I have a slow leak that look like fresh water. It is dripping from the cover of the tanks. It occurs without the pressure of the pump or city water. Is there away to check the pipe connections to the clean water tank without having to lift the airstream and removing the insulation cover?
From what I know, the air conditioner drain has a tube and the water should drip out from it near wheel wall.
I would assume the fellow members need to know exactly where you see the leak to better help you. When do you see the leak? Under what condition? No water city connection?
The Airconditioner was not in use and the leak is between the tires from the cover to the tanks. There is no pressure from the pump or city water as the leak occurs. We had driven across rough interstate highways out west. I’m afraid the tank cover and the insulation will have to be pulled to find it. WTB
