Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 12-09-2016, 12:55 PM   #1
2011 27 FB International
Oakton , Virginia
Michelin LTX M/S tires
I have Michelin LTX M/S tires, 225 75 R16, on my 2014 30' International. I inflate at 80psi cold, which is the max pressure listed on the sidewall. No problems so far with about 20 K miles on the tires. I have the same tires on my tow vehicle (F250) but they are 275 65 R20's. The recommended inflation pressure on the truck tires is 65 PSI although I inflate to 70. The max pressure is 80 psi. I have been advised to use 80 psi on the trailer tires, which I guess is due to the potential need to provide weight support if the trailer is fully loaded. I'm just trying to confirm that I'm doing the right thing. Any comments?
jtbarbee is offline   Reply With Quote
Old 12-09-2016, 03:26 PM   #2
dznf0g's Avatar
Oswego , Illinois
Yes, you are doing it right, IMO. That said my 30' Classic is somewhat heavier than your Intl., but I played with pressures for a couple years and took the advice of the tire engineers who post here. I settled in at 80 psi and have no I'll effects on the AS.
-Rich-
Old 12-09-2016, 03:48 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I run mine at 70lbs on the trailer... (about 7,000lbs loaded)... even then the ride seems a little harsh. Always picking cushions off the ground after we've moved locations...
wulfraat is offline   Reply With Quote
Old 12-09-2016, 06:28 PM   #4
Andrew T's Avatar
2019 27' Tommy Bahama
London , Ontario
If you like send me an email and I can send you a column on how to weigh your combination and determine your correct tire pressure. Andy@canamrv.ca
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 12-09-2016, 07:41 PM   #5
Vintage Kin
Fort Worth , Texas
Take Andy up on his offer.
Old 12-09-2016, 07:55 PM   #6
dznf0g's Avatar
Oswego , Illinois
Unless you listen to actual tire engineers.
-Rich-
Old 12-09-2016, 08:39 PM   #7
white laker's Avatar
2008 34' Classic S/O
Arnprior , Ontario
nope not gonna do it................
enjoy your tires and have a safe trip. All the best
Pete
Pete Crook
"Put it all behind you!"
S/OS#88
white laker is offline   Reply With Quote
Old 12-10-2016, 11:33 AM   #8
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
75 on the ram, 16" michelins on 31' classic with 72 lbs pressure,
Old 12-10-2016, 11:59 AM   #9
Refugee from Napa, CA
Photobum's Avatar
2015 25' Flying Cloud
Formerly Napa , On the road
Tires
I run all my Michellins at sixty-five pounds, tow vehicle with trailer.
Photobum is offline   Reply With Quote
Old 12-10-2016, 02:17 PM   #10
2016 30' Flying Cloud
Blenheim Ontario , Ontario
When I replace my Hancook 'O.E.M tires, I want tires that I can run all year 'round, like I did with my 4-Runner using General 'ATS.
So are the Michelins winter rated?
Like with a snowflake on the sidewall?
(The reason is on another previous post)
MelGoddard is offline   Reply With Quote
Old 12-10-2016, 04:35 PM   #11
CruizinDux's Avatar
Washington , Missouri
This is a very long thread that started as a discussion of 15 & GYM' > 16 with Michelin, but has morphed (as long thread do) to include ST vs LT and the use of inflation charts for the weight of your rig and even per wheel to name a few off topics. The inflation discussion meanders but basically starts @ post #100
I've made it to post 329 and have a way to go.
http://www.airforums.com/forums/f465...s-69297-8.html
CruizinDux is offline   Reply With Quote
Old 12-10-2016, 05:38 PM   #12
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
80 then 70 now 65
I have the same tires on our AS. I wish I could get them for my Tundra, but when I re-tired they didn't make them in my size.
We were advised by the dealer (Colonial) to inflate to 80 psi. We did. Like others, we found things getting pretty shaken up inside. I went to 70. Some improvement and no noticeable change in wear. I'm now running at 65 psi. I don't think I'll go lower.
