10-13-2017, 08:56 PM
#1881
Foothill Ranch
Added the missing piece and did plenty of welding today....
10-14-2017, 08:46 PM
#1882
Foothill Ranch
This is what happens when I’m left alone with a Beadroller, a buffer and a sheet of Aluminum....
10-14-2017, 10:29 PM
#1883
2007 22' International CCD
Corona
Wheee! Abstract Airstream art!
10-15-2017, 11:00 AM
#1884
Foothill Ranch
Tried posting a little video of that panel but it failed...
So, here is a question...
I was wondering, and so I looked back at my thread...
One of the regulars here was a guy called "Mike Leary"... he and his wife were full timing in a 310 TD, but I looked back and he hasn't posted since 12-5-2014...
Anyone know if they are still out there???
10-15-2017, 11:27 AM
#1885
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Wasn't it Mike who had his oil/filter changed, and the shop put the filter in upside down which trashed the engine?...and I seem to remember he switched to a Land Yacht because they were full-timing and they needed something immediately?
10-15-2017, 11:45 AM
#1886
Foothill Ranch
Yes, Martin, that was the story but I dont remember how that ended.
Just was wondering what happened.
10-15-2017, 11:52 AM
#1887
Foothill Ranch
Trying video again...
10-15-2017, 12:24 PM
#1888
Foothill Ranch
Maybe this really explains what happened...
It was not in the MH section, so not obvious...
http://www.airforums.com/forums/f42/...ho-128217.html
10-16-2017, 03:05 PM
#1889
Foothill Ranch
1984 Airstream 345 owner (Newbie) need advice!
Yes, it is, so now you won’t need to ask.....
Swirled
Brushed
Tried polished too...
Just my first try.
Tricky but a little “Rustic”...
A friend said if it was perfect, it would be boring, and not hand tooled...
More testing required!
10-16-2017, 03:29 PM
#1890
1984 27' Airstream 270
Scotia
, New York
Let me know whey you are taking orders for personalized Airstream signs
10-16-2017, 05:23 PM
#1891
Foothill Ranch
That would be way fun, but I need a lot more practice yet!
10-16-2017, 11:09 PM
#1892
Foothill Ranch
Prepping for my day at the Motorhome.
1/ Panel fitment ready!
I did also take a look at brushed finish on the panel.... Gotta love the Eastwood SCT!
Wanna see what it can do in 30 sec?
Old cast iron Drill Press Table...
2/ Carb with new choke power cable ready!
3/ Continue to build my “Go Boxes”.
This one is assorted rivets.
10-17-2017, 04:09 PM
#1893
Foothill Ranch
Now, to get back to a project.
Finished the Radius turning attachment, bar a knob for the handle..
So I used the tool to make a handle for itself!
Ta Da!
Now, I think I am ready to make the special bead roller Dies I need!
10-19-2017, 07:00 PM
#1894
Foothill Ranch
First panel test fit went well.
Mk 2 will be better.
10-19-2017, 07:04 PM
#1895
1979 24' Airstream Excella 24
Tipp City
, Ohio
Very nice😎
10-19-2017, 09:52 PM
#1896
Foothill Ranch
Thanks.
Just got home.
As I expected it was a combination of good and not so good.
The good was how it looks and actually my guesses were pretty close.
The panel fit the wheel arch molding, and body between the wheel arch and headlamp casting pretty well, in fact, so well that there is nothing holding them in place in the picture! Pretty lucky considering how distorted the abs panel was.
The fit is great until it passes under the headlamp casting, and then it diverges.... but the issue is not entirely my fault.
In fact, the grill, headlamp assembly and indeed the body across the front has a different plan shape to the front bumper!
I think this pic explains it....
See how the grill actually is more curved and hangs over the center of the bumper at the centerline? The bumper is a flatter curve than the body. This causes a divergent curve between the bumper and body... I just have to figure out how to hide and or compensate for it now with the wraps and center panel.
The surface that meets and goes inside the side of the bumper was great, but will need to be flatter and need a tighter radius.
See here.
The top surface where it meets the bumper matched too, but I made an error because I didn’t spot the pumper support that stops the material sliding behind. Need a work around for that.
Here is my notes... [emoji3]
10-19-2017, 11:51 PM
#1897
Foothill Ranch
Oh, figured out the non cranking genset... 20a fuse in the control box was blown. I replaced it and she is cranking again, but didn’t get further than that.
I did take a look for the low fuel, water in fuel, warning lamp unit that WayneG is interested in, but not sure I found it.
I did find, dangling, loose connectors, switches, wires, and other horrors that I will need to deal with before I start using this beast.
10-20-2017, 03:30 AM
#1898
Tipp City
, Ohio
Looking good. It looks to me like your bumper has been bent. Mine was similar. You can take it off and bend the radius back into it.
10-20-2017, 08:15 AM
#1899
Richmond
, Kentucky
Thanks.
Just got home.
Attachment 297346
See here.
Attachment 297347
Attachment 297348
Steve, that looks really good!
I'm anxious to see how well it goes when you make the mirror image of this one.
1975 24' Argosy Motor Home
10-20-2017, 08:54 AM
#1900
Foothill Ranch
Greg:
My rear bumper was bent and broken off, and I welded it back together. It’s still not quite right, but ok for now.
The front one is ok and looks consistent in itself unless I missed something... the brackets that hold the bumper to the front frame have a lot of adjustment in them, so maybe what you see is in that adjustment?
I had mine front off last year to remove the horrible jacks, and while it was off I welded up some gouges and polished it. Maybe it’s tilted up or down a little?
Brad:
Thanks!
Having the MH so far away is good for the pocket book, but bad for working on it!
I’m happy with the first fit, but there is a long way to go. I’m less worried about the other side as that abs wrap is in better shape. Getting it to be symmetrical was part of my everyday job, so less worried about that.
I have decided to move the joint line between the side and center wrap outboard a few inches to it is the same as the grill/headlamp joint. It makes sense aesthetically and practically.
There is the flange between those two to deal with...
I might also make the roll up radius a little tighter.
I am having trouble with the TiG welds cracking on the joints when I planish them out, and may change material to 3003 aluminum which is easier to work. Getting feedback from the Metalmeet forum on that one.
