There’s two TVs and two remote controls in our new rig. Problem is, changing channels on the galley TV also changes channels on the bedroom TV. Both are LG, 12 vdc and 120 vac. The owner’s manual doesn’t address pairing a TV to a remote. Thought the remote was line of sight, maybe not.
Common issue. Resolution is low tech. Point the remote directly at the TV you want to control, and do so within relative proximity so the IR light does not reach the other unit.
2020 28' International
Wilmington
, North Carolina
LOL - I posted the same question recently for our 2020 Internal Serenity 28 RBQ!
I fixed it the old fashion way - I went to Best Buy and purchased a 32 inch Samsung smart TV! (I think the LG which comes with the unit is a 28" set) Different remote from a different company fixed the problem. The 32 is also a bigger screen and it fits perfectly in the space allotted and on the bracket - and it gives you the latest smart TV features. It was about $250 but I think it was worth it - just saying!
We tried that, but I didn't think it worked. The tvs aren't within line-of-sight of each other so there must be some kind of reflection going on or the remotes work through the walls. I'll try again and see if I can get a technique that works. Thanks.
