Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 07-13-2008, 11:51 PM   #1
1967 26' Overlander
Fairbanks , Alaska
Axle shipping weight
Can anyone tell me the actual shipping weight of 3200# Henschen axles with wheels and shocks?
Fishbone is offline   Reply With Quote
Old 07-14-2008, 04:58 AM   #2
Retired.
. , At Large
Axles are about 250 pounds each, shocks are about 5 pounds each, and wheels depends on aluminum or steel wheels.
Old 07-14-2008, 07:31 AM   #3
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Phoney
I bet if U would PM Andy at Inland RV's he can tell ya what they weigh cause he ships enough of them. He is the only dealer for Henshen in the USA.
Roger
Mikethefixit is offline   Reply With Quote
Old 07-14-2008, 11:14 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Call Henschen 937 596-6125
Why are you including the Wheels in your question? Axles are sold Hub to Hub and do not include the wheels or the shocks.
2004 Excursion 4x4
Old 07-14-2008, 02:39 PM   #5
1967 26' Overlander
Fairbanks , Alaska
Good point I meant hubs.
Old 07-14-2008, 02:57 PM   #6
Wabbiteer's Avatar
Jupiter , Florida
Remember the shipping weight must include pallet and banding and about a zillion feet of duct tape holding the bags of lug bolts to the assembly...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 07-14-2008, 03:09 PM   #7
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I think a mistake was made, but
Terry, in my opinion, gave you the best answer @250 lbs each loaded axle.
My axles came strapped together just as pictured below - No pallet.
But I just now pulled out the freight slip for my Overlander's TWO axles from Andy, and the "TTL WEIGHT LBS." was listed at 276.
Now I was missing the promised Grade-8 hardware, but 224 lbs for the addition seems a bit high...
For estimating purposes, go with Terry & budget a 500 pound freight charge.
Tom
Old 07-14-2008, 03:30 PM   #8
Do you think this is an important repair on a 1966 Caravel? Andy has suggested it but he has not seen it, looking for other opinions.
mstratton is offline   Reply With Quote
Old 07-14-2008, 03:42 PM   #9
TomW's Avatar
1967 26' Overlander
Camp first
antmagrat,
I remember the angst you are experiencing now. I know nothing about your Airstream's condition.
My recommendation, for you, is to get your Caravel camp-ready, and go out and use it for several trips. If you decide you like camping AND you think camping in a '66 Airstream Caravel is the best way to do it, then replace your axle.
You more than likely have the original axle & it is beating up your Airstream.
But if you don't like the whole experience, why waste your money? Vintage Caravels are extremely desirable, and you can sell it for big bucks as is.
Tom
Old 07-14-2008, 03:43 PM   #10
Retired.
. , At Large
42 year old axles are almost certainly gonners. Don't believe people when they tell you life begins at 40...
Old 07-14-2008, 05:44 PM   #11
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
You'll soon learn that Andy's opinion has a lot of years and experience behind it. You might do better searching somewhere else, for less money, but if your time and energy is valuable one phone call to Andy and you got what you need and the parts you need. Then you can spend your searching time on something else.
NevadaGeo is offline   Reply With Quote
Old 07-15-2008, 01:45 PM   #12
1976 24' Argosy 24
1999 30' Excella 1000
White Haven , Pennsylvania
Two 3500lb dexters came on a pallet. Shipping weight listed as 298lbs. Not as heavy as thought they would be. G
Gkiesel is offline   Reply With Quote
Old 07-15-2008, 02:10 PM   #13
Bare axles are about 145 pounds, each.
Complete axles weigh about 240 pounds, each.
Freight lines will also add the weight of the pallet, as well.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-15-2008, 03:15 PM   #14
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
This is our 1965 Caravel on October 27th, 2002. We didn't know at the time that old axles were a problem. Had we known, we would have changed it and not had this problem.
Old 07-15-2008, 05:05 PM   #15
We have cautioned and cautioned owners that the Caravel and Bami axles will fail, but when they do, it will never be in your front yard.
At this point, we are shipping replacements for them at the rate of better than one a week, and about half of that time, it's because the trailer is stranded because the axle failed.
Not what anyone really wants to hear, but the word needs to get out, big time, so that others don't suffer the consequences.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-16-2008, 01:25 PM   #16
1976 24' Argosy 24
Andy, What was it about the Caravel and Bambi axles that make them prone to fail. Is it just the age, or were they undersized from the get go?
Old 07-16-2008, 01:35 PM   #17
Retired.
. , At Large
Andy is on vacation for a couple of weeks, but the spindles on the trailers were not large enough for the weight that was placed upon them.
Old 07-16-2008, 03:15 PM   #18
1976 25' Caravanner
kingston , Washington
I ordered and receive axels from Andy and his folks. They were perfect fits. Also got the brake assemblies. They came strapped to a pallet. They were sent by UPS Freight. Something to remember. UPS charges $72 just for the privilege (?) of delivering to your residence - over and above the regular freight charges. So if you have a friend that has a business, have them delivered there and pick them up.
jim kolhoff is offline   Reply With Quote
Old 07-17-2008, 10:28 PM   #19
1967 26' Overlander
Fairbanks , Alaska
Jim,
I wonder if you have a picture of the axles on the pallet. Was it a standard 4x4 pallet and did the axle hang over the ends? Were all the parts (bolts) there as promised. I will be dragging mine to Indianola as soon as possible and hope to moor a boat in the marina in front of the Inn.
Old 07-18-2008, 02:25 AM   #20
Originally Posted by phoney View Post
Jim,
I assure you that an axle that's about 7 feet wide, is going to hang over the side of a 4 foot pallet, no matter how you slice it.
Freight lines today, have the game. All consumers can do is cope the best you can.
Andy Rogozinski
Inland RV Center
Corona, CA
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Axle Weight Ratings Gkiesel Axles 7 06-03-2008 02:01 PM
trailer/tow vehicle axle weight regs sumfari Local Regs & Licensing 2 02-15-2008 05:43 PM
Axle weight ratings Lumatic Axles 20 05-15-2007 10:16 AM
Front Axle weight alfalsetto Airstream Motorhome Forums 0 02-24-2004 10:33 PM
