Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 04-07-2016, 09:43 PM   #1
2000 30' Excella
Tucson , Arizona
Problem with refrigerator
Freezer works good. Refrigerator works for 1 1/2 days then stops cooling.
Any solutions?
Thanks in advance
winston10 is offline   Reply With Quote
Old 04-08-2016, 07:18 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Sounds like bad connections on the circuit board. Disconnect each connection, clean and reconnect.
Old 04-08-2016, 08:28 AM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Also - there is DEFROSTING
I live in beautiful coastal Virginia - 99% humidity any time the temperature goes above 70 degrees.
I knew that almost all RV refrigerators need to be defrosted periodically, but I've run into a lot of younger people who simply never had an old refrigerator and can't imagine black and white TV's or computer monitors. They wonder what that huge lump of ice is in the top back side of their refrigerators and why the unit seems to not be cooling as well as it used to.
An hour later, after removing all of the food, turning off the fridge, filling a bucket with Ice sheets and dripping water and using a hair dryer to break up the icebergs - their refrigerator is ready to work again, and work WELL.
Old 04-08-2016, 04:04 PM   #4
2000 30' Excella
Tucson , Arizona
problem with refrigerator
I will clean all electrical connections tomorrow. Thanks.
No ice build up,checked that one.
Doesn't matter if its on shoreline or propane. After 1 1/2 days it stops cooling.
Temp outside was 98 ( Death Valley) That was on propane.
Parker,AZ temp 95 shoreline power same thing.
Trailer was maybe off 1/4 bubble.
Any thing else I could check?
Old 04-08-2016, 04:48 PM   #5
Lets travel's Avatar
2014 30' Classic
Fayetteville , North Carolina
Your not getting enough airflow behind the Frig. One of the draw backs on this type of Frig.
Lets travel is offline   Reply With Quote
Old 04-08-2016, 05:11 PM   #6
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
Palm Desert , California
I agree. Same thing happened to me in Palm Springs last summer. I left the access door propped open a bit and the refrigerator section got cool.
CaCraig is offline   Reply With Quote
Old 04-08-2016, 08:14 PM   #7
2000 30' Excella
Tucson , Arizona
This could be the problem. When we were in Death valley their was not a pine needle flickering.Dead still. Parker the same.
Anything else it could be?
Old 04-08-2016, 10:44 PM   #8
I should have looked at the location. Air circulation sounds right. Simple to verify - just open the door. Some people have added a 12 volt computer fan to force more air through the compartment. Do a SEARCH for overheating refrigerator.
Old 04-08-2016, 11:10 PM   #9
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
If you mount a computer fan, mount it so that it is blowing out the exit vent, not blowing in the air entrance vent. Air is pulled very easily. Doesn't push well. It tends to compress.
Wind is drawn to low pressure areas from high pressure areas.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 04-10-2016, 09:50 AM   #10
2000 30' Excella
Tucson , Arizona
Thanks for the advice.Next time out I will try it with the door open.
Old 04-10-2016, 10:39 AM   #11
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Excessive hot humid conditions I prop my two exterior doors open with a couple of wooden pencils. Seems to help the temp stay more consistent thru the day.
MICHAEL
Old 04-10-2016, 07:48 PM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The OP states the refer stops working after a day and a half, I would not think it would be an air flow problem.
It is not clear whether when on gas the burner goes off or the heating element shuts down.
If the plenum on the back of the refer is not getting hot. Then the heat source is not functioning on either gas or electric.
Both the gas and electric functions are both controlled by the circuit board. The board may have an intermittent problem or it could be just the connections.
Check to see if the plenum is getting hot let us know what you find.
Old 04-11-2016, 05:50 PM   #13
2000 30' Excella
Tucson , Arizona
TG,
Dumb question coming up. Where is the circuit board located? Is it on the left side? Cleaned all connections that I can see.It is running now,freezer is getting cold & fridge dropped down 10 degrees.I will check it tomorrow.
Old 04-11-2016, 06:21 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It was an educated guess that your refer is new enough to have a circuit board control.
Not knowing the model number I can't answer the question. There are PDF files on the Internet where you could get a full printout of the manual for your model.
You may have resolved the issue when you cleaned the connections you found.
Let us know if it runs more than a day or so.
Old 04-11-2016, 07:38 PM   #15
2000 30' Excella
Tucson , Arizona
Its a 1990 Excella 25'
I will check it out on the internet.
Will let you know if its still working tomorrow.
Old 04-11-2016, 07:55 PM   #16
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Propane regulater issue?
Low water column values change the aspect ratio of the flame causing poor cooling. I experienced this last summer on my 91 with original fridgeall is.very cold.again!
Old 04-11-2016, 08:08 PM   #17
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
I will agree with the before mentioned remarks. Airflow is the key.
This is what I did and cured the problem!
ID:	260511   Click image for larger version
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 04-11-2016, 08:47 PM   #18
2014 30' Classic
where did you get the vent cap.
Old 04-11-2016, 08:56 PM   #19
2000 30' Excella
Tucson , Arizona
Hey, this is great.I'm going to have something to do for a couple of days.
Keep it coming.
Old 04-11-2016, 10:28 PM   #20
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The model of the coach is not what you want. You need the model of the refer. RM xxxx for example.
Argosy refrigerator problem ? Davis Refrigerators 5 01-21-2015 07:22 AM
Compact Home Refrigerator or RV Refrigerator? mattsteel Refrigerators 26 04-05-2011 01:30 PM
Silly Dometic refrigerator "problem" Toasty's Dad Refrigerators 0 12-20-2005 07:19 PM
Refrigerator Replacement Size Problem Herritt Refrigerators 4 05-04-2005 11:47 AM
Refrigerator Problem bken Refrigerators 2 04-26-2004 09:46 AM
