Wanted to double check before I attempt to pull this off. Do the end caps on the over head (Far right and left sides between the over head cabinets) just pop off? is there a trick to not breaking them? There is a fuse back there for the Cell Booster that I believe is blown. Thanks
1988 29' Excella
2008 25' Safari SS SE
Austin
They are nailed. In my 2003 Bambi, I decided to move radio from closet and install radio into right panel. I removed panel to cut for radio (also had to cut wood behind panel). I reinstalled panels using screws from inside. I tightened screws through speaker hole, careful not to over tighten (will bow panel). Inspection mirror (like one for auto work) and good light inside makes job easier.
If your 28 is like my 2012 30FC, there is a electrical panel inside to the right of the opening storage door. I removed that to get behind your panel in question to access a fish tape from the top for installation of an Sirius XM antenna .
Pulled one off by accident at a RV show . It was stapled on . Pat
