Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > International > 2016 - Current International
Old 09-05-2020, 05:08 PM   #1
2008 28' Safari SE
Kemah , Texas
TVs in 2020 Intl Serenity 28RBQ
There’s two TVs and two remote controls in our new rig. Problem is, changing channels on the galley TV also changes channels on the bedroom TV. Both are LG, 12 vdc and 120 vac. The owner’s manual doesn’t address pairing a TV to a remote. Thought the remote was line of sight, maybe not.
dwight69 is offline   Reply With Quote
Old 09-05-2020, 05:27 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Common issue. Resolution is low tech. Point the remote directly at the TV you want to control, and do so within relative proximity so the IR light does not reach the other unit.
wulfraat is offline   Reply With Quote
Old 09-06-2020, 01:48 PM   #3
2020 28' International
Wilmington , North Carolina
LOL - I posted the same question recently for our 2020 Internal Serenity 28 RBQ!
I fixed it the old fashion way - I went to Best Buy and purchased a 32 inch Samsung smart TV! (I think the LG which comes with the unit is a 28" set) Different remote from a different company fixed the problem. The 32 is also a bigger screen and it fits perfectly in the space allotted and on the bracket - and it gives you the latest smart TV features. It was about $250 but I think it was worth it - just saying!
etojeo is offline   Reply With Quote
Old 09-07-2020, 01:51 PM   #4
2008 28' Safari SE
Kemah , Texas
Thanks, that's probably our solution as well.
Old 09-07-2020, 01:54 PM   #5
2008 28' Safari SE
Kemah , Texas
We tried that, but I didn't think it worked. The tvs aren't within line-of-sight of each other so there must be some kind of reflection going on or the remotes work through the walls. I'll try again and see if I can get a technique that works. Thanks.
Old 09-14-2020, 06:58 PM   #6
Sulphur , Louisiana
It frustrated me to the point of replacing the front TV with a slightly larger smart TV. No more problems and I like the new TV better.
rd1409 is offline   Reply With Quote
2018 28RBQ battery problem? Roxy59 General Repair Forum 2 06-18-2019 03:10 PM
2018 28RBQ Serenity Factory Solar Pre-wire Wconley Generators & Solar Power 12 08-12-2018 07:26 AM
Cushion layout for Dinette/Bed, 2011 23D Intl Serenity ksmuland Upholstery, Blinds, Walls & Interior Finishes 2 04-12-2016 09:21 AM
How To Install Cable Box 2013 Intl Serenity paulodland Audio, Video & TV 2 12-15-2013 05:26 PM
2014 Airstream International Serenity 27FB New - 2 LED Tvs - Queen Bed in Front eBay Watch Airstreams on eBay 0 11-19-2013 08:30 AM
