Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Classic > 2016 - Current Classic (all lengths)
Old 11-18-2020, 10:04 AM   #1
2019 30' Classic
Belleville , Illinois
Winterization question 2019 30" Classic
I have have a question regarding using compressed air to blow out the plumbing lines and the Alde hot water system. I am not going to use RV anti-freeze at this time.
Do I: 1) drain the hot water tank, close the pressure relief valve and then blow out the lines or 2) do I need to drain the hot water tank, bypass the Alde and then use compressed air; or 3) some other method?
Thanks.
Presitla99 is offline   Reply With Quote
Old 12-05-2020, 08:06 AM   #2
2018 30' Classic
Cumberland , Maryland
We have a 2018 Classic 30, and in the owners manual it has procedures for winterizing by blowing the lines out. You should have that info for your 2019. It is recommended NOT to exceed 50PSI while doing the procedure. It has worked for us.
Airhead2018 is offline   Reply With Quote
2019/20 Classic with winterization kit ghaynes755 2016 - Current Classic (all lengths) 14 11-06-2019 05:39 PM
2019 GT winterization bypass Rb115 Winterizing, Storage, Carports & Covers 3 03-25-2019 06:32 PM
"silver avion" avion C11 airstream "truck camper' "slide-in" aluminum eBay Watch Airstreams on eBay 0 09-14-2013 06:20 PM
Would like the "why" behind one step in blowing out lines in winterization process bonginator Plumbing - Systems & Fixtures 9 10-05-2012 12:12 PM
