Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1960 - 1964 Overlander
Old 05-06-2010, 09:45 PM   #1
biopig's Avatar
1964 26' Overlander
baldwin city , Kansas
new shurflo pump, wiring ?
on our 64 overlander we have the factory univolt and par pump. Is the par pump powered by 19 volts? how do i wire in my 12 volt shurflo pump. thanks for your help. Also have new water heater to install!!
biopig is offline   Reply With Quote
Old 05-06-2010, 10:41 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
19 Volts?
Where did you come up with 19 volts? Are you reading it from the univolt? Is there a battery in the trailer?
Old 05-07-2010, 05:03 AM   #3
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Pump Wiring
I replaced the pump on my 65 Safari with a Surflo on demand. Just hooked up the same wires and everything works fine. It is normal 12 volt wiring.....Tim
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 05-07-2010, 09:27 AM   #4
biopig's Avatar
1964 26' Overlander
I believe the 64 univolt provided 18.5 volts to the pump and furnace. Atleast thats what I've read on several posts. Hoping there's an easy fix.
Old 05-07-2010, 04:35 PM   #5
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Have you replaced your Univolt at all? If not, now's a good time to change over... fix two birds with one ... uh.. stone? That Univolt is HEAVY!
HOWEVER, I thought the early years (my '63 included) didn't have a converter, but rather step down transformers for converting 110 to 12V AC, not DC. If this is the case, you might want to run a positive and negative line to your pump from your battery, putting a fuse in line..
Marc
Old 05-07-2010, 07:30 PM   #6
1965 17' Caravel
Birmingham , Alabama
I still have my original Univolt set-up in my 65 Caravel. Yes,my pump and the fans run on about 19 volts AC. The shorepower 120VAC goes into a heavy step-down transformer and two wires emerge: 12VAC and 19VAC. I have 2 switches to throw to go from shore power to battery - one for each voltage feed. The original pump and fans run equally well on 12VDC or 19VAC. I don't expect that your new pump will work on AC at all though. As another poster suggested, you can run it directly off the battery. I can't because my AC Univolt set-up doesn't charge the battery. The Caravel didn't get a rectifier to make DC out of the AC circuit.
Anyway, I like the Univolt transformer hum. OK I lied there, eventually I will change to Intellipower.
gwchitty is offline   Reply With Quote
Old 05-07-2010, 07:45 PM   #7
biopig's Avatar
1964 26' Overlander
Thanks for the advise everybody. I think I'll run it from the battery until I have the funds to upgrade the electrical system. I still have alot to learn about our trailer, she's only bin in the family for about 5 months.
Shurflo Pump Problem. Mike Leary Water Heaters, Filters & Pumps 11 10-31-2009 02:37 PM
Shurflo Water Pump Problem mello mike Water Heaters, Filters & Pumps 15 08-20-2009 12:32 PM
shurflo water pump, which one? urbanfood Fresh Water Systems 24 08-19-2007 04:37 PM
Shurflo water pump urbanextreme Water Heaters, Filters & Pumps 13 05-18-2006 10:18 AM
Shurflo pump problems toastie Water Heaters, Filters & Pumps 14 05-17-2006 08:32 PM
