01-22-2017, 12:04 PM
#61
Electronic Controls OEM
Allentown
, New Jersey
Originally Posted by Al and Missy
...My Dometic starts the fan first (the 11,000 BTU unit in my 2001 Safari did not) and the compressor start is not the "thunk" I was accustomed to with my 2001. Is this common? Or maybe the most recent PO installed an Easy Start as a part of his upgrades...
Hi Al & Missy. If your Dometic has a digital controller (either their "CCC" or "Single Zone"), it is possible that these controllers separate the fan function from the compressor. If instead your A/C has the more common 2-knob control, then the fan and compressor should always start together. In the latter case, if the compressor startup is delayed on your particular A/C unit, it may be due to an EasyStart or some other modification. The EasyStart's delay is only 5 seconds, which is just enough time for the Honda EU2000i (or any similar model) to exit ECO mode and jump to high RPM.
And to your point, EasyStart has been found to completely eliminate the annoying "thump" during startup. This bonus benefit of EasyStart we never thought was that important, until a bunch of customers told us otherwise!
01-22-2017, 12:36 PM
#62
2002 30' Classic S/O
Fleming Island
Thanks Matteo,
I guess I'll have to get up on the roof to be sure. The trailer has the multi-zone CCC, (not the CCC2) but only one A/C unit. Your product is very interesting. My 2000i (on gasoline) would start and run the 11,000 BTU unit in my Safari 25. I bought a current sensor and planned to set up a PC digital oscilloscope to monitor currents and voltages before actually using it, but sold the trailer first.
I'm really interested in the product and if I don't already have one, I'll probably get the bare board and install it myself.
Al
01-23-2017, 07:28 AM
#63
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
Matteo,
I have a Yamaha EF2000iSv2 generator and my trailer has both 15k and 13.5k AC units.
Is there any doubt that it will work with either unit? I really only need to purchase one for use with the generator so would you recommend installation on the 13.5k? My preference would be the 15k because that one starts up with a huge "bang" and I'd love to eliminate that. To my recollection the 13.5k isn't as bad.
Lastly, can these be picked up at your facility? I'm in the Allentown area fairly often. If so, do you do installs? Do you want to guide an install and then test with the Yamaha? :-)
This looks like a very interesting product. Leaning toward the bare circuit board and just buying my own enclosure and start cap. Other than some wiring that's all you need, correct?
@living.somewhere.yonder | Instagram
01-23-2017, 07:57 AM
#64
Allentown
, New Jersey
Originally Posted by SCOTTinNJ
Matteo,
Scott - Although we have less experience with the Yamaha 2000W generator, other customers that we know of with Yamahas have had equal success. I'm therefore willing to assure you that EasyStart will work with either your 13.5k or your 15k.
Yes, you are correct on your list of additional ingredients needed to handle a DIY EasyStart 366 installation. On our EasyStart 366 webpage, there is a recently improved installation guide. It even talks about mounting the board on its standoffs, etc. That should help you with that part. I can further assist you by drawing in where the EasyStart 366 goes into a wiring diagram. Attached are a couple examples.
Beyond this, you are more than welcome to stop by the factory! I'll send advanced warning . I won't be there since I live and work out of South Florida to be close to our largest customers, the big marine HVAC OEMs, which are all down here. When you stop by, ask for Becky. She can process your purchase. Please realize we don't normally do this, so please don't expect your typical "counter service". You may be sitting at the conference table while you wait, drinking a cup of coffee. Or if things aren't too busy, Russ, Roger, or owner Andy may even give you the nickel tour.
