Old 05-26-2017, 06:26 PM   #1
waninae39's Avatar
2017 22' Sport
NCR , Ontario
Seelevel II Tank monitor- reads 0 for Black tank
we have a new sport 22FB
the Seelevel II Tank monitor reads fine for battery, water and grey
However the it always reads 0 for Black tank
the manual has debugging notes, but nothing for a constant 0 reading regardless of tank level
has anyone seen this?
how do i debug/fix it
i called AS and they have no clue.
my closet dealer is a 7 hour drive (;
waninae39 is offline   Reply With Quote
Old 08-07-2020, 03:28 PM   #2
2018. Tommy Bahama 19’
Lusby , MD
I am having the same problem on a 2017 I just purchased. Were you able to resolve the problem? Thanks, Betsey
BetseyHF is offline   Reply With Quote
Old 08-07-2020, 04:00 PM   #3
2018 25' International
Slidell , Louisiana
The two most common issues are a loose wiring connection and a bad sensor. Neither is easy to fix. You can first temporarily swap the grey tank wires to the monitor board to test the board. If it tests good, you can partially drop the pan by disconnecting the sewer outlet pipe and removing the pan bolts. That will give you access to the sensor and you can use temporary jumper wires to test the sensor. If it works the wiring is the issue. It may be easier to run new wires rather than track down an issue in the existing ones.
Good luck.
SeeLevel II Battery Monitor Teton Stream Electrical - Systems, Generators, Batteries & Solar 5 02-05-2017 08:18 PM
Can you calibrate a SeeLevel Monitor? SeaLevel Plumbing - Systems & Fixtures 7 01-26-2016 09:20 PM
Seelevel 700 series monitor from Garnet Robo104 Electrical - Systems, Generators, Batteries & Solar 3 04-28-2015 06:35 PM
Tank Monitor Panel Reads E Jeepjunk4 Fresh Water Systems 0 04-15-2014 09:10 AM
Micro Pulse Monitor reads red when unhooked foqus Batteries, Univolts, Converters & Inverters 11 11-03-2009 09:34 PM
