DeltaRon
The ingredients seems to show Ethyl Al*****
It gets too hard to read in the photo.
This MSDS for Super Tech -50 RV and Marine Antifreeze does list Ethanol, but is dated 2012 so I am not sure how trustworthy it is.
https://americanamb.com/wp-content/u...Antifreeze.pdf
But then again there are other data sheets for Super Tech RV and Marine Antifreeze appear to be dated 2003, So back to the same question: What does his bottle show.
Bottom line: Back to Opinion Only: If it is ethyl alcohol do not use it.. The stuff costs so little money for the non-ethanol based, why risk potential damage to the seals from the alcohol.
If other opinions are the risks from alcohol are overstated, then use it.
My posts are to just point out to all the readers that are unaware of the risks to alcohol based RV antifreezes to think twice before buying the cheap stuff.
If DeltaRon's does not have alcohol, then great......Back to his original question, Is it still safe to use after 5 -6 years.....I am only pointing out the risk of alcohol, not trying to make a judgement on the shelf life.
On the question of shelf life: Is the risk of potential really expensive damage worth the savings in a few dollars a bottle of new anti-freeze......But the reality is......Your stuff is probably still fine anyway....Particularly for an area with mild winters. "Do you feel Lucky"
