Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 09-29-2003, 01:11 PM   #1
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Tri Axle Question
I have read a lot of the comments on axle replacement posted here but have addional questions.
My 91 34 ft Excella has always sat very low to the ground. The factory ID plate shows 2,300# axles and a GVW of 8,900#. The math doesn't add up. While I had never weighed the trailer empty it does weigh in at 10,000#s for a normal trip. The axle arms do have a positive angle, the rear of a center line drawn through the arm is above a line parallel to the frame. This angle is about 10 degrees positive by eye.
My first question is what are other tri axle owners seeing as far a factory plate, trailer height when sitting level, and axle arm angle.
My second question. Has anyone changed out the axles on there tri axle and if so what axle rating did you use.
I have spoken to Airstrem with no result. and have spoken to Henschin with the results that they say the positive angle is OK but claim they never made a 2,300# axle.
With over 90,000 miles I thought it was time to look in things
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 10-17-2003, 07:48 AM   #2
stp2136
stp2136's Avatar
Profile:
I had a 1987 34' Excella that had similar ratings. The axles were 2800# each (totaling 8400#) and a gross weight rating of 8900# which implies 500# on the hitch. I suspect you have 2800# axles as well. If you really weigh 10,000# loaded you are way overweight!
stp2136 is offline   Reply With Quote
Old 10-17-2003, 08:11 AM   #3
RoadKingMoe
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
My axles are 3200# each for a total of 9600#. GVWR is 9800# which one might take to imply a 200# tongue weight.
However... with a 1100# tongue weight and 9800 lbs total weight, each axle would be carrying 8700/3=2900 lbs... IF, AND ONLY IF the trailer was perfectly level! If it's nose down, the front axle will be carrying more than the rear axle and vice versa. THAT's why the axles need to have a margin of extra capacity.
I'm not sure what's up with your trailer, but I find it interesting that yours is 8900 vs 9800 and 2300 vs 3200 with a transposition in the first two digits of each.
As I mentioned in private messages, my spindle centerlines are below the axle centerline, but that's with only perhaps 600#s on board. I'd believe they'd be closer to level with a full load.
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
Old 10-17-2003, 09:30 AM   #4
85MH325
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
34' tri axle...
I checked my trailer's info the other day for Howie. My '94 tri-axle has 2800lb rated axles and a gvwr of 8900 lbs. The dry weight on mine is 7100lbs. If you consider the tongue weight at the rated 800lbs, it leaves about a 300lb (roughtly 3%) margin of error in the GVWR of the axles before overloading.
Howie PMd me and discovered after the umpteenth time of checking his trailer that his axles are also 2800lb rated. Apparently his GVWR tag was just difficult to read, and the "8" looked like a "3".
Obviously the newer wide-body trailers are heavier than the older 34s, and need heavier axles for their heavier GVWR.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
2006 Bigfoot 25B25RQ towed by a 2001 Born Free 23RK moho
Old 10-17-2003, 10:34 AM   #5
RoadKingMoe
Beavercreek , Ohio
Re: 34' tri axle...
Good point, Roger. I'd forgot about the narrow/wide body difference when I saw the transposition.
Maurice
AB8XA
WBCCI 5446
Old 10-17-2003, 11:40 AM   #6
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
The 34 foot trailers had 2800 pound axles.
They can, in time, settle, causing a positive angle.
Generally speaking a positive angle, when loaded, means bottoming out will occur.
Replacement axles for the 34 foot trailer can be 3200 pounds, or if usually heavily loaded, they can be 3500 pounds each.
Different rating axles must never be used together.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Old 04-08-2004, 09:50 AM   #7
bake315
bake315's Avatar
Profile:  1994 34' Limited
Elgin , Texas
Images: 161
So, if I'm understanding this correctly, if I have an older 34' with 2800 pound axles in need of replacement, I can do so with either 3200 or 3500 pound axles, giving me a bit more leeway in terms of loading than I had previously?
