Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 04-21-2019, 01:30 PM   #1
2017 19' International
2018 25' Flying Cloud
Monrovia , California
Interior shower delamination 2017 CCD 19'
In the shower there is a piece of the cabinetry melamine that fills the gap between the shower board and the shower door. This material is water resistant but not water proof. This is just below the shower faucet. This is delaminating and I need advice on how to repair. Still under warranty but I would rather DIY or take it to a formerly certified AS repair facility. Pics show the area the MFG caulking job and the delimitation.
Kay0 is offline   Reply With Quote
Old 04-21-2019, 01:35 PM   #2
Pics
opps! missed the upload button.
ID:	338758   Click image for larger version
Old 04-21-2019, 02:35 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I repaired mine after about 7 years of use. Had a local shop cut and laminate a new piece of plywood to fit using the old one as a template.
These days there are some composites out there that you could look into as well.
The other option is to call customer service and see if you can work directly with them to ship you a new divider wall. It’s easy to remove / replace - just some caulk and a few screws.
wulfraat is offline   Reply With Quote
Old 04-21-2019, 03:06 PM   #4
Thanks I’ll try CS!
Old 04-23-2019, 08:11 AM   #5
CruizinDux's Avatar
Washington , Missouri
Not delaminating yet but monitoring. Just re-caulked the bottom horizontal seam to eliminate low spots that tended to accumulate water.
Not that this is the answer, but maybe the direction when it is time to replace the trim piece.
https://www.certainteed.com/trim/gre...w-trim-accent/
CruizinDux is offline   Reply With Quote
Old 04-23-2019, 05:18 PM   #6
CruizinDux's Avatar
This is what i was thinking of but could not remember the name
https://azekexteriors.com/products/t...ards/trimboard
Add the cost of a one time blade to get diwn to the AS compondnt dimensions.
Old 04-23-2019, 06:16 PM   #7
2002 19' Bambi
Lafayette , California
When we bought our 19' trailer new in 2002, I looked at that part of the shower and decided it was not watertight enough for me. I filled in the space with light plywood so that it's flat between the fiberglass wall and the door. I then used easy-to-cut, 1/4" foam vinyl sheet (Sintra Board is one brand) to cover that area and caulked it thoroughly. It is still in place, looks perfect, and has never leaked or warped.
Tim
Tim A. is offline   Reply With Quote
Delamination under shower 2018 FC 30rbt sb55 General Repair Forum 12 09-26-2020 08:43 PM
LY fiberglass side delamination Santart Land Yacht/Legacy Motorhomes 27 11-26-2012 04:15 PM
Delamination repair flashgrbiv Upholstery, Blinds, Walls & Interior Finishes 1 12-27-2008 05:46 PM
delamination fixes ? myfirstrv General Motorhome Topics 6 12-22-2006 07:53 PM
Ceiling Delamination gunworks Land Yacht/Legacy Motorhomes 4 10-19-2006 11:55 PM
