Old 06-21-2018, 06:58 AM   #81
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
Originally Posted by PharmGeek View Post
<<snip>>
About changing the hitch - I did see your comment - are you familiar with the propride hitch? That is not easy to simply remove and put back on - - not an option
Btw - the WD bars now didn’t hit at all with the lumber so once we regrade - it should prove all good
<<snip>>
Yep, forgot about the crank up tensioners. Mine are chain/snap up.
Sometimes my mouth (fingers in this case) work faster that my brain.
Glad you have worked out a solution to the slope problem!
Alan
Old 06-21-2018, 07:47 AM   #82
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
" Are you intentionally trying to test everyone's patience?"
LOL...no sir...I am not...I picked up some wood for like 12 bucks on the fly at lunch yesterday in my commute car...a small car that has no room for big boards, but I still wanted to try SOMETHING yesterday, because I myself am impatient - so cutting it up some allowed me to fit the boards in to try at least the slight elevation of the gutter area as a fix...which did give me clearance (barely)...proof of concept in one respect...
My contractor is bringing a bunch of wood (including longer pieces) tomorrow morning to look it all over and develop what we hope is a best strategy...
Yeah, every other driveway in the neighborhood has concrete in their gutters with a channel created...I doubt that is up to a code, but its clear that as far as enforcement goes, it is a non issue....although its easy to imagine the annoying situation where suddenly I would have an issue....
I have made no decision...I am not qualified in any of this (clearly)...I will wait to see what my contractor thinks is the best option and consider that....I have not discussed the lift kit route...but that is clearly another strong possibility...I forgot to measure how much more elevation the boards gave me...it looks to be about 2 inches...it may indeed be the lift kit route would solve this....but likely barely...ill measure that height when I get home (or ask my wife to do it this morning)...for sure though its very close so its not entirely clear that ALONE 2 and 7/8 inches would do it...although I think it would.
I need to do my own research on here today about the lift...I know some of you said its a no brainer but call me crazy, I just want to do my own reading on it a bit more before I pulled that trigger.
Keep in mind you all, I am juggling fiddling with this with full time parenting, I get home, I am not just fiddling with this driveway, I am making dinner for my 2 small kids, bathing them, reading books, etc etc...and THEN find a moment to think about this....doing the best I can, your patience is appreciated
PharmGeek is offline   Reply With Quote
Old 06-21-2018, 07:52 AM   #83
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Originally Posted by pteck View Post
Just thinking out side the box... But I assume you have a pickup?
There are vehicles (usually SUVs) with on board height adjustment like I have that can dynamically raise or lower the vehicle to get a wee bit more clearance at the other end of the trailer. Like a see-saw. I use to play these tricks pre-trailer lift, but no longer. Now I just use it as a cheat when hitching or leveling at a campsite.
Right..I hear ya...but go back and look at photos of my hitch setup...have no clearance...actually I have not emphasized much that on a couple approaches, as my truck tires dipped into the rain gutter, the hitch can and has contacted the new concrete..lowering the hitch at all just does not seem possibly without changing my propride hitch, which I have no plans to do....
Old 06-21-2018, 08:36 AM   #84
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
You will probably need at least 10' of board on each side. You may want to fill your water tank to account for future loads in the trailer when testing this out with the contractor.
If the boards work then spray some paint for future reference points on the ground. This will allow you to quickly just throw the boards down when you leave/arrive.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 06-21-2018, 08:48 AM   #85
Ray Eklund's Avatar
2019 27' International
2014 25' International
Fort Saunders , Wyoming
Otra15... Post #78. 100% on point. Great advice.
PharmGeek does not listen or read well. Try the simple before getting into more expensive mistakes later.
If the 2" lift of the board is not working... double it. Once you get the tow vehicle closer to the curb... solved. Write it down so you do not forget when done. Leveling blocks might work, cheap... seems to be your current choices. You can step up from one, two to three inches within minutes. Common sense trumps engineering this into a big headache.
You would have to purchase two packs of leveling blocks at Walmart.
There is no mystery here to be solved. The driveway is not the best for a very long trailer with no clearance. Even if this trailer was pulled UP the driveway, the bumper would, then, drag in the street.
This will be going from bad to worse soon... The video will sell well.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 06-21-2018, 08:59 AM   #86
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Here is what I think will be my last comment here, ‘you would be amazed at how much difference a 3” lift can make because of geometry’. Not only will that give you another three inches of clearance at the back of the trailer under normal hitching an towing, it will allow you to drop the front of the trailer another three inches in a pinch giving you another six inches in the back should you need it.
Old 06-21-2018, 08:59 AM   #87
Sag Harbor , New York
Thanks Ray.
Peter
PS -- OP/PG:
Haste Makes Waste!
Old 06-21-2018, 09:09 AM   #88
Ray Eklund's Avatar
Originally Posted by OTRA15 View Post
Thanks Ray.
Peter
A lift kit on the trailer would be the second option... to try. All you need is the bumper to clear by a fraction of an inch.
You can lift the shell off the axles 3", or use 3" of lumber. It may take several feet, four feet... try that first. A 12" wide board is easier to keep the tires of the trailer on track. Ten inches is going cheap again. You will then have to purchase 12" wide lumber. (Which may not be 12" wide if you measure.)
The plastic leveling blocks would do the same thing, but they tend to break in this kind of situation.
There are several owners that are trying to help. Do not have in your mind one cure to your problem. If the lumber does not work... build something with it.
