04-01-2016, 06:03 PM
#61
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
My center caps and stock rims corroded. I reused the center caps after cleaning them with the new 16" wheels. I just put them on so will monitor closely.
Btw, I also raised my hitch as the trailer was already slightly nose down with the 15's.
@living.somewhere.yonder | Instagram
04-01-2016, 08:27 PM
#62
2019 27' International
2014 25' International
Boulder City
, Nevada
MOUNTED and ready to roll...
Costco mounted my tires onto my new wheels today.;
I asked for 70#, but they did 74# pressure. Nitrogen.
I mounted them onto my trailer using leveling blocks and replaced one side and then the next, one in the air at a time. Break the lug nut loose on the ground, first. Then when the wheel is in the air, remove all six. Takes time, but you will survive. Gloves or no gloves... you get better after the first wheel.
I did not think about measuring the height at the fender well with the 15" and then the 16" wheels. I expect it to be higher, but how much I will not know.
Michelin LTX MS2 LT225/75R16- wheel and tire weigh about 61 pounds (bathroom scale accurate to within 1/2 pound)
Marthon 225/75R15- wheel and tire weight about 48 pounds
The Michelins took weights for balance: 0, 8, 9 & 10 (5Fe- 5 gram weights)
The Marthons took weights for balance: 5, 12, 12, 13 (25Fe- 1/4 ounce weights)
(I am not sure what 25Fe were. Costco said it was US equivalent to 1/4 ounce weights. These looked thicker, but how much, not sure.)
Someone might know for sure. The guy I spoke with did not convince me.
Of course you need to get the trailer axle higher to fit the 16" wheel, top of tire in first and slide bottom to fit under fender. After the first replacement you will know how many blocks are needed to have ground clearance to attach wheel to drum lugs. I had about 1" air space with wheel attached for floor clearance. Sit, straddle the tire, set top lug nut on drum UP CENTER, align wheel with top hole UP CENTER and... give it all you have.
Hand snug each lug nut by rotating wheel in air and equally tight. Then use breaker bar to snug them up. When wheel is on the ground, torque to whatever someone convinces you to do... 90# to 120#. I think 90# to 100# is very secure. I will check the lug nuts at each gas station stop on this first trial run.
The 15" stainless original center cap fit perfectly and no corrosion. Of course, I am in a different environment too.
The spare tire rack. I removed the 15" and slid the 16" spare onto the tire rack, hoping nothing else was needed. Wrong. The fit was a little loose for the 15", but not enough to fit the replacement wheel and tire. I took a hollow pipe that fits a floor jack, dropped it over one of the two 'side bars' that hold the tire in place. Bent outward, went to the other side and bent it outward. Just a little bending outward on each and the tire slid onto the spare tire rack and laid snug. I pushed the tire back as far as it would go and lifted... the heavier than you want to believe... spare upward and the pivoting latch was snug and I could get the pin and retainer pin through the holes with a little aligning with poor lighting.
The lug nuts sent with these wheels had a theft proof lug nut that takes a special socket. I used those and put the original lug nuts with my set of five 15" wheels and tires.
The next Boondocking Trip for us is May 9th, 2016 to Quemado, NM. I am very curious as how these tires handle, the extra clearance if noticed and anything else positive or negative.
I used my torque wrench and tightened the lug nuts to 90#. Possibly a bit more. By hand and a breaker bar... it was also about 90# without over doing it after checking it with the torque wrench. To loosen... it takes more than 90# as the torque wrench would click for 90# and it took a bit more effort to break the lug nut loose. Just For Your Information.
Human Bean
04-01-2016, 08:53 PM
#63
2006 25' Safari
Signal Mountain
, Tennessee
Ray, thanks. That is great info. I ordered my replacement wheels and tires from Performance Tire. They will ship mounted and balanced. I mentioned the $70.00 Costco discount for a set. I was assured that a $70.00 mail in discount will come with the tires. Good pointers about the spare tire rack. I have been concerned about that. It sounds like it will take no welding which is a good thing. What they tow and handle like will be reported later. Thanks again.
I also ordered a Cat 500 watt (1000 peak watts) jump starter with inverter and air compressor (up to 120psi) from Costco. The unit was priced at $79.00, but the freight and tax made it about $98.00. This was an internet special not available in our store. I will also let it be known how that works.
We are getting ready to actually go camping in the little darlin'.
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN,”Greenest State in the Land of the Free”.Davy Crocket
" America is not a place;it's a road." Mark Twain
04-02-2016, 07:45 AM
#64
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
The stock 15" GYM ST225/75R15D tires are 28.3" in diameter. The 16" Michelin LT225/75R16/E LTX M/S2 tire are 29.2" in diameter. The difference in diameters is 0.9" and raises the axles 0.45" or less than ½".
04-02-2016, 09:36 AM
#65
2002 30' Classic S/O
Fleming Island
Ray,
I have heard from multiple sources that you should initially check torque more often after mounting wheels and my experience would seem to confirm that. I think the recommendation is after 50, then 100, and finally 200 miles or at 50, 150, and 350 from start. I usually had at least one lug nut loose on each wheel after just 50 miles.
Al
04-02-2016, 09:53 AM
#66
Boulder City
, Nevada
I want to thank.... switz .... for providing those minute details that can get in the way.
After visually comparing the tire tread on my Michelin tires and the Goodyear Marathon tires... my thought... "You must be fooling yourself to believe these tires belong on a high end, expensive, trailer, like an Airstream."
Airstream, Jackson Center, OH is doing what many automobile companies are... putting low end tires on their new product and cooperating with the tire manufacturers who then can sell you 'better quality' tires after you pull off the lot.
Toyota 4x4 Tundra tires are no better. The spare is a steel wheel and a street tire, not even matching the four in use. I immediately replace the stock Toyota Tundra tires, buy Michelins and sell the stock tires on Craigs List.
