Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 10-01-2014, 07:19 PM   #1
'06 75th Winick Prototype
2006 19' International CCD
1968 22' Safari
The Swamps of Hell , Lousy-Anna
WARNING! Check your brake wiring...
Hi everyone...
I recently got home from a trip from Louisiana up to the Hocking Hills/Old Man's Cave area of Ohio. The road to the campground is just a few miles long, but staggeringly steep for Ohio (of all places); while going up and down those short steeeeep hills my brakes started acting strange on my 19ft Bambi.
The Prodigy brake controller in my SSR started to show "n.c." meaning "no connection" about 75% of the time whenever I would touch the brakes; when I would let off, it would show "c." for "connected" meaning that the controller knew it was connected, but that there was a fault in the system somewhere.
The brakes would either not work at all or would slam on like a freight train was pulling the back of the trailer.
At the campground I got my fat self under the trailer (at night of course) where I was laughingly attacked by about 100 daddy long-leg spiders (the feeling of one sheepishly walking across your face as you're holding a hot soldering iron is something to be experienced) and I was shocked to find that the curbside brake wires were crimped, but the factory heat-shrink tubing was literally never actually heat shrunk...and while merely touching the wires, the ground wire literally came apart in my hand where they were half-heartedly and clumsily crimped together. Of course, the unshrunken heat-shrink tubing fell off the wire when the wires broke in half. The positive wiring was done the same; i.e., haphazardly crimped, with the loose heat-shrink tubing loosely dangling on the wires but never actually applied to the crimped joint. So, I dug out the aforementioned soldering iron and re-connected the two wires properly on the curbside. I gladly then used the previously unused heat-shrink tubing supplied by the incompetent Airstream worker (who didn't bother to do his job) to now protect the newly properly soldered wire connections...then I wrapped both with a generous supply of black 3M electrical tape just to be safe.
But...when I checked the roadside connections, they WERE crimped satisfactorily, and the heat-shrink tubing WAS properly shrunk on the wiring protecting the crimped joints, but to my amazement I found another problem...the wiring was sheepishly kept in place by plastic tie-wraps supplied by Airstream which were still in place (on both sides), but enough play was left in the wiring by the shock so that one of the two wires on the roadside actually chafed itself enough so that it was shorting out against the metal shock housing. I was tired of being molested by spiders, so I didn't take apart and solder the roadside connections (they seemed fine and were actually properly crimped) but I did use a generous amount of the 3M electrical tape to protect the chafed area. I then promptly checked the wiring on both sides to be sure there wasn't too much play in any of the wires so that neither side could contact the shock housings and short out...but it looks SUPER easy for the wiring to do just that. There is a fine line between not enough play and too much to cause a potentially very bad problem. And, it's clear that the factory couldn't care less to check such things...
So...get out there and just check your brake wiring to be sure they are properly connected to the actual trailer brake magnets but more importantly make sure there isn't too much play in your wiring that can cause wire chafing and breaking that will immediately lead to a total loss of trailer brakes...
Even on my small trailer it was a bit of a jarring experience to suddenly lose brakes when I needed them most...
Once corrected my brakes work perfectly...
Better be safe than sorry!!!
ggoat!!! is offline   Reply With Quote
Old 10-01-2014, 10:22 PM   #2
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
Great advice to check the brake wiring. I actually found the wires to one of my wheels disconnected last summer during a routine inspection. I chose to not solder mine and leave just the simple connectors in hopes that if I snagged a rock or stray something it would simply pull loose rather than pulling the wire out of the hub.
I do have a question. The wires coming out of the hub in my new Dexter axles are simply two black wires. Can't tell from positive and negative. Are yours clearly marked that way? Reason I ask is that I'm currently chasing a problem with my beak-away switch (brakes work, break-away is being stubborn).
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Old 10-02-2014, 01:55 AM   #3
1968 22' Safari
Hi Jim...
No, trailer brake magnets can be wired either way; there is no defined "positive" and "negative." Just make sure they don't short together.
In my anecdote above, I merely specified the troubled wires because those were the chassis wires leading TO the brakes, and of course those ARE positive and negative. But, to which magnet wire you respectively attach each to makes no difference.
Hope this helps!
Jeff
Old 10-02-2014, 05:13 AM   #4
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I had something similar happen on my tow dolly once - the brake wire shorted out. I discovered the problem while I was on the road, but I wasn't able to fix it on the road, even temporarily (the short was inside the frame of the dolly). So I drove home for the next 5 hours very carefully, not knowing whether I was going to have dolly brakes from one light to the next. Quite frustrating.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 10-02-2014, 07:50 AM   #5
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I have had several problems with brake wiring - usually wires corroded off at the connectors, but in at least one case of a wire broken by being snagged on something or hit by road debris.
I have replaced faulty connectors with soldered joints and shrink tube - although I know that there are pros and cons to this.
