Old 01-17-2018, 07:32 AM   #1
sb55's Avatar
2018 30' Flying Cloud
South Hero , Vermont
Delamination under shower 2018 FC 30rbt
Bummer. Only one week camping and the laminate under the shower is buckling. Wife and I haven’t been on full hookups so have been taking navy showers. We have never seen water on the floor. This happened yesterday and this morning I noticed some amber water on the shower floor. Maybe glue is leaking out? Anyone else have this?
Btw, it’s been cold so heat has been on. I think that the duct runs right along this area so maybe heat is to blame? Click image for larger version
ID:	302569Click image for larger version
sb55 is offline   Reply With Quote
Old 01-17-2018, 09:07 AM   #2
Living Riveted since 2013
Rocinante's Avatar
2016 Interstate Lounge Ext
Winter Garden , Florida
Given the model year, you’re probably under warranty. Have your dealer take a look.
Rocinante Piccolo is our 2016 Interstate Lounge 3500 EXT
Old 01-17-2018, 09:20 AM   #3
dznf0g's Avatar
Oswego , Illinois
That is a very common area for shower water to escape the lower seal and run down th face. IMO, it has nothing to do with heat and/or condensation. Poor door design.
-Rich-
Old 01-17-2018, 09:26 AM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
I noticed a stain in the same area in my 2002 Classic purchased in 2014. It is wood, so no delamination, but I took a look at the shower door design and it looked like there was a path for water to escape. I ran some beads of silicone around the hinge pin to keep the water confined. So far, no more leaks.
In your case, get the delamination fixed under warranty and see that they do something to prevent leaks in the future.
Al
2013 Ram 2500 Laramie 4x4 Megacab Cummins
Old 01-17-2018, 09:31 AM   #5
bavarian cloud
2017 30' Flying Cloud
Leavenworth , Washington
Bummer, when I got my 2017 I saw some water from the shower running down that verticle face in your photo and onto the floor. I was never able to tell for sure where it came from, but I suspect when the door frame was assembled it was not appropriately sealed where the vertical frame pieces meet the threshold and water leaks off the outer edges of the threshold then finds a route downhill. That route probably varies from trailer ro trailer. in your case it may have soaked the trim piece, causing the delamination. I decided to trying using clear silicone aquarium caulk to seal up both ends of the threshold which seems to have worked. The only water I get now seems to come over the threshold when I open the door to get out of the shower which we quickly clean up. BTW, if you open up the panels under the closet you can get a partial look under the shower. Check that out to see if you see any water from that perspective. Good luck with your troubleshooting!
basaltfan is offline   Reply With Quote
Old 01-17-2018, 09:37 AM   #6
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi sb55,
We're sorry to learn about the issue you described in your 2018 30' Flying Cloud. Please call our customer service and technical support team at*1 (877) 596-6111, option 2 so we can learn more and help.
Thanks.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 01-17-2018, 09:38 AM   #7
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I had the same problem (minus the delimitation).
http://www.airforums.com/forums/f44/...er-172797.html
After very careful inspection of the shower framing I took it upon myself to fix the issue myself.
The root cause (I had to dismantle the shower frame on my 2017 to determine root cause) is that airstream do not adequately seal the frame, the sil / threshold and the various joints.
The discharge you see in your shower will turn dark brown soon in is actually rust which you will see in my pictures - which comes from a small screw behind the frame that holds down the sil to the plywood framing.
Water gets behind the frame on the sil at the bottom corner of the door and can then leak out damaging the plywood that the aluminum sil sits on (you are seeing the effects of this as a delimitation problem).
The solution is a lot of clear silicon caulk.
I re-calked both sides of the shower frame/fiberglass and frame/sil junction from the outside. I then removed the lower screw in the framing (accessible from inside the shower, pictured just above my finger in the attached picture) that holds the door to the frame. I then injected A LOT of silicon own into the frame structure, allowing it to accumulate inside the frame at the bottom, further sealing the area from the inside.
Below is a picture of the silicon product you will want to use. I chose the clear version (one in the photo is white). Available at Home Depot. I have photos of the repair and somewhere... I will try to find them for you.
I did not trust the dealer to perform this repair to the quality / level of satisfaction I was looking for.
In the end it took me about 4 hours to take things apart, find the problem, determine the solution, re-assemble and then caulk the framing.
ID:	302575   Click image for larger version
wulfraat is offline   Reply With Quote
Old 01-18-2018, 05:35 AM   #8
GLCMRANGER - Sue
2016 25' International
Littlestown , Pennsylvania
This situation happened to me. I scheduled appointment at Jackson Center. The shower bottom tray is NOT tilted at an angle for water to go back inside shower. So, water is soaking inside the wall. JC replaced the ENTIRE front wall, new shower door! All done under warranty........ no leak since. Don't bother trying to caulk....... it won't work.
glcmranger is offline   Reply With Quote
Old 01-18-2018, 03:55 PM   #9
zapper's Avatar
2007 25' Safari FB SE
Highland , California
Sorry to hear of your shower troubles in your new trailer. But glad to see the post on this subject. Have experienced similar leaks in both our 25' FB and our 2017 RB 30' FC. Have not observed leaks on the inside of the shower as in the pictures, but on the outside of the shower. No delamination in either AS. Like others I assumed that it was from opening and closing the shower door after a shower. On the 25' I replaced the seal at the bottom of the shower door with a heavier duty silicone wiper seal and overlapped the door hinge at the end. That seemed to fix it. The 30' shower door I will have to look closely in the area to see where the leak is coming from and will report back later.
zapper is offline   Reply With Quote
Old 02-12-2018, 04:09 PM   #10
Okstreamer
Yukon , Oklahoma
Keep the water in the shower
I found that caulking was not the answer, too much movement and expansion and contraction in a travel trailer. The water that hits the shower door just lands on the threshold and the corners always leak. I just installed a shower door gutter and that solved the problem. All the water that hits the door lands in the gutter and the gutter drains into the shower not on the threshold.
Pictures attached to show what I am talking about.
ID:	304149   Click image for larger version
okstreamer is offline   Reply With Quote
Old 02-12-2018, 04:32 PM   #11
Baby Zeppelin's Avatar
2018 28' Flying Cloud
Clayton , Georgia
Our dealer also installed a shower gutter, but it's under the door, not on the door, also drains back into the shower.
Clever tech adapted exterior trim molding for interior use. Haven't used the shower since the work was done, am hopeful that it'll head off problems caused by the wall getting wet beneath the door.
Baby Zeppelin is offline   Reply With Quote
Old 09-26-2020, 06:25 PM   #12
2007 30' Classic S/O
2013 28' International
2006 25' International CCD
seaford , Delaware
shower door gutter
where can the gutter in the picture be purchased. thanks jack
claymanjack is offline   Reply With Quote
Old 09-26-2020, 08:43 PM   #13
2017 28' International
Jim Falls , Wisconsin
This is why my next project will be to install a Nautilus shower door that retracts. I’ve never liked the AS shower door.
Daquenzer is offline   Reply With Quote
LY fiberglass side delamination Santart Land Yacht/Legacy Motorhomes 27 11-26-2012 04:15 PM
Exterior delamination repairs gloran Land Yacht/Legacy Motorhomes 6 02-15-2009 05:51 AM
Delamination repair flashgrbiv Upholstery, Blinds, Walls & Interior Finishes 1 12-27-2008 05:46 PM
delamination fixes ? myfirstrv General Motorhome Topics 6 12-22-2006 07:53 PM
Ceiling Delamination gunworks Land Yacht/Legacy Motorhomes 4 10-19-2006 11:55 PM
