Old 10-08-2022, 09:09 PM   #1
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Tip to add antifreeze when winterizing
Living in the Midwest I do the blow-down then add antifreeze to be safe. Our 2019 Globetrotter came with a factory winterizing valve (originally installed backwards).
I’ve never been able to get the pump to pull antifreeze from a gallon bottle. I found using a Hopkins FloTool funnel with an on-off valve connected to the feed line worked but you had to keep refilling the funnel or get someone to run the faucets while you added antifreeze.
Today I found a solution - turns out the FloTool valve threads are the same as the antifreeze bottle’s. This allows the pump to draw a full gallon at a time. I made a simple stand out of scrap wood to hold the bottle upside down and clamped it to the wardrobe floor. You could make a wire hanger for the bottle but the stand worked for me.
**You need to punch a vent hole in the bottom of the bottle before turning the pump on.**
After the first gallon, just cut a hole in the bottom of the bottle to refill it. Save that bottle for next year.
ID:	423759   Click image for larger version
ID:	423761   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 10-08-2022, 09:33 PM   #2
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
GVA , British Columbia
Thumbs up
Nice jig! and you just clamp it on.
Laurence
LAWBC is offline   Reply With Quote
Old 10-09-2022, 09:03 AM   #3
"Cloudsplitter"
In western NY
We blow the lines & HW tank @ 35-40 psi for 10min and just add AF to the traps.
Nothing in the lines or toilet bowl,(just lube the seal). YMMV
ID:	423777   Click image for larger version
“Listen, or your tongue will make you deaf” Native American proverb.
Winter's almost here: ok to add antifreeze to black water tank? flyingfishy Full-Timing, Winter Living & Workamping 3 11-12-2018 02:15 PM
Winterizing tip, or maybe not? Jim & Susan Winterizing, Storage, Carports & Covers 1 01-06-2016 12:12 PM
Antifreeze Leaked During Winterizing..Smell in Trailer BW1 General Repair Forum 8 08-10-2015 06:51 AM
Winterizing - Tubing Size for Antifreeze Connection campadk Winterizing, Storage, Carports & Covers 1 10-05-2008 03:29 PM
Winterizing-Adding Antifreeze JaceBeck Winterizing, Storage, Carports & Covers 13 09-25-2003 05:45 PM
