10-16-2021, 06:05 AM
#101
1992 36' Land Yacht
Grayson
, Georgia
Originally Posted by Boom Sounds
Thanks so much, I might see if you can ship it to a friend in the US and then I'll package up witha few other parts and get it shipped to the UK. Brilliant work btw and one less thing to worry about when on the road!
I remember a nightmare a few years ago (Brad and Martin will also remember) with a knock sensor (service engine) error on my dash (1991 250). We were due to leave for Italy for the Summer vacation the next day. I was about to can the entire vacation when, after getting into the ECM and PROM, I finally fixed it. What it did reveal that some parts (like your module), probably the ECM/PROM and others are total showstoppers if they fail. I think once I get your module, I might buy myself a spare ECM and PROM. I know they rarely fail, but I guess if they do, it is curtains particularly if you are on the road in Europe.
thanks again
Nick
Hey Nick. Just let me know what you want me to do.
As for the ECU failures, I've had one fail on my Landyacht. Mine may have been induced by a near by lightening strike but it sure did set me back a pretty penny to identify the no start issue. One thing I learned was to never park the MH where a tow truck can not get access to the front end. They had to winch my MH around in order to tow it to the repair center. The towing charge alone was $1600 due to the need for a "specialized" tow truck operator.
10-16-2021, 12:10 PM
#102
1992 36' Land Yacht
Grayson
, Georgia
Just for reference sake, here's a copy of the newest schematic diagram of the HFM.
10-17-2021, 07:48 AM
#103
Richmond
, Kentucky
Originally Posted by 92landyacht
Brad,
I'm working on a solution for you. I've ordered an updated PCB that will allow me to install it in a box and, hopefully, a connector that will connect to the harness connector. I'll let you know when I get it all together.
Sounds good, thanks!
1975 24' Argosy Motor Home
10-21-2021, 01:50 PM
#104
1992 36' Land Yacht
Grayson
, Georgia
Originally Posted by PeterH-350LE
Here are some pictures of Brad's future module case plug
Back to the question I asked earlier:
When I was thinking about you adding one to your system, I realized the the module gets energized from the fuel pump circuit as soon as the engine starts. Julius, does that sound right and could that be the cause for the old units to burn out? Is this something you considered when you designed yours?
Peter,
Hate to bother you again but is there any way you could take a picture straight into the connector opening? I'm wanting to make sure that the pins are the correct shape and that they're mounted into the housing in the correct orientation. The pins I have for the connector are offset toward the outside of the connector housing. Positions are A=+12V Output, C=+12V Input and D=Gnd. All other pins are left empty. If everything is correct, then I have a solution for Brad and those that don't have the original box.
10-21-2021, 04:36 PM
#105
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Peter,
Inside the original housing ?
AIR #13
10-21-2021, 04:48 PM
#106
1992 36' Land Yacht
Grayson
, Georgia
Sorry Peter, I should have been more clear. I need a picture of the inside of the connector that you posted the pictures of. I need to see a straight on shot of the contacts that mate to the ECU harness. I should have taken these pics when I had your case in hand but didn't think about it then.
10-21-2021, 06:05 PM
#107
Airstream Driver
1994 30' Excella
Austin
not a problem, least I can do.
AIR #13
10-22-2021, 06:03 AM
#108
1992 36' Land Yacht
Grayson
, Georgia
Perfect!!!! That is the exact connector combination I have the parts for now. I'll now be able to mock up a complete module from connector to PCB in a housing that should work. I received notice that the new PCB with mounting hole has been shipped and I should receive it soon.
Brad, Once I get it all together and tested I'll ship you a complete module with connector and housing.
This has been a fun project.
10-22-2021, 04:56 PM
#109
1992 36' Land Yacht
Grayson
, Georgia
Initial connector assembly is complete and looks like a perfect match to the one Pete posted in the pictures. Just waiting on the final revision of the board to begin final assembly. Should have the new PCB delivered on Tuesday. Will assembly and test the first prototype then. Brad, I will send out the new completed assembly some day soon after. If you can report back on how everything mates up it would be greatly appreciated. I would do it myself, but the shop that replaced my ECU stowed the connector behind the ECU so I can't easily disconnect the module without removing the ECU first. They also tie wrapped everything up which makes it even harder to get access to the connector to the module.