I find it poor customer loyalty that even Airstream's spare wheel is a steel wheel and the lug nuts do not fit properly from the 'aluminum' wheels in use. Where on the final price tag is CHEAP spare tire? Then you begin to wonder about everything else, with the tires a very important part of a trailer.
The Michelins come with a 70,000 mile warranty. No doubt prorated for wear, but I expect these to be as reliable as all of my other Michelins on our 4x4 vehicles. Airstream and Goodyear are doing themselves a poor job of promoting their products. Not all consumers are fools... with or without discretionary money to throw at their recreation vehicles. Eventually, as on this Forum... owners are speaking out and not afraid to express an opinion.
I am reminded about my NOISY refrigerator fan that I paid out of pocket to replace. I am expected to tow my trailer to a dealership, spend my time and money to have them declare the original fan a P.O.S., return to having the fan unplugged, replaced with two screws, and Airstream charged for the flat rate warranty repair... that I did myself.
When members on the Forum like.... switz .... provide solid information, I am among friends.
Thank you switz.
Human Bean
04-02-2016, 06:14 PM
#67
2015 30' FB FC Bunk
Ayer
, Massachusetts
Just finished my tire upgrade today. Went from the stock GYM to the Sendel T03 16" rims with Michelin LT 225 16 R LTX/MS2. Definitely a big difference in beef from the GYM, at least visually.
I ended up cutting the fender wells, they were real close otherwise, the fronts more than the rear. That was pretty easy with the molding removed, used a Dremel with a 426 attachment.
I did 5 tires and rims, the spare is now equal to the 4 running tires so if I get a flat on a trip, I want to put on a new tire and not slow down. I am going to rotate the spare into the mix, I mounted the spare face down so I could check pressure while in the carrier.
The spare tire carrier modification took about 2 minutes, just bent out he stays slightly and it was no problem. It almost felt I didn't even need to modify them.
Added Centramatics and had everything spun balanced with my TPMS sensors in place. Inflated to 80psi.
I feel better now.
04-02-2016, 06:17 PM
#68
2015 30' FB FC Bunk
Ayer
, Massachusetts
PS - Airstream doesn't put GYMs on their trailers, YOU DO !!!. They offer a Michelin upgrade which was quoted to me at $2500. I said no and did it myself. So if I had a GYM failure on the road...it would have been my fault, not Airstream's neglect.
You get what you pay for.
04-02-2016, 07:22 PM
#69
2007 31' Classic
Barrie
, Ontario
Has anyone tried or even looked at the Sendel T03 wheel in chrome instead of the aluminum finish ??? Just wondering if the chrome version has a good quality finish and might not corrode as fast as the aluminum version. Have had other chrome wheels over the years and with a good coat of wax twice a year they held up real good on our salty Canadian roads.
Walter
04-02-2016, 07:30 PM
#70
2014 31' Classic
Apache Junction
Here are side by side 15" GYM on the left and a 15" Michelin on the right in the left photo and the 15 GYM on the left with at the 16" Michelin on the right in the right photo.
Notice that the 15" Michelin has a wider tire patch than the GYM as does the 16" Michelin.
04-02-2016, 09:16 PM
#71
2014 30' FB FC Bunk
Anywhere
Here are 15" GYM and 16" michelins.
04-03-2016, 05:00 AM
#72
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Originally Posted by Al and Missy
Ray,
Al
We did just that when we first picked up our trailer. 50, 100 and 250. Now every other day. Still, after 10,000 miles one lug on each wheel can be moved, I would not by any means call it loose, but it does move.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
04-03-2016, 06:38 AM
#73
2007 20' Safari
Old Orchard Beach
, Maine
I feel better now.
Which specific Centramatics did you use?
http://www.centramatic.com/wheel-bal...pe=Trailers-RV
Marty Womer
Old Orchard Beach, Maine
Trailer name: Quarantina
2019-2022 President, Northeast Mountaineers Airstream Club
04-03-2016, 10:07 AM
#74
2015 30' FB FC Bunk
Ayer
, Massachusetts
Originally Posted by MaineStreamer
I used the 200-221 Special.
After much debate and research, including a lengthy call the the manufacturer, that is what I chose. It is however, not you only option.
http://www.centramatic.com/wheel-bal...00-221_Special
The website is confusing by the way, these are under the RV section, not Trailer section.
04-03-2016, 10:21 AM
#75
2014 31' Classic
Apache Junction
We installed the larger diameter Centramatic 300-356 all A plates on our 16" tires.
04-03-2016, 11:25 AM
#76
2015 30' FB FC Bunk
Ayer
, Massachusetts
That was my first choice before I talked to them, but both options are good.
04-03-2016, 08:11 PM
#77
2017 25' International
Carlsbad
FYI
We just covered 200 miles today. The first trip on the 16s. I stopped to check the mMcGard
Lug nuts twice. Each time I was able to get a bit tighter to 110.
It's a good idea to check yours. Frankly, I did not believe it possible. 😮
04-03-2016, 08:17 PM
#78
Carlsbad
Btw, we were beat to death on
I - 5 north through Los Angeles.
I could not appreciate the wheels or Centramatics. 200 miles in 6 brutal hours. I'm looking for a different way home.
But no popped rivets.....
04-04-2016, 05:43 PM
#79
2013 31' Classic
billings
, Montana
Billings to Oceano , first trip for the 16" michelins, checked the torque 5 times, everything is rollin easy....
04-06-2016, 07:05 AM
#80
1994 30' Excella
alexandria
, Kentucky
Are the Sendel wheels clearcoated or raw aluminum? It seems that if they are not clearcoated then it would be a good idea to get this done before the new tires.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
