Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Globetrotter > 2018 - Current Globetrotter
Old 03-24-2019, 11:01 AM   #1
Winedog
2014 25' FB International
Walla Walla , Washington
Gas struts installed on cabinet door above fridge
This is an easy project. It is slightly frustrating to access the overhead cabinet when the door won’t stay up.
I used a gas strut made by Apexstone - 45N/10lb available on Amazon.
Position of the strut is crucial or the door won’t close. Here are the measurements:
Top of strut: mount the bracket 3 inches from top of door, and 5/8” in from the side
Bottom of strut: mount the bracket 1 inch from bottom of door and 1 inch in from the side
winedog is offline   Reply With Quote
Old 03-24-2019, 11:53 AM   #2
D44
D44's Avatar
2017 25' Flying Cloud
Lawn Guyland , New York
Excellent! What hardware did you use to attach to the cabinet side and underside of door?
Walt
WBCCI - 29375
D44 is offline   Reply With Quote
Old 03-25-2019, 07:43 AM   #3
Winedog
All mounting hardware (brackets and screws) was included with struts.
Old 03-25-2019, 08:51 AM   #4
"Cloudsplitter"
Good Job...👍
When did the design change?
Another example of... 'no changes only improvements?'
Our '03' Classic...
Old 03-25-2019, 09:17 AM   #5
2019 27' Globetrotter
Pleasanton , California
Thank you for the detailed "fix". Hate holding it up with my bald head...
Couple questions - Are you measuring from the center of the strut? Did you use 1 or 2?
fubar201 is offline   Reply With Quote
Old 03-25-2019, 11:23 AM   #6
4riveteers's Avatar
2016 27' Flying Cloud
Manteca , California
Thank you winedog! I’m going to Amazon right now!����
2016 27 Flying Cloud FB
2005 GMC Yukon XL 2500 4x4, Equal-i-zer Hitch, 4.10 axle ratio.
4riveteers is offline   Reply With Quote
Old 03-25-2019, 11:34 AM   #7
Antiquepedaler
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
Laramie , Wyoming
Images: 11
Got the same result with a piano bench lit support from Amazon for $8.
https://www.amazon.com/Piano-Bench-L...gateway&sr=8-1
Antique Pedaler
2021 Caravel 20 FB
Antique Pedaler is offline   Reply With Quote
Old 03-25-2019, 11:59 AM   #8
- , My heart is in Colorado
This is awesome! I've been thinking about how I could configure magnets to hold this door open, but this is a more straight forward approach. Thanks for the great documentation and specs.
Jump, and the net will appear.
Papatango is offline   Reply With Quote
Old 03-25-2019, 12:19 PM   #9
Napa , California
We did the same thing, and just needed one strut. Only real issue we had is that the instructions might as well been written in Klingon -there was no way to directly translate into English that made any sense at all!
But, a quick review online of installing struts and a wee bit of extra "think" and test time and it went very smoothly. Such a cheap and easy fix...makes you sort of wonder why it wasn't done originally.
Atwebs is offline   Reply With Quote
Old 03-25-2019, 12:58 PM   #10
2007 22' International CCD
Probably because it costs a few bucks and a moment of assembly time that comes out of profit for Airstream, but don’t pay attention to my cynical viewpoint...
Old 03-26-2019, 11:13 AM   #11
2015 25' FB Flying Cloud
Charlotte , North Carolina
An easier fix and cheaper also is to get a spring type hatch support from West Marine. This also works for the large hinged mirror in the head.
MaiziesGang is offline   Reply With Quote
Old 03-27-2019, 08:00 AM   #12
Winedog
Diagram of strut placement mounting brackets
http://www.airforums.com/forums/atta...1&d=1553695081
Old 03-27-2019, 09:43 AM   #13
2016 27' International
Anacortes , Washington
Can you provide a larger image, please
The provided image of your sketch showing the dimensions doesn't enlarge like your photo of the completed strut. So when I try to enlarge the small image, it is too blurry.
We too have thought about struts others have installed, but knew exact placements of the strut ends would be challenging. So with your success and exact placement dimensions, we are ready to proceed!
Thanks for posting!
Pat Pierce is offline   Reply With Quote
Old 03-27-2019, 10:42 AM   #14
Winedog
Hopefully this is more clear.
http://www.airforums.com/forums/atta...1&d=1553704816
Old 04-07-2019, 03:13 PM   #15
BobAndStella's Avatar
Monterey , California
I really wanted to do this; but discovered that the height of this cabinet on our 2017 FBT FC is only 8 1/4”. So it won’t work. Still looking for a similar solution.
BobAndStella is offline   Reply With Quote
Old 04-11-2019, 05:30 PM   #16
I get frustrated with trying to find my posts and even get good results of searching for things, but (hopefully) these two pics I think are attached will be here. I frustratingly tried struts, but that became awkward. So instead I use one 3" long surface bolt (Ace Hardware, but common) in brushed nickel. I needed a filler between the wall and the surface bolt, so I cut a piece of one quarter inch thick aluminum as the filler and a couple lock washers in between to get a little more thickness. Simply screw this arrangement wherever you want, and is dead simple, works great.
ID:	337953   Click image for larger version
Old 04-12-2019, 10:58 AM   #17
Winedog
Have you looked at using a hatch support spring?
Old 04-12-2019, 10:59 AM   #18
Winedog
Oh, that was suggested earlier in this thread.
Old 04-15-2019, 08:54 AM   #19
Winedog
I saw this at a friend’s house - the cabinet is about 8” tall:
Sugatsune 90 degree Soft Down Lid Stay
SHSDSC301N-WH
$28.90 at eBay.
Old 05-01-2019, 07:11 PM   #20
jeffmc306's Avatar
McHenry , Illinois
Thanks!
Winedog, thank you for sharing your idea and detailed sketch with dimensions. I ordered the strut from Amazon and installed it tonight. Works like a charm
Much appreciated!
-Jeff
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Gas spring struts for mattress lift RLS General Interior Topics 7 12-04-2018 08:44 AM
Need cabinet struts. mapley3 Cabinets, Counter Tops & Furnishings 0 07-26-2013 09:59 PM
TV mounting - cabinet above fridge rodsterinfl Audio, Video & TV 4 03-09-2012 11:50 AM
How do I remove the cabinet above the fridge? RV H-D Lady All Argosy Trailers 13 12-11-2010 04:29 AM
Gas assist struts for lifting bed to access storage. Phil/Edee General Interior Topics 13 09-27-2007 10:12 AM