After 30,000 miles on the tires, the only way I know they have worn is that I had to adjust my X chocks once. The tread is showing even wear across the tires. That suggests to me that the inflation I am using supports the load evenly.
Like others have said, tapping expert advice for your specific trailer - which is likely much heavier than ours - is a great idea.
GammaDog is offline   Reply With Quote
Old 12-11-2016, 06:25 AM   #13
"You can ALWAYS tell an Engineer, but you CAN'T tell them much"!
Trailer Trash......."
Old 12-11-2016, 07:11 AM   #14
r carl's Avatar
Lin , Ne
You mean the guy's that gave us the great ST tires? No thanks...
Old 12-11-2016, 08:28 AM   #15
Milan , Illinois
Max pressure is for trailer tires - ST's - not truck tires LT's. Truck tires should be inflated for the weight per axle. Michelin web site has a psi charts for their tires used as trailer tires and you will find your recommended psi some where near 60 psi. As to the damage done for running at max, IMO it is long term stress on the trailer and uneven tire wear, center treads wearing faster. I noticed visible improvements on interior rivet popping and less loose items tossed around the trailer when I went from 72 to 60psi on my 25'
aswbe is offline   Reply With Quote
Old 12-11-2016, 08:43 AM   #16
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I know they used to, but I cannot find that info anymore.
Larry
lsbrodsky is offline   Reply With Quote
Old 12-11-2016, 09:02 AM   #17
lsbrodsky's Avatar
http://www.michelintruck.com/assets/...k_Sept2011.pdf
Found it here.
Larry
Old 12-11-2016, 09:31 AM   #18
2014 27' FB International
Clearwater , Florida
AutoCrosser Trick
I have used the white liquid shoe polish stripe across the tread process to determine perfect tire pressure on many vehicle tire applications.
Vehicle manufactures' recommended pressures are nominally lower than tire sidewall maximum pressures. Sidewall maximum pressures are usually at tire maximum load weights.
All that said. Installing a tire with a higher load rating than stock will allow you to run a tire pressure somewhere between vehicle manufacturers' recommended pressure and new sidewall max. To determine that exact pressure, paint a couple of stripes of white shoe polish across the tread. Note the current tire pressure, go for a short drive with left and right turns, stop and inspect the stripe. Stripes showing tire edge wear need more air, stripes showing center wear Can lose some air. This process works for all trailers cars and trucks.
Good luck.
ChuckFeldt is offline   Reply With Quote
Old 12-11-2016, 10:27 AM   #19
2000 34' Limited
1985 25' Sovereign
LaGrange Highlands , Illinois
All tires on tandem axles should be at max. It is not the weight problem it is when U turn and the scuffing of the tire that will ripe the cords out of place. Not when U turn how the tire bends, that is what what rips a tire apart. As for UR TV. the tires do not scuff because of the distance between the front and the rear. I pull a 34' AS with 1997 F-250 same tires as UR trailer and get around 70,000 miles before replacing as long as U rotate every 7,000-10,000 miles. Been towing for 40 + years.
2000 34' limited #12,500 1997 F-250 349,000 miles and still going.
rmatkovich is offline   Reply With Quote
Old 12-12-2016, 02:12 PM   #20
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I run 65 psi in my LT tires on my Classic 30.
I wonder if I should pump them om up to 80 PSI...
The tire placard on the side of the trailer says 65 psi and I have never had any problems with that pressure- no noticeable wear- even tread wear-
The tires still look new after 1 year 3 months and 10,000 miles.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
16" Sendel Wheels & 16" Michelin LTX Tires Ray Eklund Tires 688 03-02-2023 04:47 PM
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
16" SenDel Wheels and Michelin LTX Tires Jcoop Airstream Classifieds 2 01-19-2014 08:37 PM
Michelin LTX M/S tires... Dwight Tires 7 01-14-2010 05:21 PM
