Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 08-04-2018, 07:49 AM   #1
2014 25' Flying Cloud
Mount Dora , stevenwilliams
SeeLevel II Tank Monitor problem
Our 2014 25FB SeeLevel II tank monitor started showing an “err” message for fresh water and sometimes an “opn” message. Garnet tech support ran me through some diagnostics and said my sender was probably in need of replacement. Then it started working properly again. Then I started getting error messages again
Today, the freshwater is working properly and the gray and black tank are both showing “err” messages. Since the company is closed this weekend, I thought I would put this question out to see if anyone has overcome this problem.
sburrw is offline   Reply With Quote
Old 08-04-2018, 12:11 PM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Seems unlikely that all three senders are going bad simultaneously. I'd double check the wiring on the back of the display, especially the common neutral wire, which could cause an intermittent problem like you describe if it has a short. Per the installation manual, it's very important that the senders and the display are connected to an identical neutral, so all the wires should converge into the display harness a few inches behind the display.
TheGreatleys is offline   Reply With Quote
Old 08-06-2018, 07:02 AM   #3
I took your suggestion and yes, the wires are securely attached to the back of the monitor. The Monitor displays the correct voltage of 13.1, but when I use my meter on the two wires on the back of the monitor, it reads 11.7 V. That seems strange.
Old 08-17-2018, 04:35 PM   #4
I ordered a new monitor panel from the company and installed it today. That did the trick!
Seelevel II Tank monitor- reads 0 for Black tank waninae39 Electronics & Connectivity 2 08-07-2020 04:00 PM
SeeLevel monitor wbrisett Electrical - Systems, Generators, Batteries & Solar 1 06-17-2017 07:12 AM
SeeLevel II Battery Monitor Teton Stream Electrical - Systems, Generators, Batteries & Solar 5 02-05-2017 08:18 PM
Can you calibrate a SeeLevel Monitor? SeaLevel Plumbing - Systems & Fixtures 7 01-26-2016 09:20 PM
Seelevel 700 series monitor from Garnet Robo104 Electrical - Systems, Generators, Batteries & Solar 3 04-28-2015 06:35 PM
