RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-20-2020, 11:23 AM   #1
2004 25' International CCD
Richmond , Rhode Island
Leak in the wall - where to start
2004 25’ International CCD
I’m the second owner, just brought it back to RI from AZ this summer. It is in really good shape. Earlier this summer, the previous owner had the roof sealed at the Tucson Airstream dealer. A new heat pump was installed several years ago.
I detected a leak the other day.
Thought it was the range exhaust vent.
I am in the process of replacing that - you’ll see blue painters tape holding a temporary cover in place.
It rained again today, I found it is still leaking. I've included a few photos of the situation - hoping to get some suggestions on where I should start!
Photo #1
I determined it is INSIDE the wall where the solar/battery control panel is.
See the red arrow - water was dripping on the inside of the wall just above where the arrow is pointing. Notice this is to the right (inside), left (outside) of the exhaust vent.
Photo #2
I inspected the outside rivets to the left of the vent - they appear to be in good shape.
Photo #3
View of the awning rail with the bead of sealant along the entire edge and sealant on each screw. Looks OK, but not 100% sure if the minor cracking is an issue.
Photo #4
Zoom in on the rail directly above the leak
Photo #5
Roof, showing the newer heat pump
ID:	381327   Click image for larger version
ID:	381329   Click image for larger version
lobsta is offline   Reply With Quote
Old 10-20-2020, 11:34 AM   #2
2009 34' Panamerica
2005 28' Classic
Still , in the thick of it
A pressure test should provide a better look where the leaks are coming from. Many dealer service centers have this machine and I know the factory service center has one too. It really makes tracking down the leaks far more efficient.
panamerican is offline   Reply With Quote
Old 10-20-2020, 11:44 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard 👍
I would cover that awning seam,(arrow in pic), with wide blue painters tape,(quick test) or Gorilla duct tape, (more sticky) and hose the seam directly with a moderate running hose, no spray.
Actually covering all suspected leaks, and removing one at a time until leak is revealed would help eliminate all possibilities.
Good Luck
"I prefer someone who burns the flag and then wraps themselves up in the Constitution over someone who burns the Constitution and then wraps themselves up in the flag.”
― Molly Ivins
Tahawus
Old 10-20-2020, 11:53 AM   #4
2018 25' International
Slidell , Louisiana
a little suction cup works great to find leaky rivets. Then Bob's tape trick on seams. I tape everything directly uphill from the place the leak presents. Use a level gauge on the inner skin ceiling as water can travel. Then I flow the water for 15 or 20 minutes. If no leak I untape a few places and continue till I find the source.
Brian
Old 10-20-2020, 12:06 PM   #5
2005 28' Classic
Nicholasville , Kentucky
Perfect timing on this sore subject, my 2005 Classic is leaking in two locations. Thanks for the suggestions, good luck on locating your leaks.
KYShelby is offline   Reply With Quote
Old 10-21-2020, 02:15 PM   #6
1976 31' Excella 500
Chappell Hill , Texas
My money is on picture #4 area. I think every so often you need to remove that mounting piece and redo it. Just recaulking the screw threads then over the heads may not do it. Same goes for under the awning arm brackets.
tbashin is offline   Reply With Quote
Old 10-21-2020, 07:39 PM   #7
Thanks all for the great suggestions!
Bob, I tried covering the rail with blue painters tape, but it didn't stick well (it was misty) - good idea to try duct tape. But I may just apply new sealant since I"m running out of warm days.
tbashin - after reading your comment, it seems like that's probably the best fix that would give me years of leak free service. But it feels like a big job to take on with so few warm weekends left in the year.
I am planning on resealing the awning rail seam this weekend.
Old 10-21-2020, 07:56 PM   #8
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
Here's an older thread on using the suction cup that you may find useful.
https://www.airforums.com/forums/f38...ts-135769.html
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
A/C start-up w/ soft start Pimms Electrical - Systems, Generators, Batteries & Solar 21 06-11-2020 10:55 AM
AC Easy Start On 110V Wall Outlet AlanMcD Airstream Lifestyle 3 06-27-2019 05:47 PM
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 13 06-16-2017 08:36 AM
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 08:47 PM
