07-14-2020, 09:10 PM
#1761
Walnut Creek
Feet on floor - easy solution. Foot stool in front of the toilet. We found one supplied by a medical supply company. Believe it's posted here, but any wide step stool/platform that's about 4-6 inches high will work.
https://www.airforums.com/forums/f44...3d-157080.html
07-15-2020, 03:59 AM
#1762
Sag Harbor
, New York
Or raise the floor? Not sure if your floor plan will permit, but in our FC20 this was a fairly simple fix.
https://www.airforums.com/forums/f44...or-209979.html
[Rough draft prototype]
This "ablution solution" works for us.
YBMMV
07-15-2020, 10:14 PM
#1763
2019 23' International
Portland
, Oregon
Originally Posted by OTRA15
Yeah. I guess I can build a box to go there and put some sheet flooring on it. Inelegant but...
2019 International Signature 23FB "Cecil"
2020 RAM 1500 Laramie
Former coach: 2015 Bambi 16 "Beanie"
07-17-2020, 09:38 AM
#1764
Missoula
, Montana
I am about to upgrade a 2016 23FB FC to 15 inch Sendel wheels and GYE 225/75R/15 tires.
Just wanted to make one last query to the group before I purchase the tires to confirm that these tires will work and whether they require any trimming of the fenders.
Anyone with experience making this upgrade?
Thanks!
Randale
07-17-2020, 04:24 PM
#1765
Walnut Creek
https://www.airforums.com/forums/f46...fc-160321.html
That link talks about your change. No problem with our '15, but a fella who did the change on a 23D had to trim a bit. We used the 235s and the 225s should have more clearance. Pat
07-17-2020, 05:00 PM
#1766
2015 23' Flying Cloud
Copper Hill
, Virginia
Yah. I guess I can build a box to go there and put some sheet flooring on it. Inelegant but...
Here’s what I did for the wifey. Made her happy and that’s what matters.
07-18-2020, 05:41 AM
#1767
Missoula
, Montana
Originally Posted by PKI
Thanks for the feedback. I had seen that discussion before. Just wanted to make sure no problems have arisen since the original post.
Randale
07-18-2020, 07:57 AM
#1768
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Our 2015 23D worked just fine with the 15" Michelin tires and SenDel wheels. The leading edge curb side was not cut to the same dimension as street side so a little trimming was necessary. We have about ⅜" clearance from the timed edge. Any bumps and the wheel moves both back and up due to the trailing arm suspension.
07-18-2020, 08:16 AM
#1769
2010 23' FB Flying Cloud
Canmore
, Alberta
Thanks!
Randale
I changed over with exactly the same set up and there were no issues.
07-31-2020, 06:18 PM
#1770
Portland
, Oregon
Place to put my glasses
08-01-2020, 12:44 PM
#1771
Wolfwhistle
Margaritaville
, Banana Republic
Right you are. How about DIY for about $10
WW
08-01-2020, 12:56 PM
#1772
Wolfwhistle
Margaritaville
, Banana Republic
I’ve always thought the brushed panel on the fridge looked, well... off a bit, color wise. Took it off and found out the protective film was still in place. Kind of hard to get it and the 8 year old adhesive off, but did and it looks better. It does have a small divot on it, that I didn’t do. My story stickin to it. That’s all I have to report from way-too-hot-north-FL today. Oh, other than I’m ditching the Wingman antenna to add another solar panel. Looking at something with WiFi extender and possible cellular router all-in-one. To put either up front center or on top of the a/c shroud.
WW
Is taking it all with you, really getting away from it all?
08-02-2020, 11:20 AM
#1773
Portland
, Oregon
I keep finding these. What are they?
08-02-2020, 07:08 PM
#1774
2017 23' Flying Cloud
Bartlett
, Tennessee
I believe those cover the end of the hinges for the cabinet doors. I put them back on, but I don't know if they actually have any benefit.
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
08-02-2020, 07:11 PM
#1775
2007 22' International CCD
Corona
If they go on the part of the hinge furthest from the door itself, they help keep the hinge parts from separating under heavy vibration whilst traveling.
08-02-2020, 11:03 PM
#1776
Portland
, Oregon
Aha. Maybe that’s why my hinges are failing.
08-06-2020, 01:20 PM
#1777
Wolfwhistle
Margaritaville
, Banana Republic
I removed the crank up antenna. This is a DIY aluminum plate and entry port w/cable glands to replace the old base. One cable will feed the OTA antenna; the other is for a cell booster cable. That will be located just behind the rear vent cover. The new 360 antenna behind that and over the existing radio antenna hole. Two solar panels are being added, one sideways behind a/c the other behind that down the curb side.
FE
08-08-2020, 09:08 AM
#1778
Portland
, Oregon
What exactly is the point of the 1000w inverter? I ran a 680w coffee maker for one pot and watched my battery drain very rapidly. I should have done the math first, obviously 680w is gonna pull 65a or so. So beyond vacuuming the floor and watching tv (which we don’t do) I can’t see a reason to have it. 1000w is way more than the batteries can support.
08-11-2020, 01:02 PM
#1779
1976 Argosy 20
2019 25' Flying Cloud
Escondido
, CA
This is really a great idea. Did you use an 8020 vendor, or did you purchase direct?
08-11-2020, 01:35 PM
#1780
Sag Harbor
, New York
Making coffee with electricity when the propane tanks can heat many gallons of water with ease?
"Keep It Simple, Stu . . "
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