Human Bean
Old 06-21-2018, 09:26 AM   #89
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
He'll get there, he's listening just multitasking. All brains are wired differently and we don't all take information in the same way. Even though the good advice came early in the thread he's got to sort it out and process it in his own way while beating himself up inside for being gone while the project was poured.
Remember he's the guy who had 3000 Posts before he even bought his first trailer and then gave us all the great reviews on what chairs to buy.
So pull out one of those chairs and sit by, it's almost solved and in the meantime we all get to hear more great ideas.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 06-21-2018, 10:16 AM   #90
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Beautiful driveway. Sounds like the contractor will come up with a fix. Looks like you are on a cul de sac and near the top? Drainage might be okay with a slot. Never had a lift kit but I would consider it also for that trailer. I have an older 30 and the back is low. Mine is parked year round so not a problem but was when I did pull it. A couple long boards with a cleat under them that fits in the gutter would probably work but concrete in the right place would be nice. Not sure it would have been better if you had been there. When they pour they go at it hard and there does not seem to be a way to try it ahead of time.
Old 06-21-2018, 10:32 AM   #91
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Wow this is why I don't post any problems I have with a trailer. Too many people that know everything and it must be done their way or it's wrong!
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
Old 06-21-2018, 10:36 AM   #92
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Drainage is a non issue...actually on my side of the culdesac there is no sewer opening...its on the opposite side...water actually pools on my side of the culdesac as it is, and simply spills over the street to the other side and into the rain drain....so from a practical standpoint, the rain gutters are aesthetic....from a legal standpoint, its always an issue although, every other driveway in the neighborhood are violating the rules although they often include a small channel to allow water to flow...through.
Lumber as a permanent solution seems entirely unattractive to me...I would only pursue that as a last ditch effort...which appears to not at all likely be required...
J. Morgan...if you do a lift kit, then pitch the front down some...wont it look weird or tow weird? I guess 3 inches higher from the lift then 3 inches from that unlevel pitch may not be noticeable for towing or aesthetically...that's a damn good point if that were to be true...kinda hard for me though without pulling the trigger on the lift first and only then to see precisely how much lift I get....
Old 06-21-2018, 10:40 AM   #93
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
no worries...I like to think of myself in this forum as a budding dumb teenager reaching out to get help from my parents...in this metaphor, my prefrontal cortex is not yet fully developed, so comprehension skills are always a factor that must be considered if objectivity is to be a thing.
Old 06-21-2018, 10:42 AM   #94
MWBishop's Avatar
Huntsville , Alabama
Hang in there Geek!
As you know, everything involving an AS trailer should be take your time and go slow.
2017 Airstream 26U Twin
2017 F250 Platinum
MWBishop is offline   Reply With Quote
Old 06-21-2018, 10:48 AM   #95
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
BTW, to hijack my own thread...our lafuma zero gravity chairs are continuing now almost 5 years of use to be ROCK SOLID and very enjoyable...I receive no funds from the company mind you - my "chair repetoir" now includes a portable hammock stand that a woman out of California made more or less especially for me, its called the "tensahedron hammock stand"....I need to do a post on just that for engineering nerds to chew on, as it is interesting.
Old 06-21-2018, 11:25 AM   #96
1962 28' Ambassador
Mesa , Arizona
Parm,
Loving it! You got this!Click image for larger version
Name:	Lafuma-Futura-Air-Comfort-Zero-Gravity-Recliner-Black-Frame-Coral-Blue-Air-Comfort-Fabric-0-2.jpeg
Hittenstiehl
Old 06-21-2018, 11:31 AM   #97
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
You need that tilt apparatus on your hitch!
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 06-21-2018, 11:31 AM   #98
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
New Driveway - Good News Bad News
Parm,
Loving it! You got this!Attachment 314718
Appreciate all the AS family here. Hittenstiehl you can be the supportive “cool” uncle in the metaphor if you like after Pappa Ray uses the switch on me after spilling paint in the garage.
“Hang in there baby Geek, growing up is hard, let’s take a ride in my corvette convertible and get some ice cream.”
Old 06-21-2018, 11:54 AM   #99
2007 27' International CCD FB
San Diego , California
Love the banter on this thread. If only all the tow vehicle threads were this fun.
I don't think he or anyone would suggest running a trailer at anything but level under tow. Just that you have the option, likely by relaxing the WD, to lift the other end for situations like this.
Like I mentioned earlier, prior to my lift, I use to have to do something similar. My vehicle allows me to lower the suspension 2", or raise 3", from the neutral position at the push of a button. So I would lower her down, to lift the rear of the trailer, when entering a steeper transition gas station in order to avoid dragging the rear.
No more with lift! No more dragging hitch. No more dragging rear. It's all gravy.
pteck is offline   Reply With Quote
Old 06-21-2018, 11:12 PM   #100
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Mickey Mouse fixes.
Hi, boards, spacers, lift kits, hitches, and on and on and on. Yes, these will work.
But, He just spent $6,000.00 for a new driveway so he wouldn't have to do all of this.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Good Sam Roadside Assisstance-Good or not so good? flyingfishy On The Road... 27 05-16-2017 01:37 PM
More bad news Inland RV Center, In Commercial Listings 2 07-04-2008 10:47 AM
Bad news - Tire came apart Zeppelinium Tires 15 09-06-2006 09:36 PM
Bad Bad Things... (a new 454 Engine?) pillageTHENburn Mechanics Corner - Engines, Transmission & More... 24 12-19-2005 12:49 PM
Bad News... 05ModPod Our Community 34 01-30-2004 08:12 PM
