Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 06-19-2018, 09:55 PM   #61
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
New Driveway - Good News Bad News
Note that I could not back further without contact - so a bit of elevation from the gutter and I think I’ll be golden. Or I hope
PharmGeek is offline   Reply With Quote
Old 06-19-2018, 10:16 PM   #62
2007 27' International CCD FB
San Diego , California
Originally Posted by PharmGeek View Post
Does the lift much change using the stabilizer jacks? Like on flatish ground? Like you don’t have to add something under them? Assuming just an extra few cranks.
Don't need anything under them for flatish ground. Just a few more cranks on the jacks. I do always have on me 4 or so leveling blocks that I can throw under the lower end of slopped ground for the occasions they can't reach. Just like one would to level the trailer side to side under tires.
There's no way with a lift kit that this won't clear. It opens up a whole world of accessibility and reduced worries about clearance and underbody damage. I like that my hitch head and WD bars are likewise higher up and match the clearance of my tow vehicle.
pteck is offline   Reply With Quote
Old 06-19-2018, 10:43 PM   #63
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Time for a re-do.
Hi, it seems as though your new driveway has a huge arch in it. From the street it should be flat but angled up slightly to your old section. [no arch needed]
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 06-20-2018, 05:32 AM   #64
Sag Harbor , New York
. . . and now some lumber to test it finally . . .
Looking forward to this . . .
Old 06-20-2018, 06:34 AM   #65
Images: 59
You might pick up another inch of clearance if you switched your weight distribution hitch from a round bar setup to a square bar trunnion setup.
Old 06-20-2018, 07:39 AM   #66
gator.bigfoot's Avatar
KW , Ontario
Attachment 314472
This was coming down from the pad...but maybe if the rain gutter was filled that would be enough....
Do you own the hedge beside the driveway? If so remove half of it and come across from that angle. It will be a better lead in into the driveway. That is what I do with mine. I cut across the driveway on an angle to prevent it from dragging.
gator.bigfoot is offline   Reply With Quote
Old 06-20-2018, 08:05 AM   #67
Elk Rapids , Michigan
Never, ever, have concrete work done while you're not home.
Notice the 3in step at the top of our porch stairs
matthewsx is offline   Reply With Quote
Old 06-20-2018, 09:05 AM   #68
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Indeed
Old 06-20-2018, 09:06 AM   #69
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I don’t follow - I have a propride hitch and WD bars
Old 06-20-2018, 09:12 AM   #70
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Nope - I do not own it - my property line is right up against that hedge line - if it were not there that approach would be easier - although you will find that pulling out and leaving at that angle is quite a chore - you have to get near that point of bottoming and do a repetitive shimmy thing to move the angle of the tail end of the trailer and TV to pull out at that angle - total PITA
Thankfully - I can hug super close to the hedge and JUST clear with a linear shot out - for some reason going back in that “just” amount is even more marginal - it’s all so close that much depends on tiny nuances
Good news is in all cases right now my tires are in the rain gutter so I feel pretty confident now I’ll be fine - I think
Gonna grab some lumber at lunch today I hope and get home and try
To say I’m obsessed about this now is an understatement - it’s a flaw I have
I’m feeling more and more better about this all though - feels more and more like a near miss at this point
Lesson will be learned and I think I’ll have a functioning and attractive driveway at the end of this
If I had remembered Sunday night to loosen the WD jacks (usually I would) I think my panic would have been less as I would have reached the gutters that night
We shall see
Big thanks everyone again - y’all are like therapy for my nerves on this. Indeed lessons will be learned from this.
Old 06-20-2018, 10:45 AM   #71
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
In HD now - getting a 2x10 and will get this all checked out today - fingers crossed
Old 06-20-2018, 06:42 PM   #72
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
With boards slightly above level of gutters - just barely clears. Like baaarrreeely - and my hitch buts didn’t contact either (they did a couple times before...
