08-26-2021, 06:24 AM
2020 28' Flying Cloud
Jax Beach
Valterra cap hard to open
I added a Valterra knive style twist on valve to my FC28 as an added "safety feature" for tank dumping. The added valve swivels on the OEM Airstream fitting, making it easy to move the valve to get at both black and gray tank handles. The issue I have is that the Valterra cap is very hard to remove, especially since one hand needs to keep the added valve from swiveling while the other tries to remove the cap. I added vaseline to the seal area to be sure that it wasn't the seal that was keeping the cap from moving. I have a spanner that works for the slinky, but the valterra cap doesn't have the big lugs to grip.
Any suggestions on how to make the cap easier to remove?
Thanks!
08-26-2021, 06:29 AM
diesel maniac
Airstream - Other
Tucson
, AZ
Brian
08-26-2021, 07:06 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Try a set of the little levers Vallteria sells for their fittings. Try a little water pump lubricant from a pool supply store on the offending surfaces.. the levers do work well.
08-26-2021, 07:10 AM
2019 25' International
Providence
, Senior Electrical Engineer
Originally Posted by ITSNO60
A link:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
We have this and it is leaps and bounds over the orginal.
08-26-2021, 09:13 AM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
we spray our periodically with silicone which make it a lot easier
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
08-26-2021, 09:16 AM
2019 25' Flying Cloud
Houston
Do you have a link to the levers please?
08-26-2021, 11:01 AM
Houston
Awesome. Thanks.
08-26-2021, 01:44 PM
Tampa
I have a set of those levers and they leave something to be desired. First, they are designed to fit one thing, the hose. Trying to remove the drain cap or latch on a fitting doesn't work so well because the handle hits the trailer before you can hook the tabs in the wrench.
Not sure why you get two wrenches since they don't work like pliers.
I guess you can use one clockwise and the other counterclockwise.
They only fit one way, if you can hook the nub, great.
But they're $10 so why not?
I've switched to the big oil filter wrench + a clear extension so I can "get a grip".
08-26-2021, 02:01 PM
Houston
Hmm. I already own the oil filter wrench. Thanks for the suggestion.
08-26-2021, 06:40 PM
Jax Beach
Molly's Dad is right. The Camco spanner wrenches only work on the hose, and I never needed one to manage the hoses. I ordered the Valterra cap with the handle, and the Duraflex cap with the ears. See which works better for me. I didn't really want to carry another tool, and have to keep it handy for each time I need to dump.
Thanks for all the responses!
08-26-2021, 07:17 PM
diesel maniac
Airstream - Other
Tucson
, AZ
Another benefit to the one with the handle is you don't get your hand wet if there has been any seepage.
Brian
08-26-2021, 07:38 PM
2017 25' International
West Lake Hills
The wrench works but it can be messy. I’m always latex-gloved so the messiness is less of an issue if I need to use the wrench.
However, I really like the cap with the handle linked by kittmaster and just ordered one.
08-27-2021, 07:55 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Our solution....
