I replaced that cheap plastic drain valve on my fresh water tank immediately after I purchased my AS. The OEM was cracked and sloppily-repaired with Goop of some sort.
I replaced it with a short section of clear pvc hose and a brass silcock. The tank outlet was 1/2” if I recall correctly, but it was a hose-barb…onto which I clamped a short piece of clear pvc hose leading to another barb I intalled onto the silcock, then mounted the silcock in the original, factory position.
