09-16-2021, 08:25 AM
#61
1992 36' Land Yacht
Grayson
, Georgia
Final tested the module today in my motorhome. Output voltages were as follows:
Key turned to ON but engine not started. Several accessories were running including AC fan on high and air bag compressor so battery had significant load on it:
11.80V from Ignition and 11.79V to fuel pump.
Engine started and module providing power:
13.68V from Ignition and 13.67V to fuel pump.
Engine started and module relay turned off:
13.66V from Ignition and 13.66V to fuel pump.
These measurements were not done at the ODBI connector but made directly at the wires that the module plugs into. This gave me a complete picture of how much voltage was begin provided to the fuel pump both by the module and by the fuel pump relay. It also told me how much voltage loss I had through the relay. I was also able to check for any components that were getting hot. Specifically the relay while it was providing power to the fuel pump. No detected heating was noted. Time delay was 12 seconds with with jumper off (as pictured with red square thing at the top right next to the LED turned sidewise) and 20 seconds with jumper in place( Jumper shorting both pins).
On a side note, looks like my alternator is in good working order. Battery has sat for a few weeks and had a lot of initial load on it so that may account for the lower voltage with just ignition on.
Here are some pics of the module I tested:
Top View
Bottom View
09-20-2021, 06:42 PM
#62
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Hey Julius, the module(s) arrived today and I installed the new one right away. I left the jumper off (12 secs) and gained 2 full volts (11.5) on port 460 .
Still not system voltage, but by far better than the ~9.5 I had before.
Thanks so much for taking on this challenge.
AIR #13
09-21-2021, 07:17 AM
#63
1992 36' Land Yacht
Grayson
, Georgia
Good to hear. I left mine on the 12 second setting as well. 11.5V would be the suppled ignition voltage. A couple of tenths low but more than likely voltage loss through various connections along the way and load from the fuel pump itself. Pretty much what was expected. MUCH better than the 9.5V you originally had but also expected. The original design had over a volt of loss by design due to several semiconductor devices in series between the ignition source and the fuel pump voltage outlet.
09-24-2021, 01:02 PM
#64
1992 36' Land Yacht
Grayson
, Georgia
Originally Posted by cmadmaxman
Ok, will crawl back under there in the morning! Peter, if I don't find it, you will have to come up here and help me take out the rear-end
Put me on the list for a new module as well.
I also have another project for you. The wiper control module on the Zephyr is not working. You said you wanted something to play with.
Right now it's no good to me so if you want to look at it, I can send you the unit to look at.
Attachment 403221
Attachment 403222
Attachment 403223
If you're still looking for a module, let me know. I have one assembled, tested and ready to go.
09-26-2021, 11:55 AM
#65
Richmond
, Kentucky
Julius, if you're building and selling the modules I'd like to buy one.
1975 24' Argosy Motor Home
09-27-2021, 06:21 AM
#66
1992 36' Land Yacht
Grayson
, Georgia
I did order another batch of three boards, so I will have a few ready in a couple weeks. I have one assembled now but I've been using it to test under adverse conditions (high voltage, low voltage and reverse voltage under various loads). Don't think it would be a good idea to sell that one to anyone since it's been heavily stressed. I'll let you know as soon as I get the new boards built up and ready for sale. Selling price would be $50 delivered to your door. Let me know if that would be acceptable.
Julius
09-27-2021, 07:53 AM
#67
Richmond
, Kentucky
Julius
Price works for me and no hurry on delivery either. Just let me know when you want some money.
Thanks for taking on this type of project, it's helps others keep their rigs on the road.
09-27-2021, 11:24 AM
#68
1992 36' Land Yacht
Grayson
, Georgia
No money until I have a unit ready and tested for you. Thanks for helping others by supporting development of such items. Anything else that is needed and I'll see if I can fill that need.
I'll let you know as soon as I have it ready.
09-28-2021, 08:19 AM
#69
1988 34.5' Airstream 345
Clarkston
, MI
Where is this module in the vehicle? Is there a schematic that shows it?
09-28-2021, 10:50 AM
#70
Richmond
, Kentucky
The module is for fuel injected vehicles. Is yours fuel injected (i.e. TBI)?
09-29-2021, 06:53 AM
#71
1992 36' Land Yacht
Grayson
, Georgia
Yep, only used on TBI equipped vehicles. If you have a carburetor, then you don have one.
09-29-2021, 05:18 PM
#72
Clarkston
, MI
Ah Thankyou, one less thing to worry about.
10-01-2021, 04:51 PM
#73
1991 35' Airstream 350
Columbia
, Tennessee
Count me in Julius, I know it's there, just have to find it.
You have done a great job, thanks for your time working on this.
I will PM you my info. Paypal or what ever works for you.
Thanks again.
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
10-05-2021, 02:41 PM
#74
1992 36' Land Yacht
Grayson
, Georgia
I now have three units ready for anyone who needs one.
Chris yours is reserved and ready for shipment.
10-05-2021, 03:40 PM
#75
Columbia
, Tennessee
Thank you Sir![emoji106]
Sent from my SM-G950U1 using Airstream Forums mobile app
AIR Member 12654
1991 350LE "Zephyr"
10-06-2021, 08:16 AM
#76
Richmond
, Kentucky
I'll send you a PM with info.
Thanks!
10-10-2021, 08:04 AM
#77
1991 25' Airstream 250
Oxford
, Oxfordshire
Yes please Julius. I'm happy to pay shipping to the UK. thanks for taking this on, it's brilliant work.
Nick
10-10-2021, 08:42 AM
#78
1992 36' Land Yacht
Grayson
, Georgia
Nick
I'll look at the cheapest cost of shipping from USA to UK. Any suggestions would be helpful.
10-11-2021, 04:20 PM
#79
Airstream Driver
1994 30' Excella
Austin
Julius, little update on actual heavy duty usage. 200 miles in the last 2 days, 95F ambient temp. Many stops, restarts on a dime, hot or cold. Very happy that you tackled this!
AIR #13
10-12-2021, 06:08 AM
#80
1992 36' Land Yacht
Grayson
, Georgia
Glad to hear that it's working well. I've had one in my RV for several weeks. A couple trips of around 50 miles and starts almost every day since. Everything is working as expected.
