06-23-2021, 08:02 AM
2017 23' Flying Cloud
Waukesha
, Wisconsin
Converter upgrade question
I spoke with a rep at my local Airstream dealer and asked about upgrading my converter on a 2017 FC 23FB. He said there may be an issue with space depending on what converter I chose to use. Does anyone have experience with this - i.e., upgrading this model coach to a 3-stage converter in the same space under the refrigerator? Also, what converter is recommended for this? Thank you.
06-23-2021, 08:58 AM
2009 34' Panamerica
2005 28' Classic
Still
, in the thick of it
I'd get in contact with the guy at bestconverter.com he is/was a forum member and he can tell you exactly what you need, or at least he did for me a number of years ago when Airstream installed single stage converters.
06-23-2021, 09:20 AM
2022 25' Flying Cloud
NCR
, Ontario
took into the Victron series .
we use their 3k Inverter /converter
excellent product and support
as well you can access the status online or from your phone
06-23-2021, 09:29 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The Victron MultiPlus units are very nice. You *will* need to fiddle a bit to find room for them ( = they will not fit in the same space as the old converter / charger ). Indeed neither the 2000 or 3000 would fit where the old inverter was mounted either. The mods involved were not insane, but modifications were required.
Most of the basic RV targeted converter / chargers will fit into the old converter "space" without a crazy lot of work involved. Only minor DIY skills required. There are a few drop in's. Just how well they perform long term is a bit unclear ....
06-23-2021, 08:55 PM
Bartlett
, Tennessee
This is the best advice you can get. Randy will not steer you wrong. I have used him to replace the converters in both RVs that I have owned. I replaced the converter in my 2017 FC 23FB with a Progressive Dynamics PD4655, but ask Randy what he recommends because there may be something better by now. (I took delivery of the replacement converter before I took delivery of the Airstream. I never even plugged in the factory converter.)
bestconverter.com
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
06-23-2021, 08:58 PM
2006 25' Safari
St. Augustine
I have a different model but I believe Airstream still uses the same stock converter/charger. I too replaced mine with the Progressive Dynamics PD4655. It fits in the same space. They also have a new one that can be used as flooded/agm or lithium.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
06-24-2021, 09:00 AM
Waukesha
, Wisconsin
I've already switched to 6v AGM batteries and use solar panels when boon docking. But in-between travels I'd like to safely have the batteries charging without having to worry about over-charge which I've done in the past.
Thank you!
06-24-2021, 09:42 AM
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
Call Randy at:
https://www.bestconverter.com/Boondo...rs-_c_154.html
You want the 4 stage; recommend either Boondocker or Progressive Dynamics. He can help you and is an AS owner. I have the Boondocker, but I have a 28'. My friend had a 23D, and he got the Progressive Dynamics. There are several documented installations, with pictures if you need that. Not too difficult and Randy can assist with questions, perhaps pictures.
06-27-2021, 07:00 AM
Waukesha
, Wisconsin
Thank you to all who replied - I'll be reaching out to the contacts you all mentioned. I appreciate your help!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
12V converter/battery/monitor upgrade
dznf0g |
Batteries, Univolts, Converters & Inverters |
35 |
01-31-2016 07:49 PM |
Upgrade converter?
Breadbug |
5 |
01-15-2011 02:08 PM |
replace and upgrade converter fuse block
nikiarntz113 |
3 |
11-28-2010 09:24 AM |
Converter Upgrade
nickmeloy |
2 |
10-11-2010 03:50 PM |
Upgrade converter in '05 Classic 31?
bandboss |
3 |
03-01-2006 05:58 AM |