Cheers, Dave
"Finish."
AIR #4188
1994 34' Limited / 2002 Chevy 3500 CC 4x4 D/A Equal-i-zer Hitch / Jordan Ultima 2020
bake315 is online now   Reply With Quote
Old 04-08-2004, 09:55 AM   #8
Commercial Vendor
Dave.
Absolutely correct.
Inlandrv.com
800-8777311
Old 04-08-2004, 10:00 AM   #9
bake315
bake315's Avatar
Elgin , Texas
Images: 161
Cool beans!
Thanks Andy!
Cheers, Dave
"Finish."
AIR #4188
Old 04-08-2004, 05:02 PM   #10
j54mark
Profile:
I thought the axle load rating applied only to what the axles carried, which would not include the axles themselves, while the GVWR is the whole load. In other words, even ignoring tongue weight the axles need only to carry the weight loaded upon them.
Or am I missing something?
Mark
Old 04-08-2004, 06:55 PM   #11
Commercial Vendor
What does that have to do with increasing, if desired, the maximum carrying capacity?
Lets keep this out of engineering theories, so as not to confuse the true issue of increasing weight carrying capacity.
Inlandrv.com
800-8777311
Old 04-08-2004, 07:06 PM   #12
Tarheel
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Andy after pulling my tri axel for 25,000 miles or more I finally got around to weight it. the truck weighs 7160 solo, 7880 with the trailer on it but trailer wheels not on scales and 16640 truck and trailer. My question is tongue weight I only have 720 lbs on the tongue of a 9480 lb trailer or 7.6% it rides level but should I shift some more weight up forward? Getting ready to make a cross country trip on the Southwest Caravan and want to be as safe as possible.
Rick
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 04-08-2004, 07:58 PM   #13
Commercial Vendor
Rick.
Tongue weight should be between 10 and 15 percent of the gross trailer weight.
By various tests, a 12 percent tongue weights seems to be the ideal.
A little more, or, a little less than the 12 percent is OK, but certainly no less than 10 percent or more than 15 percent should ever be considered.
Tongue weight can easily be adjusted by placement of the variable load.
Always travel with a "FULL" water tank. It helps the tongue weight, "AND," lowers the center of gravity.
All of the above applies to those that use a "proper" load equalizing hitch, properly installed and properly adjusted.
If you tow an Airstream trailer with just a ball, sooner or later, you will become a statistic. The laws of Physics, says so.
Inlandrv.com
800-8777311
Old 04-08-2004, 08:57 PM   #14
j54mark
Profile:
"I thought the axle load rating applied only to what the axles carried, which would not include the axles themselves, while the GVWR is the whole load."
Nothing, nothing at all. But then, increasing the maximum carrying capacity wasn't really the initial question, now was it? HowieE was trying to figure out how a coach with a GVW of 8900 lbs could have three axles, each rated only to 2300 (later corrected to 2800) lbs. I wasn't the one who wandered off into tongue weights.
So the question remains - three times 2800 is only 8400 lbs. The coach is rated to 8900 lbs. How is this possible? I asked the question, and I'll ask again using different words, is this because the axles CARRY 8400 lbs., while the entire coach weight cannot exceed 8900 lbs.? Or does an axle's weight rating include its own weight? If so, then we do come back to tongue weight after all, or so it would seem.
And If HowieE buys your 3200 lb. axles, what is the point? Does it increase his GVW? If so, what is the new GVW?
If this is too much "engineering theory", I will retire.
Mark
Axle Question drex Axles 7 07-30-2007 05:50 PM
Sorry. Another axle question whistler Axles 6 08-28-2004 10:33 AM
axle swap question garry Axles 4 10-08-2003 02:39 PM
axle question stp2136 Axles 1 10-05-2003 07:05 AM
Axle Offset Question DanLyle Axles 11 08-28-2002 09:35 AM
