RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 07-08-2016, 01:26 PM   #1
Retail6's Avatar
2007 28' Safari SE
Springdale , Arkansas
End Caps above couch, Pop Off?
Wanted to double check before I attempt to pull this off. Do the end caps on the over head (Far right and left sides between the over head cabinets) just pop off? is there a trick to not breaking them? There is a fuse back there for the Cell Booster that I believe is blown. Thanks
Name:	Photo on 7-8-16 at 1.23 PM.jpg
Retail6 is offline   Reply With Quote
Old 07-08-2016, 01:41 PM   #2
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
When I installed the booster for tpms I just pulled the speaker out. Never thought that face might pull off.
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is offline   Reply With Quote
Old 07-10-2016, 04:06 PM   #3
Retail6's Avatar
2007 28' Safari SE
Sherrif1, Ever had one of those "Silly Me!" moments? Your right. Thats how I got in there the first time. Forgot. Thanks for the reminder
Old 07-10-2016, 04:31 PM   #4
1988 29' Excella
2008 25' Safari SS SE
They are nailed. In my 2003 Bambi, I decided to move radio from closet and install radio into right panel. I removed panel to cut for radio (also had to cut wood behind panel). I reinstalled panels using screws from inside. I tightened screws through speaker hole, careful not to over tighten (will bow panel). Inspection mirror (like one for auto work) and good light inside makes job easier.
mbutterfield is offline   Reply With Quote
Old 07-10-2016, 05:10 PM   #5
2015 28' Flying Cloud
Newtown , Pennsylvania
I had to remove the shelving and DVD player to get to the screws that hold the end cap on. Having two elbows on one arm would help.
Bruce
AstroBruce is offline   Reply With Quote
Old 07-11-2016, 02:06 PM   #6
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
If your 28 is like my 2012 30FC, there is a electrical panel inside to the right of the opening storage door. I removed that to get behind your panel in question to access a fish tape from the top for installation of an Sirius XM antenna .
Howard L. is offline   Reply With Quote
Old 07-11-2016, 04:16 PM   #7
Ventura County , California
Pulled one off by accident at a RV show . It was stapled on . Pat
Patandlinda is offline   Reply With Quote
Closed End Pop Rivets vhord Ribs, Skins & Rivets 21 01-20-2019 09:09 AM
Is this the end of my end caps? unit13 Upholstery, Blinds, Walls & Interior Finishes 9 01-02-2017 11:42 AM
Looking for 12" tambour door above rear couch Aluminumb 1984 -1986 Excella 0 10-13-2009 11:47 PM
City water pop-off valve? (drips included) empresley Fresh Water Systems 15 02-10-2008 07:12 PM
