'll have to look into the polyisocynurate compared to other options.
08-22-2020, 03:44 PM
#170
Spring
Today was a big day.
Got supervised the whole time.
Anyways, test fitted the c-channel
Once the fit was checked, started cutting the Coosa.
Point of no return now
Started fitting the second sheet behind the first.
Here's where I decided to make us stop... I have found one downfall to the Coosa. While yes, it is stronger than plywood, it does flex some more.
With that being said, I have decided to get more angle iron and add floor supports between the outriggers for added rigidity. Do it once - do it right.
Also - so much room for activities with the belly pan above instead of below.
08-22-2020, 09:16 PM
#171
@steadystreamincashios
1968 28' Ambassador
1964 26' Overlander
1976 Argosy 26
Heber Springs
, Arkansas
It’s looking good! Curious as to if you are still going to wrap the aluminum on the edges (skirts) so the frame isn’t “exposed”? Maybe you mentioned this but I couldn’t remember. Keep up the great work.
08-23-2020, 10:40 AM
#172
1972 25' Tradewind
1975 24' Argosy 24
Denver
Shouldn't that Coosa joint be over an outrigger and cross support? Also, do you think the Coosa will flex even when it's fastened down? I'm wondering if that would take care of the flex and save you some work (and weight, though obviously at this point we know you don't really care about weight! )?
I'm getting ready to purchase some Coosa to replace the floor in a GMC motorhome, but I think there is plenty of support in that GMC chassis that I don't need to worry about flex. I am however thinking about cutting some access ports to store/access mechanicals in the belly.
BeahmStream.com
08-23-2020, 01:48 PM
#173
Spring
That... is something I totally glossed over I may have to mess with it some more
08-25-2020, 10:44 AM
#174
Chappell Hill
Post some updates on the off road frame.
08-27-2020, 10:45 AM
#175
Spring
Updates coming. Been a little crazy past couple of days.
08-27-2020, 10:46 AM
#176
Spring
kidjedi - I will be cutting down the boards like you suggested so the joints land on a crossmember.
However - I still will take the time to weld in some more supports. Just feels like the right thing to do.
08-27-2020, 11:00 AM
#177
Highlands Ranch
Playing Devil's Advocate here...
Do you really need supports between the outriggers? Once the the trailer is finished, how much foot traffic is there at the edge of the trailer? Most of the edge of a trailer has cabinets or other "stuff" on it, that would span the existing supports.
I don't know how the shell is attached to the frame. I assume that it will attach at the outriggers for sure. But could you also put a screw between the outriggers up into the shell? That would add some support to the Coosa board.
08-28-2020, 08:03 AM
#178
Chappell Hill
You probably already know this, but be aware that there actually needs to be some flex in the frame or you will start popping rivets and possibly creasing panels. I've been researching building a frame from scratch for a couple months. My original thought was "as solid as possible," but evidently that's not the way to go; there needs to be quite a bit of flex for these monocoque designs. I'm also looking at "deck over wheel" possibilities, but I don't want to increase my center of gravity too much (though I do want to raise everything quite a bit to increase clearance by as much as possible). I am also looking at water tank solutions mounted inside the cabin, both to minimize damage from below (rocks, logs, etc.), but also to keep things from freezing in the winter. I am aiming for a Colorado high altitude winter build, so everything needs to hold up to remaining in use at sub-zero temps.
Interesting. I see this mentioned often but I don't get it though. I can't figure out how the monocoque structure needs to have flex or it pops rivets or could buckle.
I would think that being more structurally rigid, it would prevent the flex that causes these issues.
It seems every time I've seen a post of an AS buckling or rivets popping it was because of too much flex or a hard jolt. Rivets were popped by hitting rough roads or trailer twisting, or due to too much WD force, etc.
Buckling of panels, I would think, can only be caused by displacement of the supporting structure in some way, such as when a wrecker tries to pick up by the rear or extreme tail drag situation, etc.
I can't wrap my brain around how more rigid frame would not help maintain the overall integrity of the structure. A properly cushioning suspension being part of the build.
08-29-2020, 01:22 PM
#179
Spring
I'm going to be doing that on top of adding more supports.
08-29-2020, 01:28 PM
#180
Spring
Got some more angle iron. 1/8" 2x2.
Each outrigger will get one support except where the door is. Cut out two for that.
Also decided to cut out one more set of outriggers for the rear of the trailer. It's under where my bed will be but decided that it would be better safe than sorry. One more attachment point too.
