Old 10-18-2021, 10:42 AM   #1
2002 25' Classic
Kalama , Washington
TST-507-FT users
We're installing tire monitoring at long last, for both TV and trailer. The directions offer two means of mating sensors to the display monitor (touching the monitor with each before mounting, or the same after loose mounting). Does one way better the other?
Apparently, sensor batteries become powered by tightening sensors onto the valve stems. What do you recommend I do during months of trailer storage re sensor battery life? Since expected battery life is only a year, it seems wasteful to let them deplete in storage. Thoughts?
nwclassic is offline   Reply With Quote
Old 10-18-2021, 12:18 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I found the instructions a little difficult to follow and as a result I like to do the sensors before mounting while sitting in front of the video on the computer. The sensors put out enough signal to program even when not mounted. One way to do storage is to remove the sensors and store them in a little box with labels for position. I left mine on and changed batteries after 2 years. I tossed the batteries I got from Amazon and got the batteries that work from TST.
Old 10-19-2021, 12:05 PM   #3
2002 25' Classic
Kalama , Washington
Thanks, Bill. I did as you did. Next task is the repeater install. Haven't finalized a location yet, but will insert an online switch to avoid a ghost load when unplugged.
Old 10-20-2021, 01:25 PM   #4
1988 25' Excella
1987 32' Excella
I did not install the repeater. My system did not need it.
TPMS- Expandability of TST-507-FT-4-C Brawny Tires 0 06-24-2021 10:36 AM
TST 507 flow thru or RV Tom Servo Tires 11 03-19-2021 06:03 AM
TST 507 Tire Monitoring System cactusjk Airstream Classifieds 0 06-17-2017 08:25 AM
TST 507 TPMS Repeater Question Ridgerunner3 Tires 12 12-29-2016 12:23 PM
TST 507 TPMS Battery Replacement Siegmann Tires 0 03-15-2016 09:12 PM
