So I get home from the amazing Region One Rally and find my 3 way fridge off.. On the way home we stopped at a farm stand and bought some steaks and stuff. When putting them in the fridge I found a flashing displace meaning no fuel. OK, just set it for DC. Check the TriMeteric and I'm only down 4 amps with the truck running.
Get home an the unit was dead. Free thought was of course panic. Did something really bad, fuse?, breaker, !!!!! control panel in unit. Looked in back of fridge an found the ground wire came off. Relief. Joy. Put it back on and the unit is still dead. Get out the meter, no
12 volt behind the unit. Panic again. I thought maybe I fryed the self resetting breaker. Checked the front panel where the
12 volt all ties together, battery, TV, fridge. Found the #8 ground to the fridge was off. Came right out of the lug.
Lesson. Just because you found one bad ground doesn't mean there isn't another. Check the simple stuff first.
