02-25-2022, 01:09 AM
2021 27' International
San Francisco
Heating pad install under the floor vinyl
I'd love to install a couple of these in my trailer...
https://expeditionupfitter.com/produ...-floor-heating
I'm pretty sure it'd be ok to put this under the vinyl, as the power output is pretty low. Ideally I'd put them where the orange rectangles are here...
Is there any way to insert them without ripping out everything to get to the edge of the flooring? Could I perhaps cut the vinyl at the pink locations, remove part of the sofa/bed framing to squeeze it underneath, and then staple the vinyl down again around the cut? Very interested in people's thoughts .
Cheers!
Nick
02-25-2022, 04:54 AM
2013 31' Classic
billings
, Montana
Use a throw rug….
02-25-2022, 10:22 AM
1988 32' Excella
Robbinsville
, New Jersey
Originally Posted by tjdonahoe
Use a throw rug….
Agreed or maybe some anti-fatigue foam mats.
When they build Airstreams they put in the flooring then everything else goes in on top of it, I doubt you would be able to sneak them in.
02-25-2022, 11:00 AM
2021 30' Globetrotter
Oviedo
I think you’d be opening a can of worms trying to get something under the flooring. I d also be concerned about it eventually discoloring the floor.
02-25-2022, 11:25 AM
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
And create a lump. The vinyl is cheap and thin.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017 Chevy Silverado 2500HD Duramax Diesel
02-25-2022, 11:54 AM
San Francisco
Yes, there'd definitely be a slight lump on the floor from the thickness of the mat. I don't think discoloration should be an issue as the power levels here are relatively low - around 140W/m is about 1/10th of what bright sunlight gives you. Just enough to make it warm, not hot.
I'm not sure if I want to do it, but is there a reason why cutting the vinyl in a couple of hidden places and then stapling it down again, would be really bad?
02-25-2022, 12:08 PM
2013 30' Classic
Key West
02-25-2022, 02:40 PM
Oviedo
It’s thin, but it ain’t cheap
02-25-2022, 02:50 PM
1979 31' Excella 500
Desert
I was actually considering doing that too. I don't have the issue of installing at as I am rebuilding my trailer from the ground up, however I am concerned about the interaction with the custom printed vinyl that I want to install on top of it
02-25-2022, 11:43 PM
San Francisco
Are you thinking about the same heating element or a more powerful one, and are you worried about the lack a flat floor or the impact of the heat on the vinyl?
02-26-2022, 07:49 AM
Some Guy
1968 26' Overlander
2021 25' Globetrotter
Nashville
, Tennessee
NickA, You aren't crazy. I've considered the same, however, I'm just looking at a highly recommended 110V pad vs. a much higher cost 12V pad. Given that this would only be used as a comfort, rather than a heat source, for us. Are you considering the 12V vs. 110V for boon-docking and are you considering this as a more primary heat source or....?
There are a few 110V on Amazon that have pretty high marks. If you have an ample battery bank and inverter, these things sip electricity and could be set with a timer to come on in the morning 30 minutes before you wake just to add a level of comfort. From what I've seen from "VAN LIFE" folks, this is a common addition to van builds and are so thin, that they add no floor challenges to floor height.
The Jarretts
Nashville, Tennessee
1968 26' Overlander
2019 RAM PowerWagon TV-Petrol Hemi
WBCCI # 22342
02-26-2022, 09:23 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Anything you do that puts a lump or ridge in the vinyl will create a wear point. It will wear out very quickly at that point. Foot traffic hits the "bump" much harder than a normal piece of floor.
02-26-2022, 09:31 AM
2017 16' Sport
N/A
, N/A
Sheep lined slippers
02-26-2022, 10:39 AM
2017 25' Flying Cloud
Woodway
Heating Pad Under Flooring
IF you're really determined to do this, consider removing a patch of the old flooring the same size of the pad(s), provided the pad approximates the thickness of the original flooring. Once done, go over everything with a better quality vinyl.
02-26-2022, 01:25 PM
BoatnutG2
2015 28' Flying Cloud
2023 23' Flying Cloud
2013 Interstate Coach
Huntington Beach
We have one down our center aisle on top of the vinyl and use a 2' X 7' throw rug from HomeGoods over it. Works great! We plug into a thermostat/timer. It keeps the floor and the rig toasty.(and feet warm). I would not cut up the vinyl.
02-26-2022, 04:03 PM
2019 25' International
Washington
, Washington, D.C.
Umm, I think this might not go the way you wanted. What problem are you are trying to solve? If it's cold feet, go to Walmart and buy a pair of those ugly open-toed sandals for $7. Is it to keep the dog warm? There are comfy beds and heating mats for that. Photo below shows the cheapie sandals I mentioned. I have "cold feet syndrome" - (can't remember the name right now) and these and a pair of thick wool socks are a godsend when in the AS on cold mornings.
02-26-2022, 05:11 PM
2020 23' Flying Cloud
2019 22' Sport
Sebastian
The wife agrees with the slipper approach.
A mechanical engineer would tell you, “F=MA and you can’t push a rope (mat)”. I would not give you good odds for a successful insertion.
If you really want to heat up those areas of the floor, have you considered a low wattage IR heat lamp?
Good luck on your project.
-Don
(That man in that tiny can)
(Same man, Bigger can)
02-26-2022, 06:38 PM
Some Guy
1968 26' Overlander
Nashville
, Tennessee
I respectfully disagree with those who claim this is a bad idea. In Van Life, this is as common as van builds. In EURO Caravans, this is standard to have heated floors. These heated floor mats are paper thin and also can be cut at strategic places to length (just like LED tape light strips). Additionally, these sip 12V if not left on for long periods of time. Anyway, I'm still debating one in the bed area to simply knock the morning chill. The practical side of me worries that it'll just be another item to maintain (even though they're pretty much maintenance free).
The Jarretts
1968 26' Overlander
WBCCI # 22342
02-26-2022, 06:41 PM
San Francisco
Thanks so much for all the feedback/ideas! My main goal is keeping feet warm when sat at the table for long periods. We work from the trailer for months at a time while enjoying weekends wherever we are, and I spend a lot of time sat there, and it’s hard to keep my feet from getting cold, even with thick socks.
Originally Posted by djarrett
Are you considering the 12V vs. 110V for boon-docking and are you considering this as a more primary heat source or....?.
We do a fair bit of boondocking, so I like the idea of having the option during those times. We have a decent solar setup and inverter conversion efficiencies are quite low, not to mention the static power draw of them being on and unloaded. We try not to leave the inverter on unless we need it or are plugged in. I’m not expecting this to provide that much heat overall. The power level isn’t that high, which makes it usable in boondocking scenarios when there’s sufficient solar in a given day. I just think it’d be great on cold days while working, and also for half an hour first thing in the morning!
I wondered about this too. The mat is less than 1mm thick - do you think this is really going to be enough to be an issue?
Definitely another option, but doesn’t work under the table where I care the most. I get the risk of wear points in the vinyl, and the difficulty of getting it under there(!), but is there any other good reason for not cutting the vinyl somewhere hidden that I should be aware of?
Cheers,
Nick
02-26-2022, 06:46 PM
2023 28' International
Mercer County
, New Jersey
One thing to check/verify is that the vinyl flooring isn't glued to the wood flooring in the trailer. I know in many homes they put an adhesive under the vinyl flooring.
