Hi - I have a 2007 31' Classic with a Atwood 8535-IV furnace. Last month it stopped working properly - would run for about two minutes blowing cold air, and then quit. The circuit board indicated a no.1 fault (Air flow/Limit Fault). I dismantled the furnace blower (from the outside, without removing the furnace) and discovered that the problem was the sail switch was improperly placed, and rubbing against the outside housing (sticking, in other words). I fixed that, and all is good now.
Do you know what model furnace you have? If it is similar to mine, I might be able to walk you thru a repair.
Paul
