08-26-2009, 07:36 PM
#281
1955 22' Safari
Great Lake State
Originally Posted by utee94
Looking good toastie, all that new channel is so shiny and nice. That's about the spacing I used, seems to be working just fine.
Thanks Marcus, this trailer was neglected and was in very poor condition when I bought it, and it was exactly what I was looking for.
08-26-2009, 08:01 PM
#282
Remember, Safety Third
Catfish Corners
, Georgia
What Truck and Marcus said about the elevator bots. I think I read the other day that you are bolting the shell thru the new U-channel into the outriggers, right? That's pretty much how my 27 footer was put together. I think you'll be fine.
08-26-2009, 08:04 PM
#283
1955 22' Safari
Great Lake State
That is correct, fastener's are being attached to frame..........
09-05-2009, 02:56 PM
#284
1955 22' Safari
Great Lake State
Had rear separation and the pictures show why. The frame was repaired and today added a 2" x 3" angle iron bolted to the floor and frame for my rear plate. And like the front will add as many solid rivets that I can, shell to angle iron............toastie
09-05-2009, 03:27 PM
#285
Port Hadlock
Looks really good, toastie. Back end of my frame looked exactly like yours and I added a steel plate back there. I was putting bolts in there this morning and I'll be riveting the plate in when I get a helper for the bucking bar. Really impressive how much they stiffen up when the fasteners start going in.
09-06-2009, 08:04 AM
#286
1955 22' Safari
Great Lake State
Finally "slow floor replacement" is done, floor is down permanently. Starting to sand the seams, and my question to the forum is:
"What is the best filler to use on the elevator bolts and seams?" Bolts where recessed about 1/8"..........thanks toastie
09-06-2009, 08:53 AM
#287
Port Hadlock
I'm going to coat the subfloor with epoxy, so I'll be using epoxy with a filler to level out all my holes and seams. Microballoons would be fine; I think I've got a container of West System 407 407 Low-Density Filler that'll work ok. It'll sand smooth very easily.
09-06-2009, 09:13 AM
#288
1955 22' Safari
Great Lake State
Steve
Thanks very much, made both a favorite..........
Steve
09-06-2009, 09:58 AM
#289
1955 22' Safari
Great Lake State
Almost forgot to cut hole for the shower, sanded off the dim's, luckily I wrote them down on a piece of paper. Have to finish the belly pan before I can start the fun stuff..........toastie
09-06-2009, 03:54 PM
#290
1951 21' Flying Cloud
1960 24' Tradewind
Folsom
ok I really like your shower drain setup . . . that's what I would like to do, but I was under the impression that I must have a trap or I'll be smelling the contents of my grey tank AND I was led to believe that I need larger diameter drain line. Do you have "alternate" information? And, where did you get that shower drain w/the barbered fitting?
Thanks, MarkR
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
09-06-2009, 06:02 PM
#291
1955 22' Safari
Great Lake State
Thanks, MarkR
The shower drain comes with a stopper. The gray tank below is just for the shower and bathroom sink and is not part of the other gray water system, plus the shower drain is going to be approx 4" off the floor and
will built my own trap. The small bathroom sink will also have a trap. I bought my drain off ebay, its a SCANDVIK shower drain used on boats.........hope this helps..............toastie
Scandvik Drain & Accessories
Shower Drain
09-09-2009, 03:31 PM
#292
1955 22' Safari
Great Lake State
Stainless 7 Terminal Wiring Junction Box for the Bargman, all hardware is stainless, what a slick system.........
09-09-2009, 10:06 PM
#293
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral
Is the fitting at the end of the clear tube a straight-through barbed transition fitting or it a checkvalve?
09-14-2009, 06:02 PM
#294
1955 22' Safari
Great Lake State
No check valve...........
09-20-2009, 04:37 AM
#295
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha
, Wisconsin
Don't keep us in suspense... where did you get it?
09-27-2009, 04:47 PM
#298
Port Hadlock
Lookin' good, Toatstie. What aluminum are you using for your belly pan?
Great idea on those ramps--I think I know where I can borrow a pair.
09-27-2009, 05:28 PM
#299
1955 22' Safari
Great Lake State
Thanks Steve
I'm using 5052 0.040 and the ramps are Rhino Ramp 12000 Extreme Ramp bought at Rhino Ramp 12000 Extreme Ramp Set - 2166195 | Tractor Supply Company
toastie
09-27-2009, 05:36 PM
#300
Port Hadlock
Thanks!!
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
