Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 10-10-2020, 04:36 PM   #1
Golden , Colorado
1972 door latch/lock help
I purchased a 1972 overlander 27’ and it has the original door lock and latch except the seller lost the keys and he had just rebuilt it. So, I have to replace it anyway and want something more secure so I’m
Looking for advice on which lock/latch system is best.
The lock/latch is rectangular and mounted horizontal, most new ones are more square shaped.
Any thoughts on how I accommodate a newer lock?
Emmaggy is offline   Reply With Quote
Old 10-10-2020, 08:53 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
There are lots of threads on this topic. Search for "KT lock replacement," and you should see many.
Basically, if you want to go to a different lock, there is no drop-in replacement. You can patch the existing hole, and then cut a new hole and make other mods to the door frame to accommodate a more conventional lock, or you can completely re-skin your door, if you want to spend a lot of time on the project.
A kit is sold by online suppliers like inlandRV.com or outofdoorsmart.com to facilitate the patch, or you could buy a $35 latch off of eBay, and cut your own patches from a scrap of aluminum.
Another option in your case would be to have a locksmith make you a new ket to the "rebuilt" latch you have, and install a dead bolt to make it more secure. A fairly low impact kit is available from Vintage trailer supply.
good luck!
Old 10-22-2020, 05:07 PM   #3
New Braunfels , Texas
Emmaggy, If you decided to go with a new replacement lock/latch, I would be interested in purchasing the original.
JHET is offline   Reply With Quote
Convert vintage door latch to modern double rotary latch & strike? Mixter Doors & Locks 5 02-19-2017 09:12 AM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
Help Help Help - Door Lock Issues HowieE Doors & Locks 1 09-08-2009 09:57 AM
Door lock/latch problems Stefrobrts Doors & Locks 4 04-28-2003 11:12 AM
Door latch/lock McGill Doors & Locks 0 06-25-2002 06:51 PM
