01-14-2023, 08:18 AM
#61
2024 30' Classic
PORT SAINT LUCIE
, FL
Originally Posted by Merlintiaga
Super jelly of the Truma! I would paint it. IMO, A water heater is something that should blend in, not be a focal point.
(which is why I need a Truma. I spend too much negative energy on the Girard)
The black is non-paintable. The white is paintable.
06-27-2023, 08:01 AM
#62
2023 25' Flying Cloud
West Olive
, Michigan
Both black and white panels are paintable. Both panels are PC (polycarbonate) which is very paintable.
That said, black panels may need a white primer applied to minimize the coats of silver paint used.
Attached is an image of my black Truma door painted primer plus 3 coats of silver.
07-07-2023, 05:16 AM
#63
2024 30' Classic
PORT SAINT LUCIE
, FL
All I can say is the manual states paint only the white panels. I took it literally. Looks like you did ok.
08-15-2023, 07:57 PM
#64
2022 16' Bambi
Upper Holland
, Pennsylvania
not $1,200.00——Truma comfort cost is over $3,000.00
08-15-2023, 10:35 PM
#65
1971 27' Overlander
2023 28' Flying Cloud
Monmouth
, Oregon
Cold showers are good for stress, circulation, and a hit of adrenaline.
At least this is what I tell myself when that cold water hits during a Navy shower.
I wash my feet first with the cold water.
“Let’s be careful out there.”
08-16-2023, 03:47 AM
#66
North AL
, Alabama
Every time I see this thread pop back to the top, I think the title really should be: "Girard On-Demand Water Heater SUCKS for Boondocking".
Because it really works well for most people when you have access to a water connection.
It would be great if Airstream would offer an optional "Boondockers" package with a traditional tanked water heater and propane refrigerator to satisfy that small but vocal segment of the market.
08-16-2023, 05:24 AM
#67
2023 23' International
Macon
, Georgia
Or, just offer a Truma AquaGo as an upgrade option. Problem solved...
08-16-2023, 12:54 PM
#68
2022 25' International
Savage
Or AS switch to all Truma AquaGo Plus as the supplier of choice. Speaking from experience of now having a Truma, it is far far superior to the Girard. I had to spend $2,500 for the change, and although I would recommend that everyone consider this “upgrade”, I would rather have had it from the factory. The Truma is almost instant hot water. I think that’s how it’s supposed to work.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
08-17-2023, 11:14 AM
#69
2023 27' Flying Cloud
Beaufort
, South Carolina
Girard Temp Too High
I have the control panel on the tankless water heater set as low as it will go (95) and the water temperature is still too hot. The display steady increases from 95 up to about 110. Any ideas on how to remedy this other than install a conventional tank water heater?
08-17-2023, 12:19 PM
#70
North AL
, Alabama
If the control panel isn't holding the set-point, it sounds like you have a faulty component somewhere. Definitely recommend calling Girard
08-17-2023, 06:09 PM
#71
1988 32' Excella
Robbinsville
, New Jersey
Could also be an issue with the incoming water temp being to high.
08-17-2023, 10:54 PM
#72
North AL
, Alabama
Here's what the manual says to troubleshoot:
Customer cannot control the temperature from set point, get too hot and then maybe too cold.
- Purge water lines.
- Water pressure to low. Some campgrounds have the water pressure very low. - - Try putting water in the fresh water tank
and running off the pump.
- Set temperature lower.
- Possible partial by-pass opened.
- Possible, outside shower faucets turned on and just the shower button closed. Same for inside shower.
- Possible, outlet temperature probe, defective. Have not confirmed this.
- Replace water heater.
https://www.rvupgradestore.com/v/vsp...e%20Manual.pdf
08-18-2023, 04:49 AM
#73
2023 27' Globetrotter
Winder
, Georgia
I had the same thing happen earlier this summer. I honestly thing it had to do with incoming water temp. We were in 90 degree plus heat. Water out of the spigot was warm even after running for several minutes. The water heater cannot then regulate properly. My previous trip just a few weeks earlier was at a higher elevation area and much cooler.