10-25-2021, 05:41 AM
#110
Richmond
, Kentucky
Sorry, I've been preoccupied for the last few days.
All of the wiring harnesses in my Argosy have been custom built by me which means it currently has no connector installed to tie into your new module.
Let me know what the case, various connectors, etc. and postages costs are so I can make sure you get paid.
Much appreciated!
10-25-2021, 12:05 PM
#111
1992 36' Land Yacht
Grayson
, Georgia
Much appreciated!
Brad, does your Argosy have an electric fuel pump? If not, than this module would do nothing for you. If you do have an electric fuel pump, then I can send you a housed board with just the pigtail wires coming out. You can then just splice those wires into your existing harness.
I currently have the module side pigtail connector but not the mating connector that's normally on the main harness. If you want, I can try to find the mating connector and supply you with that but you'll still need to splice that into your harness.
10-25-2021, 12:23 PM
#112
Richmond
, Kentucky
Actually I have two pumps
Low pressure suction pump and a high pressure injection pump. Each pump is controlled by a separate relay but each relay is driven by the same output from the PCM. I'll just connect your module to that PCM point and all should be good.
I'm good with just a pigtail connector coming out of the fuel pump control module.
10-25-2021, 01:17 PM
#113
1992 36' Land Yacht
Grayson
, Georgia
Sounds like an interesting setup. I should receive the new boards on Tuesday. Give me a day or two to verify operation and then I'll send you out the box with pigtail along with a new Rev: 6.1 board. No money is involved. It's my pleasure to lend a hand. The more units I have in the field the better.
10-26-2021, 05:56 AM
#114
Richmond
, Kentucky
Wow, that's very much appreciated!
When I was researching what vehicles might have used these boards I was surprised how many different forums had people searching for them.
Have you thought of ways to market the boards?
10-26-2021, 06:11 AM
#115
1992 36' Land Yacht
Grayson
, Georgia
I'm on a couple of forums but am open to suggestions. Marketing was never my strong suit.
There's been a slight setback on your board/module. The USPS was supposed to have delivered the new PCB to the house yesterday, but no package was left. Now I'm scrambling to get replacement boards or find out where the USPS delivered them to. I'll let you know as soon as I have more information. Sorry for the delay.
10-27-2021, 07:09 AM
#116
Richmond
, Kentucky
Marketing is not my strong suit either! However there are many forums where people have asked about where to find these modules. I've listed a few below. There are three part #s for this module, 10052954, 10052955 & 10052973. I think each is a revision of the original.
I Hate Mud forum
GM Truck Club
GearHead EFI
67-72 Chevy Trucks
I would suggest starting by listing them on ebay with the following header "GM fuel control module 10052954 10052955 10052973"
You never know until you try
No worries. I've got more then enough to keep me busy for the rest of my life
10-27-2021, 01:31 PM
#117
1992 36' Land Yacht
Grayson
, Georgia
I Hate Mud forum
GM Truck Club
GearHead EFI
67-72 Chevy Trucks
Thanks for the suggestions on marketing. I'll give it a try.
As for your module, since they needed to produce a new batch to replace the one in the mail, I decided to make a new design just for your needs. Here's a pic of the board.:
Notice that there are no provisions for the edge connector that's used by the OEM housing. Figured I could save space and make a more secure connection using just through holes for the wires. Should arrive in a couple of weeks. One good point of the newest design is that, because it's a slightly smaller board footprint, it was less expensive to produce. Should have named it Rev: Brad.
10-27-2021, 07:05 PM
#118
1992 36' Land Yacht
Grayson
, Georgia
The Brad board has been sent to the fabricator. Should be ready in a week. Now I have two options for those that have or don't have an existing module box.
11-01-2021, 10:07 AM
#119
Richmond
, Kentucky
I have to admit, I've never had anything named after me before
I guess there's a first for everything!
11-09-2021, 05:50 AM
#120
1991 25' Airstream 250
Oxford
, Oxfordshire
Without going too off topic, what is the best approach for me to try and find a spare/matching ECM for my 1991 250? It feels like a good spare to have on my travels.