Now, I regularly visually check brake wiring ay time I have reason to be poking around under the trailer.
Also, any time I have the trailer up on a jacks, I spin the free wheels and have my wife apply brakes just to confirm operation. A regular north pointing compass held against the wheel will also at least confirm that the magnet is being powered.
Just a couple of weeks ago, while doing a bearing repack, my spin test confirmed one wheel not braking, turned out to be a faulty connection at a previous wire splice
The truck brakes are large and effective and I hadn't realized that one wheel on the trailer was not braking.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 10-02-2014, 06:04 PM   #6
Originally Posted by 75TH BAMBI View Post
Hi Jim...
Hope this helps!
Jeff
Thanks Jeff. That's what I thought, just makin' sure I didn't miss a step somewhere.
www.nesa.org
Air No. 6427
Old 10-03-2014, 12:33 PM   #7
2004 16' International CCD
Chicagoland , Illinois
First - that sounds like a scary situation (especially the spiders). I'm glad that you nor your trailer weren't injured. It sounds like poor quality control has run amok.
You're fortunate to be so handy. This could have been an expensive surprise for a less electromechanically-inclined owner.
I'll be spending my evening checking out my brake wiring (hopefully without the spiders). Thank you so much for sharing this information.
Airrogant is offline   Reply With Quote
Old 10-03-2014, 12:49 PM   #8
Tyvekcat's Avatar
2014 28' International
Blacksburg , Virginia
brakee
Brian
Holy Crap, I am going to check mine tomorrow. Thanks Brian.
I have a compass here somewhere. Do you have the wheel off and have to get the compass super close? Or can I just be at the back-plate?
I appreciate the information.
Have a good one,
Ra & Chelle
For my next trick, I will use my new AS & Dodge Ram CTD to make this pile of money disappear.
Tyvekcat is offline   Reply With Quote
Old 10-04-2014, 06:43 AM   #9
Wingeezer's Avatar
2005 30' Classic
Have a good one,
I just hold the compass near to the location of the magnet (bottom of the brake assembly) with the wheel in place. I hold the compass at the outside face of the wheel, not the backing plate. If all is well, I get an unmistakable swing of the compass needle when the brakes are applied.
When I first tried it, I told my wife to tread on and off the brake while I checked, but found there is a slight lag before the compass needle reacts, so I found it better to have her just hold the brake down on my signal until I determined there was magnetism, and then tell her to release and I go on to the next wheel.
We do this with a pair of GMRS radios and that makes it easy. (At least it would if I could get my wife to understand that she needs to press the button on the radio before she starts to talk!)
Brian.
2005 Classic 30'
Old 10-07-2014, 02:37 PM   #10
'Nuther question. When I have Susan push the brake pedal in the truck I can hear a definite humming of the brakes at each wheel. When I pull the breakaway chord, don't hear that same sound..
Is it possible that the breakaway switch somehow uses less braking power when engaged? As in a "just enough" scenario of some kind? I have a separate thread on this subject from a month or so ago, so I don't mean to high jack this thread, but you all seemed plugged in to braking so to speak.
www.nesa.org
Air No. 6427
Old 10-08-2014, 06:44 AM   #11
Wingeezer's Avatar
2005 30' Classic
Not 100% sure of this but I don't think the breakaway circuit would be set up to apply some minimal braking - given what it is intended for I would expect it to apply maximum braking.
Possibly your breakaway switch is defective and even when you pull the pin, the switch contacts are not closing?
Would be worth checking a wheel by spinning it after you pull the breakaway pin - or maybe just trying to move the trailer with the pin pulled to verify that the trailer brakes are on.
Interesting that you hear a humming sound from your brakes when you apply them from the tow vehicle. I have never noticed that from mine - but never really listened that closely I suppose.
I would have associated a humming sound with an AC circuit (the same way a transformer will hum) rather than the DC current that is applied to your brake magnets, so I'm not sure what would cause the noise - unless it somehow relates to the type of brake controller that you have in the two vehicle. Perhaps others know the reason for the humming?
Cheers ........ Brian.
2005 Classic 30'
Old 10-08-2014, 07:00 AM   #12
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I need to check my brake lines so thanks for the heads up.
For what it's worth, I always check the operation of my brakes each time I pull the trailer by simply squeezing the brake controller buttons to manually engage the brakes as I am pulling away from the campsite. A gentle tug from the trailer brakes assures me that the trailer brakes are working (they are more noticeable during this test since the truck brakes are not engaged so all the braking effect is coming from the trailer brakes themselves.)
Of course, this test does nothing to predict that a loose wire will let go during the tow hence the need to also check the wiring periodically.
