09-12-2010, 09:34 AM
TeddEBear
1972 31' Sovereign
Hamilton
, Ontario
Bent Leveling Feet
Howdy All!
New member here...and sure I am going to have a pile of questions.
My 1972 31ft sov has crank down leveling feet. The two on the "front" or door side of the trailer are bent.
Is there a way of repairing these or am I better to replace them?
Any idea on cost of replacement?
Thanks for any and all advice.
Ted
Edward (Ted) Strauch
Hamilton, Ontario,
Canada
1972 31' Sovereign
09-12-2010, 09:40 AM
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County
, Ohio
stabilizer feet
We were just at the Mother ship, factory/store and they were only about $10 each. Don't know what shipping would cost.I think you can hammer them out if you have the time and tools too.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
09-12-2010, 09:50 AM
2002 25' Safari
Dewey
The stabilizers are made by BAL and the ones for an Airstream have an extended shaft. They sell for around $50-$60 each. I would try and straighten them first, it could save you some money.
Richard
09-12-2010, 10:10 AM
1989 29' Excella
Lorain County
, Ohio
clarify
Are just the flat, round feet bent or are the whole stabilizer arm assemblies bent too?
Larry and Lou
Air #2695
TAC- OH 2
09-12-2010, 10:32 AM
Corona
Originally Posted by TeddEBear
Howdy All!
Ted
Ted.
Posting a photo, will get you better help.
09-12-2010, 12:05 PM
Jupiter
Just a side note: the crank down levers are 'stabilizing' props, use your tongue jack and drive-on boards to get level and then drop the arms to snub most of the wiggle of walking etc.. The crank-down arms were not meant to lift weight off the axles blah blah blah...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
09-12-2010, 04:25 PM
TeddEBear
1972 31' Sovereign
Hamilton
, Ontario
Thank You All for the advice and ideas.
I am not sure of the formal name for the part in question.
They are the crank down arm with feet on the bottom that are located in the four corners of the under belly. The part in question is not part of the towing assmebly at all.
Hamilton, Ontario,
Canada
1972 31' Sovereign
09-12-2010, 05:42 PM
1974 Argosy 26
Morrill
, Nebraska
Not intended to level your trailer
These devices are only intended to stabliize the trailer, they are not leveling jacks. They are to keep the trailer from rocking around as you move around on the inside.
09-12-2010, 06:14 PM
Oswego
As Andy said, pics would help. I'd pull them off and take them to the bench and straighten them, clean them good, inspect for any cracks after the straightening, paint them up if necessary, lube the screw and pivots with silicone spray, remount, and go camping!
09-25-2010, 08:01 PM
1973 31' Sovereign
raleigh
, North Carolina
same thing with 3/4 of mine from PO. I may try to straighten mine and if it doesn't work, I'll buy new from Out of Doors mart. I may weld in reinforcement if they straighten out well, but it may be a good failsafe for it to bend before lifting at that point and causing damage.
09-25-2010, 08:12 PM
1970 27' Overlander
Espanola
, Full Timer
We were making a quick move one time and one leveler was still down, and it bent it towards the back. I freaked out needless to say. But the next day I climbed under 'THAR' and unscrewed the whole enchilada and we took it to a friend that had a vice (if needed) and a good sledge hammer. He straightened it out in a matter of minutes, and we brought it home and re-installed it and it works, but not as good as before...but it works. and I swear from now on I make darned sure those little 'boogers' are raised before any more moves are made!
The crank-down arms were not meant to lift weight off the axles blah blah blah... __________________
I agree! Blah -blah - blah!
09-26-2010, 08:04 AM
2008 22' Safari
Oracle
Been there done that. Once bent and straightened they are weakened and never the same. Several years ago I bought some on e-bay, they were $75 for two plus shipping.
09-26-2010, 09:51 AM
Pittsfield
, Maine
You can purchase new flat bars from Bal at a fairly reasonable cost - as I recall - having done so just after bringing my trailer home for the first time (2003). Straightening is possible - but once the bars have been bent excessively they'll never be as strong again. On the other hand, if care is used when stabilizing the trailer, the repaired bars may be perfectly adequate. I'll admit to being somewhat persnickity sometimes - taking out 1/8 of a bubble on the high side using the stabilizers - but this only requires a slightly higher force than normal on the crank - and certainly not enough stress on the bars to cause any deflection.
Cracker
