11-02-2021, 06:14 PM
Baltimore
, MD
Any red flags with this tow vehicle I want to buy?
Hi - thanks in advance again, I'm ready to pull the trigger on a used Chevy 250 I think is plenty sufficient but I just can't wrap my head around the formula for a proper tow vehicle. I can't afford to make a bad choice, this is already a stretch
Are there any red flags with this truck to pull a 25/27 FC or International?
https://www.koonswhitemarshchevy.com...8e2fd1ac4d.htm
Is the fact it has an Integrated Trailer Brake Controller a big deal? I was specifically looking for a truck that had one which has been impossible to find
I'm waiting for a response from the dealer on the curb weight, hitch type, axle ratio, and payload - all of which I'm assuming I need to know but aren't sure. Is there anything else I need to be asking?
I already asked once about a different truck and still feel lost, but I'm closer to understanding now. A little.
11-05-2021, 05:03 AM
Liquid Cooled
2017 27' Flying Cloud
near Indy
, Indiana
That's probably about what I'd look for if I was looking for a Chevrolet. The lack of comments in this case is probably as close to a thumbs up as it gets.
11-05-2021, 05:20 AM
Evergreen
Based on the information provided, it looks like this truck should easily handle a 25 or 27 footer. You’ve got plenty of payload capacity at 2,626 lbs., and the axle capacities are good. It would be nice to see the axle ratio and hitch information, but I don’t think they will be a problem. I believe your curb weight will be 6,874 lbs. (GVWR less payload). I’d be shocked if a 2500 series HD truck didn’t have an integrated brake controller as a stock accessory, but I could be wrong. Is this a diesel or gas truck? I’m guessing diesel.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
11-05-2021, 06:59 AM
2017 23' Flying Cloud
Bartlett
, Tennessee
I agree with RedSHED. The lack of comments is a HUGE green light. With nearly 130 views, if anyone thought it was insufficient, you WOULD have heard.
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
11-05-2021, 07:21 AM
2008 27' International FB
Petaluma
Well the truck link is broken so maybe the OP bought it?
11-05-2021, 04:48 PM
2021 27' Globetrotter
Daytona Beach
My work truck is one of these and I love it.
11-05-2021, 05:36 PM
2019 27' Globetrotter
McHenry
That’s more than enough truck to handle the anticipated 1100 lbs tongue weight of a 25 or 27’ Airstream. By comparison, a 1500 would have around 4000-4100 lbs rear axle max vs. this truck’s 6200 lbs. The 1500 would be right at the axle’s max which means you’re out of payload.
Take a trip to the CAT scales after you get it and do a three-pass weigh. It will confirm you’re in good shape.
You’ll be fine!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
11-06-2021, 10:01 AM
2024 23' International
South of Austin
It'll do just fine with a good WDH system like the Fastway E2. You still need weight distribution and sway control.
11-06-2021, 10:07 AM
2019 22' Sport
You can ad a brake controller no problem. That truck has plenty of payload for your needs. I'd tow my 22 sport on the ball all day long with that thing
11-06-2021, 11:09 AM
2006 25' Safari
St. Augustine
2626 lbs is good for payload. That is tongue weight (about 1000 lbs), and people and stuff in the truck. If the sticker from the manufacturer says it will handle that load then the math is already done for you on axles, etc.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
12-08-2021, 01:45 PM
2017 20' Flying Cloud
Williamson County
I did not see the answer regarding advantages of the factory brake controller. The factory installed unit also includes sway control that will lightly apply trailer brakes as well as specific TV brakes under certain detected sway conditions. Of course with everything setup properly it may never be needed anyway, I have never seen mine activate.
2018 GMC Canyon CCSB V6 Mallet Supercharger
2006 Chevrolet CCSB 2500HD 6.6T LBZ
