Old 08-17-2018, 02:10 PM   #1
ghaag's Avatar
2014 30' FB FC Bunk
2007 25' Safari FB SE
Jonesboro , Arkansas
Needing help figuring out the correct AC/Heat Pump to order
I am trying to replace the heat pump in my 2007 AS Safari. I contacted Dometic and they say the need a model number, and I do not seem to be able to find what they need. I am hoping someone has already been down this road and might be able to help me. I am attaching a roof shot of the unit, the only label I can find on the inside of the unit and a picture of the thermostat in case any of these might be helpful. I am wanting to install a new 13,500 or 15,000 unit.
Thanks in advance,
Greg
ID:	320130   Click image for larger version
ghaag is offline   Reply With Quote
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
I need help with naming a part and figuring out how to use it. jgermano General Repair Forum 2 02-02-2014 08:52 PM
Solar - help with figuring out panel voltage ddruker Generators & Solar Power 9 01-10-2013 04:46 PM
need help figuring out a tow vehicle! sunshine127 Towing, Tow Vehicles & Hitches 21 05-25-2012 11:14 AM
