Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 01-23-2018, 03:26 PM   #1
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
2017 30' AS - Lithium batteries located under rear bed & tongue weight
Hi All,
I am planning my Lithium install with the Lewster in the spring.... planning on 600 amp hours of Victron 'powa' and the batteries and hybrid inverter will be installed in my 2017 30' international under the rear queen bed - see attached picture - Blue shaded area has been designated for batteries + inverter + a few ancillaries.
Based on my back of the envelope math, I am looking at something like:
minus (-) ~92lbs from the battery box (remove stock Interstate Group 24s)
add (+) ~275lbs in the center isle under the rear queen bed (2x 300ah Victron lithiums + 3000VA hybrid inverter)
My tongue weight has been measured at 990lbs on the CAT Scales with weight distribution applied and ready for camping. So static tongue weight is currently sitting at perhaps 1,100 lbs without WD (I'd need to check my CAT scale numbers to be certain). GVWR for the 2017 30' international is 8,800 lbs.
Just curious what others with similar installs (batteries under the rear queen bed on a 30') have measured in terms of overall reduction of tongue weight given the weight shift. I am thinking 150-200lbs when the dust settles, which brings me down to the ~10% of GVWR range when fully loaded and no WD applied.
I currently use an equalizer hitch but will likely make the move to a propride for what it is worth.
Thanks Airforums!
wulfraat is offline   Reply With Quote
Old 01-23-2018, 03:55 PM   #2
1988 Argosy 32
Lomita , California
Can't the lith bat's burn ?.
Wolfe is offline   Reply With Quote
Old 01-23-2018, 04:12 PM   #3
Naples , Florida
Noooope! Victron lithiums never burn (at least I have never heard of one burning). They have internal mechanisms that prevent them from getting too hot. Go over that threshold and they shut down.
lewster
Old 01-24-2018, 09:58 AM   #4
1988 Argosy 32
Lomita , California
O.K. thank you.
Tow vehicle Tongue Weight vs. Trailer Tongue Weight KeepPedaling Hitches, Couplers & Balls 10 03-23-2016 12:33 PM
Safety question about battery located under the bed bkahler General Motorhome Topics 47 01-24-2013 10:22 AM
Rear Queen Bed Platform/under bed storage AluminumGirl Cabinets, Counter Tops & Furnishings 0 04-18-2010 11:57 PM
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
