01-29-2020, 02:22 PM
2016 23' International
Mancos
Adjust temperature of refrigerator
Is there a way of adjusting the temperature of the domestic rm2551 refrigerator. Presently it is freezing the eggs on the bottom shelf
01-29-2020, 02:46 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
Have you checked the manual?
Ray B.
01-29-2020, 03:08 PM
2018 27' Globetrotter
Apollo Beach
Yes. There is a wire that is clipped to the cooling fins inside the refrigerator. If the top of that wire is higher up, the refrigerator will get colder. If you mount that wire lower, the refrigerator will be warmer. Just move the clip up or down until the refrigerator is at the temperature you desire. I adjusted the refrigerator temperature on both my 2017 FC25 and my 2018 27' Globetrotter with this method. The factory service tech showed me how to do this.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
01-29-2020, 03:16 PM
Sag Harbor
, New York
In addition to checking your AS owner's manual, and the Dometic manual that should be in your AS briefcase, assuming that you have the aforementioned clip on the fins at the top back of the fridge . . .
It is called a thermistor:
https://www.google.com/search?q=ther...com&gws_rd=ssl
. . . and a handy mnemonic to remember, which way to slide it, is: "It is colder up north."
You should also keep a good quality thermometer in the fridge to monitor things. Some folks add a small battery operated fan inside the fridge to mix up the air. Maybe move the eggs up onto a middle shelf. Cold air sinks, so the very bottom of the fridge is the coldest. Also . . . the air that comes off the cooling fins is very cold, so don't store the eggs way up there.
For even cooling don't put anything warm in the fridge . . . pre-chill it first in an ice chest etc..
Good luck,
Peter
01-30-2020, 09:56 AM
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
I continually learn by reading all of the questions and answers even though I may not have a specific issue to address. Thx all!
01-30-2020, 10:38 AM
2015 25' Flying Cloud
Bend
, Oregon
These refrigerators are so fickle.
It is definitely worth investing in a fan that sits at the bottom of the fridge to help circulate the air. I bought one of the cheap ones and it works well. i bought a more expensive on that clips onto the fins and now everything freezes!
It is a good idea to have a fridge thermometer so you know the temp of the fridge, the thermistor gives the temp of the fin it is attached too and that can be very different to the middle and bottom of the fridge.
01-30-2020, 11:15 AM
Loveland
There are battery-powered fans to circulate air within the fridge. I don't have one yet, but I'm thinking it might be a good idea.
01-30-2020, 08:22 PM
Watertown
, Massachusetts
We have one
We have one of those little fans. It helps a little, I guess. Hard to really say.
01-30-2020, 08:47 PM
2015 27' Flying Cloud
Newberg
, Oregon
That is pretty much our experience. Maybe it helps, maybe it doesn’t. Who knows?
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
01-30-2020, 08:59 PM
Bend
, Oregon
Mike
I thought it helped significantly. As i said, the fin mounted fans seem to make it worse, the bottom of the fridge freezes now..
01-31-2020, 12:16 AM
2022 25' Flying Cloud
NCR
, Ontario
we keep a good quality round thermometer in both the freezer and fridge.
this way we know if something is going bad. they are not expensive
01-31-2020, 04:03 AM
2017 FC 28 Twin
Plymouth
, Indiana
Remember if your adding fin mounted fans to improve air flow..well it does subsequently as stated adjusting the temperature of the fridge is needed especially if it is freezing everything...yes I have twin mounted fin fans plus fans mounted in the rear to evacuate hot air and yes the performance improved greatly and yes I had to readjust my Temperature.
2017 FC 28 w/ Shocker hitch
2014 RAM 3500 4x4 mega cab drw
02-05-2020, 10:41 AM
1972 25' Tradewind
East Lansing
, Michigan
You can also store the eggs on the door and place a fluffy dish towel over them. Refrigerator door shelves are generally warmer because of the close proximity to the outside! A towel helps to insulate the eggs from the colder refrigerator temperatures and retaining the 'warmer' (relatively speaking) shelf temperature.
02-05-2020, 12:02 PM
Ebb and Flo
Tulsa
, Oklahoma
White clip does the trick
My Dometic fridge has a white piece of plastic that attaches to the right side of the cooling fins. Slide it up to make it colder and down to make it warmer. Works like a champ. But, there is no wire attached to it. Just a white plastic clip.
David Briggs
Ebb - 2015 F-150 3.5L Ecoboost
Flo - 2012 30' International Serenity
02-16-2020, 07:41 AM
2005 22' International CCD
Pittsburgh
, Pennsylvania
Fridge temperature
We have a 22' 2005 CCD.
Never heard about shifting the thermistor. Will try that.
I have a fan in the outer compartment. It works well. May add a second.
I plan to keep rear compartment air away from the side of the fridge. When inside the trailer, if one touches the side of the fridge, it is warm. I suspect hot, circulating air gets in behind the fridge and keeps it warm. Not efficient.
What kind of battery powered internal circulating fan do people use?
02-16-2020, 07:51 AM
Newberg
, Oregon
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
02-16-2020, 10:49 AM
2016 30' Classic
Houston
“It’s colder up north” - I like it. Won’t forget!
02-17-2020, 03:39 PM
Sag Harbor
, New York
. . . yup!
