Old 07-28-2020, 04:33 PM   #1
Airstream87's Avatar
1987 29' Sovereign
Huntsville , Alabama
Penguin 2 condensation not coming out drain line
Have factory installed (2012) P2 (87 Sovereign) that has always dripped from wall drip line, finally got 30 amp power installed at home and turned on AC, no water from road side drip line but water coming from roof curb side of unit. Blew (not compressor) into drip line and didn't clear. Looks like P2 drip cups are installed. Trailer isn't completely level but close, never had issue at campgrounds, any suggestions?
Airstream87 is offline   Reply With Quote
Old 07-28-2020, 07:53 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
My P2 on my 2017 clogged up after 3 years in service. I had some water coming out via the plumbed drain / wheel well but a larger amount of water snaked down the interior skin and out the belly pan.
I blew out the lines from above (using compressor). That seemed to solve the issue. I also ran a weed whacked line up the drain tube but it was clear.
I plan to go up top and check out the drain pans (2 small units) on the exterior unit to ensure they are truly clear. I will also seal up the foam gasket with silkaflex or dicor to ensure no water from the outside gets into the coach where the 1/2 inch drain tube enters....
wulfraat is offline   Reply With Quote
Old 07-28-2020, 10:40 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Drain pan could be cracked. Can you remove the interior cover to inspect?
Old 07-30-2020, 06:39 AM   #4
1987 29' Sovereign
Have not removed anything inside, could you be a bit more specific as to what can be removed to inspect?
Old 07-30-2020, 06:40 AM   #5
1987 29' Sovereign
I ran weed whacker line as far as I could but can't tell how far.
Old 07-30-2020, 07:00 AM   #6
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Re insert line, mark line with tape when it stops feeding in pull back out and measure length.
GCinSC2 is offline   Reply With Quote
Old 07-30-2020, 07:16 AM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
From memory: Remove AC blower vents on interior AC housing. You will see some screws holding the housing to the body of the AC. Remove housing and you will see the drip pan. My trip pan was cracked where the drain line entered the drip pan. This also caused the housing to leak. I sealed it with silicone. I did not remove the drip pan.
Penguin I to Penguin II drain pan? HiJoeSilver General Repair Forum 1 05-25-2015 04:51 AM
Dometic Penguin condensation drain leak Larry C Furnaces, Heaters, Fireplaces & Air Conditioning 18 02-15-2015 12:28 PM
water coming out pressure regualtor drain line when on city water txstreamer Fresh Water Systems 7 09-16-2010 03:07 PM
A/C Condensation Line - location and size tubing nmbosa Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-06-2010 05:45 PM
Condensation Coming Through Vista View Norm1234 Windows & Screens 8 11-13-2009 11:35 AM
