11-09-2021, 06:04 AM
#121
Richmond
, Kentucky
Originally Posted by Boom Sounds
Without going too off topic, what is the best approach for me to try and find a spare/matching ECM for my 1991 250? It feels like a good spare to have on my travels.
Nick,
There are two parts involved. One is the ECM itself and the other is the Memcal.
For my Argosy I used a 1994 ECM with part number 16248378 and the Memcal was BYYC.
To get the Memcal info you might have to remove the cover from the ECM and read the Memcal number.
The ECM is the computer and the Memcal is the program that is ran by the ECM.
I found all of my parts on ebay.
1975 24' Argosy Motor Home
11-09-2021, 02:07 PM
#122
1991 25' Airstream 250
Oxford
, Oxfordshire
Originally Posted by bkahler
Nick,
There are two parts involved. One is the ECM itself and the other is the Memcal. For my Argosy I used a 1994 ECM with part number 16248378 and the Memcal was BYYC. To get the Memcal info you might have to remove the cover from the ECM and read the Memcal number. The ECM is the computer and the Memcal is the program that is ran by the ECM. I found all of my parts on ebay.
Thanks Brad
11-25-2021, 07:22 AM
#123
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Originally Posted by 92landyacht
Brad, does your Argosy have an electric fuel pump? If not, than this module would do nothing for you. If you do have an electric fuel pump, then I can send you a housed board with just the pigtail wires coming out. You can then just splice those wires into your existing harness.
I currently have the module side pigtail connector but not the mating connector that's normally on the main harness. If you want, I can try to find the mating connector and supply you with that but you'll still need to splice that into your harness.
I received your latest version and installed it! Works perfectly, thanks for all your effort.
Question: This module should also work for a carburetor setup, if you have a rear electrical fuel pump, right? A little wiring is all that is needed. The module itself does not depend on the ECM to function, it is pretty much stand alone. Or am i missing something?
AIR #13
11-25-2021, 07:46 AM
#124
Richmond
, Kentucky
Peter, with a carburetor setup on our coaches that have an electric pump, the pump is typically energized all the time. On a TBI the pump is energized for 2 seconds then is turned off until oil pressure is verified (i.e. engine is running).
I supposed technically you could install one of Julius's modules but all you would really need to do on a carbureted engine is leave the ignition switch on until it built up pressure.
11-25-2021, 08:48 AM
#125
Airstream Driver
1994 30' Excella
Austin
Ok, I understand, however, a safe setup would be to tie the aftermarket rear electric fuel pump to the oil pressure switch. In that case the module would come in handy.
I believe the late 80's carbureted engines with the factory rear fuel pump have that safety feature, which must include a temp module? Anyone?
AIR #13
11-25-2021, 11:51 AM
#126
1992 36' Land Yacht
Grayson
, Georgia
For what it's worth, I do now have a standalone module named the Brad Module that can be added to any harness. The module comes with a stock connector for those that don't have the modules box and have the stock TBI harness or just a three-wire pigtail. For the three-wire connection you just need to connect to +12V ignition, ground and an output to the fuel pump. I'll be sending out Brad's unit on Friday.
11-26-2021, 05:13 AM
#127
Oxford
, Oxfordshire
Thanks, I'm in. I'll PM you. Great work, thanks for all the effort. Top quality work.
11-26-2021, 06:12 AM
#128
1992 36' Land Yacht
Grayson
, Georgia
Just let me know if you need just the replacement board or a completely housed module.
12-18-2021, 03:24 PM
#129
1992 36' Land Yacht
Grayson
, Georgia
I now have all the parts needed to produce everything form just the board to a complete module with both male and female harness connectors. The complete unit doesn't look stock but is fully functional. I'll post pics in a day or so.
12-19-2021, 07:35 AM
#130
Airstream Driver
1994 30' Excella
Austin
I am enjoying the reliability of your units. Since I had to check the rear fuel filter frequently, my fuel shut off valve and your module let me do the job in minutes and pressurize the system in no time.
I am still amazed how little attention this module got over the years, until I had to deal with the consequences of a burnt out unit and had to trace the wiring to its hiding place.
AIR #13
01-11-2022, 08:12 AM
#131
Richmond
, Kentucky
I had to laugh when this Fuel Pump Control Module showed up on ebay this morning
01-11-2022, 05:10 PM
#132
1992 36' Land Yacht
Grayson
, Georgia
Ya, pay $70 and have it fail the next day. Seen too many of the stock units in a very "crispy" condition.
My newest module is rated for 20 amps. Perfect if you have upgraded your fuel pump to a higher current unit or just have extra capacity in general.
01-12-2022, 07:36 AM
#133
Richmond
, Kentucky
Yeah, there are times when NOS is not necessarily a great thing. Old electronics are just that "old".
Thanks again for your work on this project!
