Hi
We spent a bunch of time reading various threads and deciding what we needed to go out and get "pre delivery". We then spent the next few years shopping for this and that to replace this and that
There is a certain minimum amount of stuff you will need to get through two days of camping. You do need a toothbrush
. You need to make coffee (that might be ahead of the toothbrush on the list ...). The dealer likely will throw in a sewer hose and a water hose. They probably will supply a few rolls of TP and some tank treatment "stuff".
I would suggest you start off with paper plates / plastic knives and forks. Yes it's horrible for the environment, it also fits way better with the sort of water / gray tanks on an RV. See how that goes before you buy lots of place settings.
A pot and a pan probably is the minimum. You can go pretty crazy in this regard. It *does* need to fit someplace. Same thing with the crock pot / air fryer / toaster oven / ice cream machine / beer fermenter ...... from the typical modern kitchen. Wait a bit and see how things fit.
Chocks and leveling blocks will be needed. With a dual axle X Chocks are pretty neat. There are a *lot* of different gizmos out there for leveling.
One thing most folks don't have in their camping gear: A torque wrench. You need one to tighten the nuts on the wheels when a tire is changed. An extension and the proper thin wall socket also are part of the kit. Most toss in a breaker bar to loosen the nuts as well.
One not so obvious item: A big box in the garage. You will get all sorts of goodies with the trailer. Will you *use* those AS custom cushions? (or whatever) If not, into the box they go. They get saved for the next owner or for when you change your mind.
Yes this list could go on and on forever and ever .... check out the threads on the Insta Pot ....