Bob Martel
WBCCI# 5766
Old 10-09-2014, 08:22 AM   #13
hang up and drive
kry226's Avatar
2010 30' Classic
Carlisle , Pennsylvania
I also have had brake wiring issues so badly that I lost all braking during a trip. Luckily I was in a parking lot at the time. I make a habit of carrying tools when I travel and had butt connectors to repair the wires there in the lot. The problem was that the wires looked good but were corroded inside the factory connectors as mentioned above.
When I got home, I bought all-weather shrink tubing butt connectors for a more permanent fix.
Kyle
2023 Ford F350 Lariat 7.3/4.30 FX4 CCLB
2010 Classic Limited 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 10-10-2014, 07:43 AM   #14
Wingeezer's Avatar
2005 30' Classic
Any reference info on those all weather connectors? Can they be bought at automotive stores such as NAPA or pep Boys stores? I wouldn't mind adding some to my "Emergency repair kit!"
Thanks ............ Brian.
2005 Classic 30'
Old 10-10-2014, 07:51 AM   #15
dznf0g's Avatar
Oswego , Illinois
Brian, they're readily available everywhere. HD has them even. Look for heat shrink connectors with hot glue in them. They both shrink to fit and the glue seals them.
-Rich-
Old 10-10-2014, 08:11 AM   #16
Wingeezer's Avatar
2005 30' Classic
Thanks Rich, will check our our local HD - although I often find that for some reason HD store in the US have a wider selection of products that we do here in Canada. That's OK though - will be back visiting the US this winter once more - all being well!
Brian.
2005 Classic 30'
Old 10-10-2014, 08:21 AM   #17
Chelsea , Michigan
Images: 12
Brian.
Winegeezer, surely you have been to Canadian Tire? Every time I go into one of those, I never fail to find what I want and a whole lot more!
Bob Martel
WBCCI# 5766
Old 10-10-2014, 10:37 AM   #18
1974 Argosy 20
Kooskia , Idaho
A general note on this thread. I also have had brake issues, electrical. Once I found that 3 of the 4 wheels had no working brakes, due to corrosion issues where the magnet wires connected to the brake wires.
The easiest way to check for good brake electrical is to measure the total current going to the brakes. It will be between 2.5 and 3 amps per wheel. So a single axel trailer should measure 5 to 6 amps, and a double axel 10 to 12 amps.
Just identify which pins on your cord which plugs into the tow vehicle has the 12 volts on it and which pin is the one for the brakes. Put an ammeter between those two pins and you will measure the maximum brake current.
Some brake controllers have an ammeter built into them, and you can read the current that the brakes take directly.
The Humming sound mentioned in one of the posts above when the brakes are activated from the brake controller is caused by a rapid on/off cycling of the power to the brakes by the electronics in the brake controller. Not all controllers operate that way, so it is not a universal thing you will find (humming). When the break away switch pin is pulled pure 12 volt battery power is applied to the brakes so no humming will be noted then.
The best wire nuts for brake use are the type which have an internal "goo" in them which keeps water out. They are designed for wet locations and underground splices. You can generally find them at Home Depot and Lowe's as well as a well stocked hardware store. Under no circumstances use regular wire nuts and fill the ends with silicone. That will eat the wires up really fast as the normal silicone acts as a corrosive to the copper. Also, do not tape the wire nuts with electrical tape as that only keeps the water which will get in, in, and will not allow it to drain out. Use the special wire nuts or crimp or solder connections covered with water proof shrink wrap material.
I hope this has added something to the thread of use.
Old 10-10-2014, 06:27 PM   #19
Originally Posted by idroba View Post
.......The Humming sound mentioned in one of the posts above when the brakes are activated from the brake controller is caused by a rapid on/off cycling of the power to the brakes by the electronics in the brake controller. Not all controllers operate that way, so it is not a universal thing you will find (humming). When the break away switch pin is pulled pure 12 volt battery power is applied to the brakes so no humming will be noted then.
Ah Ha! Now that explains why I'm not hearing the humming with the pin pulled. Man, what a relief. I've rewired several things around the 7way-to- brakes-connection with the same result--no humming.
Now all I have to do is jack the trailer up, pull the pin and spin the wheels to see if they are working.
Did you add something of use? Absolutely. One of the best posts I've read on the forums in a long time. Thank you!
www.nesa.org
Air No. 6427
Old 10-10-2014, 06:46 PM   #20
Wingeezer's Avatar
2005 30' Classic
Canadian Tire is indeed a great institution! I often wonder why there is not a US equivalent? If there is, I have yet to find it!
Not sure if they have these all weather connectors though - I haven't seen them there, but then, I have never asked! .......... I will!
Brian
PS - Wingeezer not Winegeezer (relates to my age + the motorcycle!)
I do make my own wine though, so I suppose it could be equally appropriate!
But these days, I make a lot more home-brewed beer than I do wine!
2005 Classic 30'
Warning! Birchwood. Warning!!! austreampete Commercial Listings 1 01-10-2004 08:04 AM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