In talking to my other concrete buddy he sent me this message (photo)
The concrete guy will be out here Friday morning to meet with me
Old 06-20-2018, 08:30 PM   #73
DaveP's Avatar
2004 28' Classic
Monument , Colorado
PharmGeek,
Not trying to butt in and not sure if you saw my previous post, but I had a similar problem after changing the bottom of my driveway (post # 55). I use a different hitch in my receiver going into and out of my driveway. It has no drop below the receiver (straight out) and no weight distribution bars hanging down (or connected). It stopped the rear of my trailer from dragging (as the weight distribution hitch tries to keep the trailer and truck on the same plane) and (or course), there are no bars to drag. Cheap solution, but you have to put the weight distribution hitch back on when you get out in the street and take it off before you go back into the driveway. Anyway, it worked for my situation.
Good luck.
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
DaveP is offline   Reply With Quote
Old 06-20-2018, 08:54 PM   #74
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
A concrete topping on the existing concrete will not stay in place. The thin edges will crack and crumble in no time. Eventually all of the topping will come up, even if a bonding agent is used.
Cut, remove, replace is the best way.
Alan
Old 06-20-2018, 09:33 PM   #75
"Cloudsplitter"
Attachment 314671
Attachment 314672
Ok...stop right where you are, put a Lynx right behind the AS tires...have the 'Concrete' guy buy them.😂😳
Old 06-20-2018, 10:05 PM   #76
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
My buddy said the same thing - cut, remove, and replace about 4 feet worth should do the trick.
About changing the hitch - I did see your comment - are you familiar with the propride hitch? That is not easy to simply remove and put back on - - not an option
Btw - the WD bars now didn’t hit at all with the lumber so once we regrade - it should prove all good
- just have to see how the fix will play with my contractor and what he will agree to.
I haven’t ruled out the option of a lift kit either to be clear - gonna mull more about it.
Meeting the contractor on Friday
Old 06-20-2018, 10:22 PM   #77
Just thinking out side the box... But I assume you have a pickup?
There are vehicles (usually SUVs) with on board height adjustment like I have that can dynamically raise or lower the vehicle to get a wee bit more clearance at the other end of the trailer. Like a see-saw. I use to play these tricks pre-trailer lift, but no longer. Now I just use it as a cheat when hitching or leveling at a campsite.
Old 06-21-2018, 04:19 AM   #78
His proposed modification over the gutter will dam up the water and create a problem. It is also probably ON CITY PROPERTY, so you should have your survey handy when you meet with him.
Why did you cut that 10' long 2x10 down to the short length which is under the tires? You did not accomplish the mock-up which would have informed a wise and complete solution IMO.
Here is Post #12 -- click on the orange arrow to go back there and read the entire thread again -- there seems to be a communication or some other problem here:
Originally Posted by OTRA15 View Post
This should work for a test fit mock up IMO. I think I would start with longer planks, and a bit wider to give you some wiggle room. Maybe 2 2x10 10' long, with plenty of cut-offs to use as supports every 1/4 of the length. If you have any red bricks around, they would also work as supports.
If you can find any construction cedar 2x material [vs. CCA etc. pressure-treated lumber], you can use all the scraps as kindling for campsite fires, or in your Bonfire stove!
Really, this is getting ridiculous! About 6-8 people have made the same suggestion about using a longer plank as a test.
Why did you cut it down to that length? Are you intentionally trying to test everyone's patience?
Old 06-21-2018, 06:24 AM   #79
r carl's Avatar
Lin , Ne
Didn't you see the bottom pic in post 31? The truck height doesn't come into play here.
Old 06-21-2018, 06:37 AM   #80
r carl's Avatar
Lin , Ne
Pic in post 32 shows not enough dirt was removed so the poured concrete would be ground level, not grass level. Spacers above your axles will help you in other situations too.
Good Sam Roadside Assisstance-Good or not so good? flyingfishy On The Road... 27 05-16-2017 01:37 PM
More bad news Inland RV Center, In Commercial Listings 2 07-04-2008 10:47 AM
Bad news - Tire came apart Zeppelinium Tires 15 09-06-2006 09:36 PM
Bad Bad Things... (a new 454 Engine?) pillageTHENburn Mechanics Corner - Engines, Transmission & More... 24 12-19-2005 12:49 PM
Bad News... 05ModPod Our Community 34 01-30-2004 08:12 PM