01-24-2017, 08:54 AM
#65
2015 16' Sport
Lakeridge
, Virginia
Subscribed
01-24-2017, 09:46 AM
#66
1994 30' Excella
alexandria
, Kentucky
Any idea if this would work on a 1994 vintage low profile Dometic with controls on the ceiling unit? The fan runs continuous. Would this AC unit even benefit from the controller since the fan run continuously and the compressor is switched on/off automatically as needed.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
01-24-2017, 10:43 AM
#67
Allentown
, New Jersey
Hi Steve. Yes, your older Dometic low-profile unit will certainly benefit. The fact that the fan is always running only means that if your generator has an ECO mode, it may not drop to low RPM when the compressor cycles off. This is because there will always be about 3A of AC load from just the fan. But as in all cases, when the compressor cycles on, EasyStart will reduce the starting amps by around 70%. Depending on the size of your generator and your other AC electrical loads, EasyStart could therefore allow your vintage A/C to start and run when it otherwise would not have.
01-24-2017, 07:01 PM
#68
2015 30' Classic
Pleasanton
I hope somebody posts a DIY install of EasyStart in a late model Dometic A/C unit!
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
01-24-2017, 07:34 PM
#69
2019 30' Classic
Canfield
, Ohio
Soon, i bought one!
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
01-26-2017, 05:31 AM
#70
Micro-Air Discount Offer
The recent discount offer post and subsequent replies have been relocated to the Commercial Listings forum which you can access via the link below.
http://www.airforums.com/forums/f206...ml#post1902763
William C. Swinney
01-26-2017, 09:46 PM
#71
Journeyman
2016 25' International
Amherst
, Massachusetts
I see a micro-air and honda EU2000i in my future. Thanks all. I had been debating this for a while (saw it on the Wynns) but wondered whether it would work with the smaller genny. The confidence of people who have done it -- and the stunning clarity with with Micro-Air talks about the details of the system -- make this an easy decision.
01-26-2017, 10:12 PM
#72
Journeyman
Amherst
, Massachusetts
Silly question. If I'm running with a Honda EU2000i, it doesn't have a 30amp plug, so am I just running a nice thick normal extension cord to the genny input on the trailer (using a dogbone converter)?
01-27-2017, 09:24 AM
#73
Oswego
Other way around. Us the AS shore power cord with an adapter with a 30 amp female to 15 amp male inserted in the Gennie socket.
-Rich-
01-27-2017, 10:33 AM
#74
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
Please document with pictures....
I am in same camp with my Champion 2000W, but not sure if I will get this unit for my current AS or wait till I get the new one in the spring...
If you the time and are interested, please document your time and progress on doing this and even take pictures if you can? This would be a great education for us all!
01-27-2017, 11:11 AM
#75
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
I'd be concerned that using anything other than a 30 amp cord all the way to the generator while running the air conditioner would put you at risk, even with this device, of overheating the cord and perhaps damaging your power socket at the generator. So, if you go this route, you may wish to consider the EU2000i Companion which has a proper 30 amp socket.
01-27-2017, 11:19 AM
#76
2014 30' FB FC Bunk
Anywhere
A 2000w generator can't put out 30 amps.
01-27-2017, 05:28 PM
#77
Green Cove Springs
Yes, good point, though I'm well aware of that. Just pointing out that if your devices are gonna suck really hard on that cord, maxing out the capabilities of the generator, it's probably best if it's a full-thickness cord all the way back to said generator.
Not telling people what to do, it's just a suggestion. It's your generator, your dime, your choice. Do what you want, no stress here.
01-27-2017, 06:26 PM
#78
2013 27' FB International
El Dorado Hills
I've had no problems using a 15 to 30 amp adapter running the AC at home from a wall socket (20 amp circuit). The adapter is about one foot in length. According to my kill-o-watt the AC amperage draw is in the 13 to 14 range for a 15,000 BTU AC. At 115 volts that's about 1600 watts.
01-28-2017, 02:44 AM
#79
2014 30' FB FC Bunk
Anywhere
Well I'd agree it can't hurt. But a good 20 amp extension cord should also be fine.
01-30-2017, 08:32 AM
#80
2016 16' Sport
Miami
I'm really interested in the easy start. I called dometic and was told installation of any non dometic part would void the warranty. I have two Honda 2000s with genconnex conversions. It would be nice to only carry one. Additionally a quieter start would also be welcomed. Any shared experience with this product would be appreciated.
